> 2010 MS3 - ECU Computer Tuning
Like Tree6Likes
  • 2 Post By G26
  • 1 Post By SRTie4k
  • 1 Post By G26
  • 1 Post By phate
  • 1 Post By charlesfist
 Old 01-06-2012, 10:03 AM   #1
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Default Can't Hit Boost Targets in 1st or 2nd Gear
So yeah any ideas? 1st and 2nd gear is off by about 1.5 psi.
All obvious tables are correct.
Throttle - Req. Load Norm BAT is set to 3
Boost Error comp is as follows...0.06 0.04 0.02 0.00 0.00 0.00 -0.02 -0.14 -0.22 -0.44 -1.10
APP Translation Tables are all the same.
 Old 01-06-2012, 11:19 AM   #2
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Well, your boost error is kinda of weak and should be more aggressive. Also, the engine is under lower load in those gears, and it might be hard to hit a high target.
rfinkle2 and deadlandxtreme like this.
The Following 5 Users Say Thank You to G26 For This Useful Post:
charlesfist (01-07-2012), emag remrofni (01-07-2012), rfinkle2 (01-06-2012), RichieRichness (01-06-2012), Teethkikr (01-06-2012)
 Old 01-06-2012, 11:33 AM   #3
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I've been using the following BEC comp table and it is working very well.
(along with 25-50% of ots LEC)
.08...... .03 <0> -.03 ..... -.08 (horizontally interpolated)
charlesfist (01-07-2012), RichieRichness (01-06-2012)
 Old 01-06-2012, 12:05 PM   #4
Groans: 35
I've tried bumping up BEC in the past but it tends to create small boost spikes. I'm beginning to think 1st and 2nd gear are very limited as far as how much boost you can push (as G26 has stated).
 Old 01-06-2012, 12:15 PM   #5
SRTie4k's Avatar
Posts: 1,715   (View Stats)
Dunno how well the OTS BEC table works on the gen2, but in my gen1 I was constantly underboosting with the overboost side skewed like that. I set mine similar to rfinkle's but less authoritative...I think something like:
.05 .03 .01 .00 0 .00 -.01 -.03 -.05
This works well for me with well calibrated WGDC. I'm always within .4psi of my target.
The Following User Says Thank You to SRTie4k For This Useful Post:
 Old 01-06-2012, 12:20 PM   #6
Teethkikr's Avatar
Posts: 677   (View Stats)
Teethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the world
Groans: 50
In my tuning adventure in my black gen2, I rarely hit full boost targets in 1st and 2nd. As soon as I hit 3rd gear I would get to target quickly.
2012 CWP Tech Package:
Powdercoated Rx-8 Wheels//35% Tint//Cobb SRI//COBB TIP//CS LED Kit//UR Test Pipe//Autotech Internals//TRZ RMM//Painted Front Grille//Painted Emblems//
Teethkikr is offline   Reply With Quote
The Following 2 Users Say Thank You to Teethkikr For This Useful Post:
atvfreek (01-06-2012), rfinkle2 (01-06-2012)
 Old 01-06-2012, 12:26 PM   #7
SRTie4k's Avatar
*removed*
 Old 01-06-2012, 12:35 PM   #8
Groans: 35
I'll try messing around with the boost error comp tables again but I think the oem EBC is not quick enough to hit 20 psi 1st or 2nd gear.
 Old 01-06-2012, 12:36 PM   #9
SRTie4k's Avatar
Remove the EBC, I guarantee you will hit more than 20psi in any gear.
ChimmyChong (01-10-2012)
 Old 01-06-2012, 12:40 PM   #10
rfinkle2's Avatar
Groans: 298
Richie, are you using the LEC table @ all?
 Old 01-06-2012, 12:48 PM   #11
Groans: 35
negative...WG Duty Load Error Comp. is set to 0
 Old 01-06-2012, 01:00 PM   #12
rfinkle2's Avatar
Groans: 298
You must really have that wgdc dialed in then.
