> 2010 MS3 - ECU Computer Tuning
Notices
 Old 10-11-2012, 05:57 PM   #1
MazdaBoy2.3's Avatar
Posts: 2,282   (View Stats)
MazdaBoy2.3 has disabled reputation
Default Fuel Pressure dropping when slowing.
Let me start this by saying:
idle is pretty consistent around 420-440
cruising 1000-1200
WOT 1600+
My questions is when i am downshifting, and using my gears to help slow the car, I see my fuel pressure drop to about 300. Is that normal? As soon as i put the clutch in, or touch the gas, it jumps back up. Best example would be if you are going down a steep grade and you are using the gearing of the car to help hold the speed down instead of using the brake, the pressure will drop to around 300 and hold there until i put the clutch in and it jumps back up to 400+
2010 Black Mica
Corksport: RP, SRI/TIP, Cold Airbox, RMM Inserts, Mudflaps
JBR: SSP & Bushings
SURE: Boost Tubes
COBB: Accessport
Other: AT Internals, 35% Tint, DDM 6k HID, NGK Plugs
My car is being rfinkle(d) with! VD: 263hp/319tq
MazdaBoy2.3 is offline   Reply With Quote
 Old 10-11-2012, 06:00 PM   #2
Dmurray06's Avatar
Posts: 2,591   (View Stats)
Groans: 122
Groaned at 49 Times in 15 Posts
Normal
2010 Mazdaspeed 3 Black Mica w/ Tech Package
Insalled: Corksport SRI/TIP // Cobb AccessPort// Autotech Internals // Corksport LED Kit // Corksport Stubby Antenna // Forge v2 BPV // JBR SSP// JBR 80a RMM // JBR Weighted Shift Knob // ETS TMIC // Corksport Catless Downpipe // Corksport RacePipe // Denso itv22 // Stratified Guardian Angel // block8head Defrost Pod // Prosport Boost Gauge // Zoom Boom Box
Awaiting Install: HTP 3" TIP // HTP Battery Tray // Sure 3" MAF // Stratified Boost Dial
Dmurray06 is online now   Reply With Quote
The Following User Says Thank You to Dmurray06 For This Useful Post:
MazdaBoy2.3 (10-11-2012)
 Old 10-11-2012, 06:02 PM   #3
Keko's Avatar
Posts: 1,338   (View Stats)
Groans: 97
The engine doesn't use any fuel when you are engine braking, so yeah, not a problem.
2012 MS3
Stratified 91
Aeroforce Interceptor | Pennzoil Plat 10W-30 | FoMoCo XT-M5-QS
15% Tint
The Following User Says Thank You to Keko For This Useful Post:
 Old 10-11-2012, 06:07 PM   #4
Thanks guys. I Appreciate it.
2010 Black Mica
JBR: SSP & Bushings
SURE: Boost Tubes
COBB: Accessport
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
Dmurray06 (10-11-2012)
 Old 10-11-2012, 06:08 PM   #5
easy's Avatar
Posts: 502   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
you will see your AFR go up to 29+
oh and brakes are cheaper than engine ...
but i guess if your doing it to prepare for a corner .. that's understandable
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, Autolite XP5263
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Enkei GF1/Ferderal RS-R, Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms, ATE Super Blue Brake Fluid
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 10-11-2012, 06:17 PM   #6
I Definately don't do this that often. Was just using this as an example.
Thanks again!
Matt
2010 Black Mica
JBR: SSP & Bushings
SURE: Boost Tubes
COBB: Accessport
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-02-2012 11:12 PM
Fuel PSI dropping during WOT frodaddyweez MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 71 05-11-2012 02:56 PM
Fuel Pressure dropping during WOT My FIX crazyp MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 03-26-2012 06:05 PM
Fuel Pressure still dropping shnouz MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 8 03-23-2012 05:39 PM
Dropping fuel pres. but AFRs ok?? ElBartoRex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 01-28-2010 07:40 AM
Page generated in 0.28989 seconds with 23 queries
