-   2010 MS3 - ECU Computer Tuning (http://www.mazdaspeedforums.org/forum/f426/)
-   -   Maf cal log with safe mode map (http://www.mazdaspeedforums.org/forum/f426/maf-cal-log-safe-mode-map-128662/)
JDMJOSH 10-28-2012 03:12 PM
Is it still advisable to do a maf cal with a safe mode map? I tried doing a log but am having a hard time getting the mass air g/s over 100. Figured it was the map and maybe I should switch out to a stage 1 93 octane?
ms3blackmica 10-29-2012 12:57 AM
Your MAF calibration isn't going to change because of the "type" or "version" map you run, only with changes to hardware on the intake side.
Have you done a MAF cal on a differerent map? If so, just copy and paste it into the safe mode map.
If not, just do it on the safe mode map.
Page generated in 0.16209 seconds with 11 queries