I have yet to get decent boost control without using that table.
 Old 01-06-2012, 01:11 PM   #13
Groans: 35
Here is Pauls latest map.
Stage2+cpCAI+TIH+IC 93 v210.05.ptm
The Following User Says Thank You to RichieRichness For This Useful Post:
 Old 01-06-2012, 03:56 PM   #14
G26
G26's Avatar
Groans: 39
@rfinkle2
My load error comp is also zeroed, along with using much more aggressive boost error gets me the stable consistent boost you see in my logs.
My boost error table goes something like this
0.40 0.30 0.20 0.12 0.06 0 the overboost side mirrors that. My ebcs is in 2port
The Following 3 Users Say Thank You to G26 For This Useful Post:
charlesfist (01-07-2012), rfinkle2 (01-06-2012), RichieRichness (01-06-2012)
 Old 01-06-2012, 04:11 PM   #15
rfinkle2's Avatar
Groans: 298
Originally Posted by G26 View Post
@rfinkle2
No doubt that your map and self tune is on point.
I like to use the load error comp tables because I can be fancy and call it a hybrid tune. LOL.
They must pick up the slack for the difference in authority for the more aggressive bec table you run.
atvfreek (01-06-2012), RichieRichness (01-06-2012)
 Old 01-06-2012, 05:03 PM   #16
Groans: 35
@rfinkle2
cool thanks man...i know I have some room to play with the BEC
 Old 01-07-2012, 01:01 AM   #17
Eth Fiend
phate's Avatar
Posts: 6,931   (View Stats)
SWAS
-06 MS6
-Corn fed 07 MS3 - Sold
rfinkle2 (01-07-2012)
 Old 01-07-2012, 01:18 AM   #18
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
I can hit 26psi in 1st,2nd,3rd, and 4th gear...No its not good for the turbo yes its bad etc etc, but my car will do it. Under the BOOST section of ATR, check your Boost Come:1-2 gear and see if it is at 1.0 or if it less than 1.0. If it is less than your targets will not be met as the car is commanding less. Just a thought.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 01-07-2012, 06:01 AM   #19
Groans: 35
Yeah everything is set to 1
 Old 01-07-2012, 08:39 AM   #20
charlesfist's Avatar
Posts: 281   (View Stats)
charlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the world
I would agree with the others here. Raise ur BEC and see how it changes things.
If u do get undesirable results (spikes as u mentioned when u tried it before) and run out of ideas, last ditch effort, I would go back and actually try increasing Boost compensation for 1&2.
Depending on where u are and what ur targeting, increase the percentage appropriately.
So if your off by 1.8psi and ur targeting 18psi, increase by 1.8/18 = 0.1 (10%)
so change the 1 (100%) to 1.1 (110%) and see what happens.
charlesfist is offline   Reply With Quote
The Following 2 Users Say Thank You to charlesfist For This Useful Post:
rfinkle2 (01-07-2012), RichieRichness (01-09-2012)
 Old 01-07-2012, 10:37 AM   #21
mrmonk7663's Avatar
Phate may be correct with SWAS as well. 1st and 2nd generate a descent amount of torque steer which will impact your boost as fuel is richened and timing is pulled.
The Following User Says Thank You to mrmonk7663 For This Useful Post:
phate (01-07-2012)
 Old 01-07-2012, 03:25 PM   #22
Groans: 35
Not sure what swas is
 Old 01-07-2012, 03:33 PM   #23
CJM
CJM's Avatar
Posts: 231   (View Stats)
CJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the world
Groaned at 5 Times in 2 Posts
It's the torque steer sensor that limits boost if it senses the car getting out of control, if I'm not mistaken. Not sure what SWAS actually stands for though.
