![]() | | #1 | ![]() |
![]() Join Date: Jun 2012 Location: Hooksett,NH
Rep Power: 444 ![]() Thanks: 77
__________________ -13' CWP MS3- JBR 88a Rmm // Full3 Aeros ID300 Intake // At Internals // UR Catless Tbe // JBR Occ // Forge V2 // Cobb FMIC // Ngk(6510)@.026 // Devils Own WMI // Freek Tune // Swift Springs 323hp/351tq SAE Sold // 12' Ms3 // 305hp 336tq SAE |
| can't take out voltron ![]() Join Date: Apr 2012 Location: Wood-Ridge, NJ
Rep Power: 4882 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,082
both ffs and lc are fuel cut. hence why you see lean afr using lc. ffs has been known to give you rich afrs if you lift anf shift. just ffs and come back and tell us how much you like it son |
| The Following 4 Users Say Thank You to ms3blackmica For This Useful Post: |
Maybe I wasnt very clear my bad This morning for example. I did a wot run from 3rd to 4th Not using the no lift shift I hit high 10s during the shift then it made its way back to 11.8afr (normal) Using the no lift shift from 3rd to 4th it hit 12.7 and just stayed there for more than my liking while i was accelering so i backed off. Flat foot shift im not lifting because your not suppost too just keep the pedal pinned and go threw the gears with the clutch.
![]() | | #4 | ![]() |
![]() Join Date: Jul 2010 Location: Clarksville, Md
Rep Power: 676 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,173
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake | |
![]() | | #5 | ![]() |
![]() Join Date: Jan 2010 Location: Austin, TX
Rep Power: 658 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,588
Groans: 44
acceleration pedal to the ground.. push clutch in.. shift gears.. release clutch.. acceleration pedal still to the ground. all with in a second or less = win
__________________ ![]() ZOOM ZOOM left the Room ![]() |
| The Following User Says Thank You to silentwolf8 For This Useful Post: | fortressofcomfort (09-20-2012) |
![]() | | #6 | ![]() |
![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 380 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... | |
| The Following User Says Thank You to fortressofcomfort For This Useful Post: | voltron (09-20-2012) |
![]() | | #7 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 356
Groaned at 4 Times in 2 Posts
How would you disable ffs? Just leave its value at redline? Sent from my ADR6300 using Tapatalk 2
__________________ Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP Stage 2 tune - Koni yellow struts - H&R springs _ (Looking for BT) |
![]() | | #8 | ![]() |
| Not Ranked : 0 score |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is exactly what I am doing. I actually just did another 3rd to 4th run only becuase it is the easiest quickest shift. Yet again right after the shift i saw a 13 then it stayed right at 12.8afr and i accelerated a good 5-10 mph more and i said fuck that and let off. Any insight to this??
![]() | | #10 | ![]() |
| voltron down ![]() ![]() Join Date: Oct 2011 Location: Dirty ass Jersey.
Rep Power: 4692 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,270
Groans: 43
Groaned at 14 Times in 14 Posts
Ffs is the shit. Period.
__________________ 2012 HYPNOTIC TUNED 5k hids. 3k fogs. ![]() 12.15@117 Mason Dixon Raceway 4-14-13 |
| The Following 2 Users Say Thank You to voltron For This Useful Post: | England15j (09-20-2012), ms3blackmica (09-20-2012) |
![]() | | #11 | ![]() |
| S.I. Reppin! ![]() Join Date: Jun 2012 Location: Staten Island, NY
Rep Power: 147 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,137
Groaned at 7 Times in 6 Posts
And it's not enabled for the 2010 models. |
![]() | | #12 | ![]() |
Groans: 44
I know it blows. Ill be at cobb tomorrow so maybe i have them give me insight on why its not working.
| The Following User Says Thank You to silentwolf8 For This Useful Post: | moomooz12 (09-20-2012) |
![]() | | #13 | ![]() |
(Thread Starter) | Not Ranked : 0 score See if they have a car there they can compare afr #'s too in person while using the ffs. It would be a big help for all of us ffs users to see it from the source.
![]() | | #14 | ![]() |
| Not Ranked : 0 score Be sure to update us.
__________________ Autotech HPFP Internals || Corksport TBE || cp-e FMIC || JBR 3.5" WP Intake || JBR TIG & Coolant bypass || JBR EGR delete || JBR OCC || JBR 88 RMM || JMF Direct Port Meth Inj IM || Stratified 2-Port EBCS || Turbosmart BOV || NGK colder plugs |
![]() | | #15 | ![]() |
Groans: 44
Talked to the guys at cobb. They said they found the issue but its in the testing phase before they do a release on it. No time frame on when they are though yet.
| The Following 2 Users Say Thank You to silentwolf8 For This Useful Post: | moomooz12 (09-21-2012), ms3blackmica (09-21-2012) |
![]() | | #16 | ![]() |
| Not Ranked : 0 score good shit
![]() | | #17 | ![]() |
![]() Join Date: May 2011 Location: Bakersfield, CA
Rep Power: 111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
Wow, I'm glad I stumbled upon this. I really dig FFS, but not if there's potential for damage. Thanks for posting this up
__________________ Installed: CS SRI & TIP | Cobb AP | JBR SSP & Bushings | AT Internals | 235/40/18 Conti DW | JBR 80a RMM | UR Test Pipe || CP-E TMIC || UR Catted DP at home in a box waiting for me to develop mechanic skills | Perm Tune |
![]() | | #18 | ![]() |
![]() Join Date: Feb 2012 Location: Dana Point, CA
Rep Power: 654 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,303
Groans: 96
Hmm I have FFS enabled but I never use it. I guess I should disable it incase I'm running rich after shifts (havent checked) I wish there was a dashhawk for genpus
__________________ 2012 MS3 Stratified 91 Cobb AP | UR FMIC, TP, CBE | Autotech Internals Forge v2 BPV | Denso ITV22 | SURE Aeros Full3 ID283* JBR 88a RMM/TMM, 70a PMM, OCC, RSB, TIGs, Coolant bypass, EGR delete, Bushings, Knob Aeroforce Interceptor | Pennzoil Plat 10W-30 | FoMoCo XT-M5-QS 15% Tint *Product is advertised as ID300 |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
I am using my aeroforce and that is how i am seeing my afr's. I'm sure not many ms3's owners are actually monitoring this. I thought cobb already did an update on this?
![]() | | #21 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 1939 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,593
Groans: 297
Groaned at 186 Times in 102 Posts
Anyone know what made them go for fuel cut over ignition cut?
![]() | | #22 | ![]() |
Groans: 44
Probably cause of the DI ? Tht would be mu guess but who knows.
![]() | | #23 | ![]() |
![]() Join Date: Jun 2010 Location: San Antonio, Tx
Rep Power: 282 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,447
Groans: 43
Groaned at 8 Times in 4 Posts
Had the pleasure of experiencing this during tonight's Test-n-Tune. AFR's in the 12.6 range at WOT going from 3rd to 4th. knock all throughout 4th as well.
__________________ 2013 Black Mica Mazdaspeed 3 |
![]() | | #24 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 879 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
I ffs on races that are close. Have to get that edge! Sent from my dizzLe using RaWr powers!
__________________ 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Next: TMIC(WTB PM me); meow DP Official 60-100mph Times Official Youtube Channels |
![]() | | #25 | ![]() |
| Not Ranked : 0 score I think it's because it's easier for them to implement seeing as how they use fuel cut for load targets and such.
