> 2010 MS3 - ECU Computer Tuning
  • 1 Post By atvfreek
 Old 03-17-2013, 09:23 PM   #1
derek13p's Avatar
Posts: 1,194   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
Default Fuel pressure drop
So I was driving from Houston to San Antonio today and after more than an hour of driving I went WOT in 5th gear and around 5-6k rpm I felt my engine stutter and loose power so I let off and slowed down, downshifted and tried it in 4th, same thing around same rpms...
I did one more time and logged it to see what was happening and when I look it shows my fuel pressure drop like crazy then a second later boost gets cut. It also shows my accelerator pedal pos change but I had it to the floor until the boost got cut. (log 20)
I've also attached two other WOT logs wot1 and wot2 which I did yesterday and sent in for an e-tune with stratified. I didn't experience anything bad during these logs at all.
Someone told me it may be bad gas because this happened right after I filled up in a place ive never filled up at before.
I've also been told maybe the spark plugs need to be changed or my fuel pump is bad..
As far as power mods, my car has Autotech fp internals which have been on for ~8k miles, cobb sri/tip, cp-e fmic and catless dp. The fmic and dp are brand new, just put on last sunday.
Ill include the map I'm using as well.
Any opinions would be great. I don't want to go zzb right as I'm getting into my tune :/
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
 Old 03-17-2013, 09:37 PM   #2
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Groaned at 64 Times in 49 Posts
Aside from being rich, fuel pressure is strong across the board, no major knock. I'd say you just need to get a real tune. 10.9-11.1 is realllllyyyyyy rich. You want to be 11.5-12.1 tops. Any wheel spin/ Was DSC off? @rfinkle2; @ms3blackmica; @atvfreek; can give you more input.
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
The Following 3 Users Say Thank You to Payne Racing 67 For This Useful Post:
atvfreek (03-18-2013), derek13p (03-17-2013), rfinkle2 (03-18-2013)
 Old 03-17-2013, 09:42 PM   #3
derek13p's Avatar
Groans: 38
Originally Posted by Payne Racing 67 View Post
Aside from being rich as fawk, fuel pressure is strong across the board, no major knock. I'd say you just need to get a real tune. 10.1-11.1 is realllllyyyyyy rich. you want to be 11.5-12.1 tops.
Yeah I literally just purchased a tune from stratified 2 nights ago and sent them those 2 wot logs and 2 maf logs so I should be getting into a good tune soon.
As far as the pressure drop in log 20 though. Should I be concerned? it did that in 3rd 4th and 5th gear when I was on the road and went wot. But after I got to a friends house to show him it didn't do it again and by that time I was pretty much done with that tank of gas. Just filled up at my normal place and put some b12 injector cleaner in it to be safe.
No wheel spin and DSC was on. I was in the middle of fucking with an srt4 caliber when it first started haha
06 MS6 & 06 MS6
Daily driven
The Following User Says Thank You to derek13p For This Useful Post:
Payne Racing 67 (03-17-2013)
 Old 03-17-2013, 09:46 PM   #4
Ohhhh woah, wait....I missed that until you pointed it out. Possibly bad gas but keep on eye on it man...seems like the internals could possibly be fuckin up. Your FP definitely should not be dropping THAT low
 Old 03-17-2013, 09:54 PM   #5
btstarcher's Avatar
Posts: 4,850   (View Stats)
Groans: 112
Fuel cut/throttle close?
SnailTune in progress
DingoDave (03-18-2013)
 Old 03-17-2013, 09:55 PM   #6
derek13p's Avatar
Groans: 38
So should I be looking into purchasing new fp internals or a whole pump or what?
06 MS6 & 06 MS6
Daily driven
 Old 03-17-2013, 10:01 PM   #7
derek13p's Avatar
Groans: 38
Yeah I saw that too. I had it floored until the boost started getting cut so i'm not sure why the throttle pos was decreasing..
06 MS6 & 06 MS6
Daily driven
 Old 03-17-2013, 10:03 PM   #8
btstarcher's Avatar
Groans: 112
After looking at the log, I don't think it's fuel cut, but not sure.
 Old 03-17-2013, 10:11 PM   #9
derek13p's Avatar
Groans: 38
Any ideas on what I should do?
06 MS6 & 06 MS6
Daily driven
 Old 03-18-2013, 01:04 AM   #10
btstarcher's Avatar
Groans: 112
@Boost_creep;
 Old 03-18-2013, 01:41 AM   #11
turboKart's Avatar
Posts: 321   (View Stats)
turboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the world
Groaned at 8 Times in 4 Posts
Default my opinion, for free, and worth it!
