![]() | | #41 | ![]() |
| Harvestor of PU ![]() Join Date: Jun 2011 Location: in the snowy mountains of narnia
Rep Power: 920 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,916
Groans: 170
Groaned at 25 Times in 20 Posts
| Not Ranked : 0 score
__________________ 2012 BM MS3 w/ tech. No bolt ons. self tuned. |
| The Following 2 Users Say Thank You to Harvey PU For This Useful Post: | mazdaspeed916 (08-20-2012), rfinkle2 (07-26-2012) |
![]() | | #42 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
Groaned at 21 Times in 10 Posts
| Not Ranked : 0 score mazdaspeed916 sorry for my delayed answer. I am on vacation and don't use the pc at all. As some here already said AFR are off. I think that that is because of the KR(which you should not worry as rfinkle2 said). Did you change all the Fuel tables as per the guides? How about the Knock Tables? Make sure you do these. Otherwise the MAF calb looks ok, maybe slightly off when Mass Airflow is under 18 but it is good. Just try rfinkle's map For sure he has done pretty much all the basics stuff.
| The Following User Says Thank You to dead-zone For This Useful Post: | mazdaspeed916 (08-20-2012) |
![]() | | #43 | ![]() |
![]() Join Date: Nov 2010 Location: Elk Grove, CA.
Rep Power: 61 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 113
(Thread Starter) | Not Ranked : 0 score rfinkle2 Harvey dead-zone, ok been on vacation myself, back now, I am going to head out tomorrow night to do a few logs and am ready to go to work on this tune. Also started to read up on phate and his e85 thread, I think I may have found an e85 station nearby, kind of curious to try a mix..... but also scared lol
__________________ Velocity Red 2010 Genpu -Drag Wheels DR-31 18X8 5-100/114 48FBR -Cobb DP -Cobb SRI/TIP -Cobb AP Selftune -Cobb Shift Weight -CP-E TMIC-CP-E RMM CP-E HPFP -DENSO Sparkplugs -Ksport Coilovers -SPC Camber Arms - Whiteline Front Endlinks -Forge BPV v.2 -CorkSport Front License Plate -UR Catback ![]() |
| The Following User Says Thank You to mazdaspeed916 For This Useful Post: | Harvey PU (08-20-2012) |
![]() | | #44 | ![]() |
![]() If I were you, first I would build a nice 93 map and then start with e85. Especially, If you tune it yourself you will have more experience(from tuning 93 map) and that way you will understand the whole process better. The only thing with e85 is that a good tune is a must. Moment that you put that E85 the car will tun lean and like shit. Soon I will be adding some e85, 50/50 mixture. | |
| The Following 2 Users Say Thank You to dead-zone For This Useful Post: | Harvey PU (08-20-2012), mazdaspeed916 (08-20-2012) |
![]() | | #45 | ![]() |
Groans: 170
yes, i would say get a good 93 map first. then start putting in some E85 and messing with that. E85 is amazing, but not going to be everywhere you go, so you want to have a 93 map in case.
| The Following User Says Thank You to Harvey PU For This Useful Post: | mazdaspeed916 (08-20-2012) |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score Harvey I don't have 93 here in any pumps nearby. Would octane booster get me to the desired 93 and if so any brand suggestions?
![]() | | #47 | ![]() |
I did some digging and found that torco and lucas seem to be the better of the bunch but that it only raises octane a total of 30 points which doesn't get me to 93.... stupid CA gas stations ><
![]() | | #48 | ![]() |
Groans: 170
| Not Ranked : 0 score didnt see you are California. Tune for 91. good to have a reliable map for what you have. Then make an E85 map. use the E85 map for fun! 91 map is there for if you travel and dont have e85 nearby.
![]() | | #49 | ![]() |
Ok so first WOT in 3rd from tonight, i'll try to get another tomorrow night.
![]() | | #50 | ![]() |
The only difference between the 91 and 93 is that tune won't be as aggressive as on 93, specifically won't be able to push timing a lot. But as Harvey said just have a good 91 map for back up. |
![]() | | #51 | ![]() |
Groans: 170
looks like you have room for more boost/timing. those AFR's are just fine for 91. you can either push this map a little bit more, or if you want, you can start working on E85. start with a 3 gallon mix. you would be amazed how much of a difference it makes
| The Following 2 Users Say Thank You to Harvey PU For This Useful Post: | mazdaspeed916 (08-21-2012), rfinkle2 (08-21-2012) |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Harvey anything I should be prepared to tweak after the 3 gallon mix?