2010 LSM Speed3
Twinscroll .82 A/R GT3071 | Boost Junkyz Mani | 44mm TiAL MV-R
CXRacing/RPM Piping + TR8 | HTP 3.5" Intake | AT Internals | Forge V1
Premier Auto Modified ATP Long DP | JBR RSB | Other Miscellaneous Shit
Tuned by Me
CJM is offline   Reply With Quote
The Following User Says Thank You to CJM For This Useful Post:
 Old 01-07-2012, 03:46 PM   #24
Eth Fiend
phate's Avatar
Steering wheel angle sensor. The most intrusive system we have in our car, it seems.
-06 MS6
CJM (01-07-2012), RichieRichness (01-09-2012)
 Old 01-07-2012, 03:57 PM   #25
mrmonk7663's Avatar
Intrusive....fuck this little electronic piece of shit. It is downright dangerous in my book having that on the car. I wish COBB could work a solution for us that allowed full retention of the electronic power steering. This is my number 1 wish aside from bigger injectors at this point in time.
 Old 01-09-2012, 11:01 AM   #26
Groans: 35
If it was the SWAS wouldn't it only be an issue while turning the wheel? This issue is very consistant...doesn't matter if I'm driving in a straight line or turning.
Thanks for all the input.
 Old 01-09-2012, 11:03 AM   #27
rfinkle2's Avatar
Groans: 298
The swas sometimes affects things even when driving straight, but getting torque steer.
allo80 (10-11-2013)
 Old 01-09-2012, 11:07 AM   #28
TRex's Avatar
Posts: 3,139   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 106 Times in 69 Posts
question....why do you want such high boost in those gears anyway? i spin through 1st and 2nd at stock setting, let alone full 15 psi....
TRex is offline   Reply With Quote
 Old 01-09-2012, 11:18 AM   #29
harryclay's Avatar
Posts: 685   (View Stats)
harryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the world
^^ what he said. I dont ussually hit my full boost target in 1st or 2nd because traction is such a problem, 3rd gear is the gear!
2010 super smiley Red MS3
- Corksport SRI/TIP
- ETS TMIC
- CNT hiflow catted long DP
- Sure boost tubes
- SURE motorsports anchors
- SU RMM
- Greddy Type S BPV
- KMD HPFP Internals
- harryclay tune
- Semi-flat black wheels (painted stockers)
- Eibach pro springs ftw
- Michelin Pilot Super Sports 235/40/18
- Yellow 55v fogs
13.69 @ 106 (4g eth mix, intake/tune)
13.67 @106 (intake,dp,tmic, 50/50 eth)
harryclay is offline   Reply With Quote
 Old 01-09-2012, 11:28 AM   #30
Eth Fiend
phate's Avatar
SWAS can cause issues even when driving straight.
-06 MS6
rfinkle2 (01-09-2012)
 Old 01-09-2012, 11:30 AM   #31
Groans: 35
because I have MS6 and MS3 guys will get traction with slicks.
The Following 4 Users Say Thank You to RichieRichness For This Useful Post:
AZSPEED3 (01-09-2012), harryclay (01-09-2012), phate (01-09-2012), TRex (01-09-2012)
 Old 01-09-2012, 11:45 AM   #32
TRex's Avatar
well there you go
The Following User Says Thank You to TRex For This Useful Post:
 Old 01-09-2012, 11:47 AM   #33
Groans: 35
Oh yeah and because race car!
The Following 3 Users Say Thank You to RichieRichness For This Useful Post:
ChimmyChong (01-10-2012), harryclay (01-09-2012), TRex (01-09-2012)
Why are the boost targets so low at 75% TP? event MazdaSpeed 3/6 - ECU Computer Tuning 6 08-18-2011 02:06 PM
Boost Targets Table... Significance when Tuning Load/Gear dougefresh_
Cobb ATR Support
18 05-19-2010 08:06 AM
Boost Targets AntiStock
Cobb ATR Support
8 02-02-2010 01:21 PM
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 06:36 PM
Why are TRL load targets lower for 2nd gear than all the other gears? bast525
Cobb ATR Support
13 05-01-2009 07:16 PM
Page generated in 0.79491 seconds with 31 queries