Do you have an AP? Turn on other parameters, like [Accel. Pedal Pos.], [Fuel Inj. Amt], [HPFP Des. Press.], [HPFP Sens. Volt.], [Inj. Duty Cycle and Pulse Width]. It could be the spill valve - if you look at voltage and demanded psi, you should see something. There are threads on cleaning the pump worth a look as well. I think the Relief Valve can cause that too, but I'm not sure how to troubleshoot it.
'09 MGM MS3 - 'MaZcedes'
* Cobb A/P * CP/e S2 RMM * Autotech/6oost3d/McMaster-Carr HPFP Internals * JBR PowerPath SRI/TIP * ATP Catless DP * Cobb XLE BPV * Bilstein B8 Sprint Shocks * JBR 32mm Rear Sway Bar *
STRATIFIED...proper - ZFZMF!
turboKart is offline   Reply With Quote
The Following User Says Thank You to turboKart For This Useful Post:
derek13p (03-18-2013)
 Old 03-18-2013, 05:39 AM   #12
atvfreek's Avatar
Posts: 7,787   (View Stats)
Is that the only log that fuel pressure has dropped that low?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following User Says Thank You to atvfreek For This Useful Post:
 Old 03-18-2013, 07:05 AM   #13
Yeah Justin the 2 that he took before it were fine. Thats why Im not sure what to gather from the last one. Why is the pressure dropping so dangerously low other than the fp acting up
Sent from the Smurfmobile
 Old 03-18-2013, 07:11 AM   #14
derek13p's Avatar
Groans: 38
I can turn those all on and try and duplicate the issue again if you think its safe to do so.
That's the only time I logged the issue. I was able to duplicate it 5-6 times within a few minutes in different gears, all around the same rpm, before I took out the AP and did it one last time to log it and then just took it easy for the rest of the drive.
I know for sure that each time whatever happened happened it was getting boost cut in the higher rpms and that's what made the vehicle start to stutter and loose power. I am not sure if it was dropping fuel pressure the other times, though I would only assume that was why it was cutting the boost since fuel pressure was cut/dropped first?
06 MS6 & 06 MS6
Daily driven
 Old 03-18-2013, 07:12 AM   #15
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
What intake are you running?
 Old 03-18-2013, 07:14 AM   #16
atvfreek's Avatar
If you are able to duplicate it, then you need to address that before lex can tune you. I doubt the autotechs have failed, but you never know. The autotechs do over run the relief valve frequently, so it may be the relief valve that has taken the hit. Really the only way to find out is to swap components with a known good component.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
alex_speed13 (05-21-2013), derek13p (03-18-2013), Payne Racing 67 (03-18-2013), rfinkle2 (03-18-2013), timjs (05-14-2013)
 Old 03-18-2013, 08:17 AM   #17
derek13p's Avatar
Groans: 38
Well once I got to san Antonio and got to another members house to show him we tried a few pulls in 3rd and couldn't duplicate it again. He recommended me change my plugs, said it might be bad gas, and told me to run some b12 injector cleaner. So when the tank was on E I filled up with some 93 that I knew was always good and put the b12 in there.
I can have those other parameters checked and go do a wot or two on a good stretch of road here in a few hours and post up what happens?...
I've got the cobb sri/tip combo.
06 MS6 & 06 MS6
Daily driven
 Old 03-18-2013, 08:39 AM   #18
I would go and do it anyways man. Just so that we can look at the logs and either determine what is wrong, or possibly be able to say it was in fact just bad gas.
The Following User Says Thank You to Payne Racing 67 For This Useful Post:
 Old 03-18-2013, 08:42 AM   #19
rfinkle2's Avatar
Groans: 298
atvfreek and Joey both give excellent advice here. I tend to agree that your rail valve may be starting to go bad.
Have you had any strange idle issues?
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (03-18-2013), derek13p (03-18-2013), Payne Racing 67 (03-18-2013)
 Old 03-18-2013, 09:12 AM   #20
derek13p's Avatar
Groans: 38
for sure, I'll do that here in an hour or so then
hmm, I had noticed while idling a few days ago a slight thump/knock that I felt through the peddles. Happened randomly and was real slight then went away.
06 MS6 & 06 MS6
Daily driven
 Old 03-18-2013, 10:51 AM   #21
derek13p's Avatar
Groans: 38
So I went out and did 5 logs, watched fuel pressure the whole time and it never dipped, boost never cut either.
Differences between now and when it happed:
Different gas
B12 injector cleaner
Traction control off
Wasn't running car for over an hour
Logs are attached
06 MS6 & 06 MS6
Daily driven
 Old 03-18-2013, 12:45 PM   #22
turboKart's Avatar
Default careful, mi amigo
The last log you posted looks ok - AFR is =<11, and your pump is not dropping pressure. Your IDC is 75%, which is within the [60-80?] I've heard as ok, especially since you are running rich.