![]() | | #53 | ![]() |
Most likely will need to do another MAF CALB
| The Following User Says Thank You to dead-zone For This Useful Post: | mazdaspeed916 (08-21-2012) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to dead-zone For This Useful Post: | rfinkle2 (08-21-2012) |
![]() | | #55 | ![]() |
Rep Power: 11938 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,968
Groans: 235
If you guys have a nice clean pump gas maf curve, you can use the injector scalars that Cobb implemented when you start using e85. *****word of caution guys !!!! ******** DO NOT TUNE FROM KNOCK SENSOR FEEDBACK when using e85. There is a chance you will never see kr and pass MBT (aka minimum timing for best torque), which is deadly for the rods and engine in general. Please see below linked thread, and back off of the dyno proven ignition values by a substantial margin if tuning timing on e85. scalar here: E85 Beta, now live on ATR And a huge thanks to Phate for his proven ignition map thread here: The E85 and E85 Mix *Ignition Timing* Database
| The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: | dead-zone (08-21-2012), Harvey PU (08-21-2012), mazdaspeed916 (08-21-2012), TiGraySpeed6 (08-21-2012) |
![]() | | #56 | ![]() |
Groans: 170
yea just gotta scale the injectors and touch up the maf cal. Then the fun part of power tuning!
![]() | | #57 | ![]() |
Groans: 170
| Not Ranked : 0 score Im sorry im getting confused with the two of you lol. you have a log?
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score Harvey when you ran 3 gallons of e85 what did you set scalar and specific gravity to? That would put me at 25% so specific gravity 0.75 and scalar of 1.1?
__________________ Velocity Red 2010 Genpu -Drag Wheels DR-31 18X8 5-100/114 48FBR -Cobb DP -Cobb SRI/TIP -Cobb AP Selftune -Cobb Shift Weight -CP-E TMIC-CP-E RMM CP-E HPFP -DENSO Sparkplugs -Ksport Coilovers -SPC Camber Arms - Whiteline Front Endlinks -Forge BPV v.2 -CorkSport Front License Plate -UR Catback ![]() Last edited by mazdaspeed916; 08-21-2012 at 01:15 PM. Reason: added info |
![]() | | #59 | ![]() |
Here they are. I just need feedback and opinion. datalog30.csv datalog29.csv datalog24.csv Timing table.png EDIT: I will be adjusting timing where kr occurs. | |
![]() | | #60 | ![]() |
Groans: 170
__________________ 2012 BM MS3 w/ tech. No bolt ons. self tuned. Last edited by Harvey PU; 08-21-2012 at 02:03 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Harvey PU For This Useful Post: | mazdaspeed916 (08-21-2012) |
![]() | | #61 | ![]() |
![]() It is consistent and it is in that 5000-5600rpm range. I already pulled some timing. Just have to do some logs and see how it is. I have another 93 map with boost 19psi and less timing(no KR). I wanted to try lower boost, 17, high timing(the current map). In comparesin, I do make more HP on the low boost high timing map but much less torque, about 30 less torque then the 19psi map. With both of the maps the car pulls very nice. On the 19psi the power sidenly comes, more like a kick. The 17psi map the power is more smooth. I do get more wheel spin on the 17psi map. | |
![]() | | #62 | ![]() |
Sigh, so the only gas station nearby is out of e85 and they aren't sure when they're getting more. So let's work on my 91 map, here's the most recent WOT and the map that is being used.
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score rfinkle2 Harvey dead-zone ok so I read buckers cheat sheet on timing again and made adjustments. Before I mate this to my car here's what I did, I added 1* to the no knock tables and then made sure the knock tables were 2* lower and that the max A&B tables were 2* higher let me know if I did that correctly. Thanks again everyone for your input.
![]() | | #64 | ![]() |
Groans: 235
I didn't mean to barge in the thread. All of the advice you have gotten so far seems sound to me.
__________________ CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R) ● CPE HPFP ● CPE RMM ● CPE FMIC ● CPE TOW PLATE ● CPE TRITON CBE ● HTP 3" TIP ● HTP BATTERY RELOCATE● COBB AP ● GRIMMSPEED 3 PORT BCS ● COOLING MIST / DEVILS OWN METHANOL INJECTION ● DEFI Boost gauge ● TWM FULL REPLACMENT ● TWM M1 ABRAMS ● JBR SSP ● JBR RSB JBR TIG ● H&R COILOVERS● JUMPING JACKSON 3 BAR MAP HARNESS ● STOPTECH STAINLESS LINES ● AKEBONO EURPO 915a ● TANABE STRUT BRACE ● NEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KIT ● GRAM LIGHTS 57 DR ● TOYO PROXES PLUS | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Harvey PU (08-22-2012) |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Any input is much appreciated =)
![]() | | #66 | ![]() |
Groans: 170
| Not Ranked : 0 score mazdaspeed916 i cant look at the map. i dont have ATR for a 2010. but what you said you did sounds right. the general rule with timing, is to raise a degree at a time, until you start to see KR. Then back off 1-2 degrees. If you're getting on E85, i would say back off 2 degrees from that point to make your 91 map safe
| The Following User Says Thank You to Harvey PU For This Useful Post: | mazdaspeed916 (08-22-2012) |
![]() | | #67 | ![]() |
That the way you need to go. It sounds right. Post the logs though and pic of your ignition table.
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are the tables
![]() | | #69 | ![]() |
Groans: 170
timing curve is fine. thats not very much timing though. You can bump it up a degree at a time until you see KR, then back off a degree or two
| The Following User Says Thank You to Harvey PU For This Useful Post: | mazdaspeed916 (08-25-2012) |
![]() | | #70 | ![]() |
You can do way more timing! Just do it as Harvey said, slowly. And be patient. It does take some time to adjust it.
| The Following 2 Users Say Thank You to dead-zone For This Useful Post: | Harvey PU (08-25-2012), mazdaspeed916 (08-25-2012) |
![]() | | #71 | ![]() |
| can't take out voltron ![]() Join Date: Apr 2012 Location: Wood-Ridge, NJ
Rep Power: 4921 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,185
| Not Ranked : 0 score those .doc files were hard to see lol i had to zoom in to about 300% to see the table properly. If you can post up screenshots as regular picture files it would help a lot. Your timing is very low, but thats perfectly okay... Best way to tackle this adjustment is start low and work your way up. Not only is the best way to do it, but also the smartest. Add in small increments also! Try increments of 0.5 at at time. You will feel the difference when you get the timing dialed in. Something funny that i did once was i saved my map with the low timing in a seperate folder, and after i was done with timing, i flashed back the same map but with the low timing values, and wow is all...It may be hard to feel the difference when your doing pulls all the time to tweak ignition advance, but when you see the final difference between OTS and your final product, its a sweet feeling.. |
| The Following 3 Users Say Thank You to ms3blackmica For This Useful Post: |
![]() | | #72 | ![]() |
Groans: 235
When I set the base map up, I blended the max tables with the high and low throttle tables in order for you to be able to edit 1 table, and copy and paste it to the remaining tables. Bucker's method is perfectly sound, but I find it easiest to use the same timing in all of the maps. The ecu still pulls timing when it detects knock @ a set rate, regardless of the knocking tables. -note: There are values in the ots max tables that are keeping your car from running higher advance than as seen in the high and low throttle tables. In the tables I put into your map, those values are seen in all of the ignition tables, meaning you may now edit one table, and copy and paste those values into all of the tables to avoid confusion. (I find it best to work this way, but other methods certainly work as well).
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #73 | ![]() |
The most consistent way (and this is the way i do it too). The ecu DOES in fact still pull timing accordingly when it detects knock regardless of the knocking table's values. I would set the Max Tables to the same as your primary ignition tables so that you do not have any issue with not hitting your set timing at some point if you go beyond the OTS values in the max tables. This method becomes easy because you can edit one table, and then copy and paste the entire table into all of the tables and no be confused just as finkle said. | |
![]() | | #74 | ![]() |
| lowspeed ![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 1761 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,704
With all this talk of "just copy one table & paste it to the others" going on, it's important to remember that the Max A & B tables have 3 extra lines at the top of the table, and if you just quickly go to the top left corner then ctrl+v you'll be screwing up. Be sure to select 0.31/500 and paste from there. The other tables have a lowest value of 0.31, but the max tables add 0.13, 0.19 & 0.25.
__________________ Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04 Last edited by TiGraySpeed6; 09-07-2012 at 05:45 AM. Reason: left, right, whatever..... |
| The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | mazdaspeed916 (09-07-2012), ms3blackmica (09-07-2012) |
![]() | | #75 | ![]() |
Groans: 235
![]() | | #76 | ![]() |
(Thread Starter) | Not Ranked : 0 score Haha yes, he had me confused for a second, btw thanks again rfinkle2 that base map has been easy to slowly change via the different help faqs and info from the guys in this thread. I'd have to say thanks to Bucker for his cheat sheet too thats been helpful.
| The Following 3 Users Say Thank You to mazdaspeed916 For This Useful Post: |
![]() | | #77 | ![]() |
| Not Ranked : 0 score Hey ! We are not turkeys ![]() lol |
![]() | | #78 | ![]() |
Found a E85 station thanks to Bosox going to clean up this 91 map and then start with a 3 gallon E85 map.
| The Following User Says Thank You to mazdaspeed916 For This Useful Post: | ms3blackmica (10-01-2012) |
![]() | | #79 | ![]() |
![]() | | #80 | ![]() |
(Thread Starter) | Not Ranked : 0 score rfinkle2 I think I am ready for a hypnotic tune.
| The Following User Says Thank You to mazdaspeed916 For This Useful Post: | rfinkle2 (04-18-2013) |