But - I am not offering to analyze yer log - I just want to push the fact that everything you need, other than the tools and will to get under the hood, is right here, based on my experience.
That, and the fact I would not drive that car without AT LEAST ALWAYS logging and watching your hpfp psi until you fix this - what you have logged is a condition that I believe kills these engines...and whatever the problem was may have just flushed elsewhere, or just be waiting to do it again. There are some great threads on how to work/maintain the HPFP components here.
 Old 03-18-2013, 01:59 PM   #23
derek13p's Avatar
Groans: 38
Definitely, that's why I got straight on here for help. I was so scared to go zzb.
I'm going to use more injector cleaner and change my plugs and check the internals and clean them next chance I get.
that and I hope getting this new tune will help out
06 MS6 & 06 MS6
Daily driven
 Old 03-18-2013, 10:44 PM   #24
turboKart's Avatar
Default the beard will guide you
Here is a great link on taking off the spill valve and cleaning it out.
It comes off easy with a 32mm wrench.
http://www.mazdaspeedforums.org/foru...le-hpfp-96970/
derek13p (03-19-2013)
 Old 03-19-2013, 11:56 AM   #25
derek13p's Avatar
Groans: 38
hell yeah, thanks man, I'll be doing that for sure!
06 MS6 & 06 MS6
Daily driven
 Old 05-14-2013, 09:51 AM   #26
mazdaspeed916's Avatar
Posts: 167   (View Stats)
mazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond repute
@derek13p I am running the same OTS map (minus the changed commanded AFR to 11.6) you are right now and I had the same hiccup last night. Was in 3rd WOT and i want to say around 4500 RPM car just lost power but I haven't been able to replicate it like you did. I'd like to see what you find out.
SOLD AS OF 6/20/13 Velocity Red 2010 Genpu -Drag Wheels DR-31 18X8 5-100/114 48FBR -Cobb DP -Cobb SRI/TIP -Cobb AP Selftune -Cobb Shift Weight -CP-E TMIC-CP-E RMM CP-E HPFP -DENSO Sparkplugs -Ksport Coilovers -SPC Camber Arms - Whiteline Front Endlinks -Forge BPV v.2 -CorkSport Front License Plate -UR Catback
New Ride:
Snowflake White Pearl 2014 Mazda 6 Grand Touring
mazdaspeed916 is offline   Reply With Quote
 Old 05-14-2013, 05:01 PM   #27
derek13p's Avatar
Groans: 38
Bad gas is what I had. I put some fuel system cleaner in and took it easy till next fill up(drained tank) and then filled up where I knew the gas was good and I haven't had it since.
06 MS6 & 06 MS6
Daily driven
 Old 05-14-2013, 05:35 PM   #28
Now that I think about it I did goto a different gas station from usual.
New Ride:
 Old 05-14-2013, 05:57 PM   #29
derek13p's Avatar
Groans: 38
yeah, just fill up where you normally do or in nice parts of town where you know people buy premium.
hope that's all that it was for you.
were the symptoms exactly the same?
06 MS6 & 06 MS6
Daily driven
 Old 05-15-2013, 09:40 AM   #30
Pretty much identical, did you have a different idle also until you got rid of the bad gas?
New Ride:
 Old 05-15-2013, 11:44 AM   #31
derek13p's Avatar
Groans: 38
hmm, idk, I drove across Texas so the gas was gone pretty fast hahs
06 MS6 & 06 MS6
Daily driven
 Old 05-27-2013, 09:38 PM   #32
Texas Speed Demon Fag's Avatar
Posts: 527   (View Stats)
Texas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond reputeTexas Speed Demon Fag has a reputation beyond repute
#Richtune any ideas?
Texas Speed Demon Fag is offline   Reply With Quote
 Old 05-27-2013, 10:24 PM   #33
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,899   (View Stats)
Groans: 540
#inspectorgadget #swaglife #derekdoo #realtalk #badgas #oldthread #problemsolved #nce @pzr2874;
94 M
06 MS6
Logs showing 1 point of fuel pressure drop into the 100s breakfasteatre MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 12-09-2012 06:18 PM
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-03-2012 12:12 AM
Fuel Pressure Drop/Cut Burton MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 05-31-2012 07:43 PM
Fuel Pressure Drop after load of 2 dpolseno41 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-17-2012 07:37 PM
Drop in Boost Pressure Jujiro_Prodigy_31 MazdaSpeed 3/6 - Turbo Induction 4 01-12-2010 04:04 PM
Page generated in 0.91015 seconds with 29 queries
