-   2010 MS3 - ECU Computer Tuning (http://www.mazdaspeedforums.org/forum/f426/)
-   -   maf cal logs look weird (http://www.mazdaspeedforums.org/forum/f426/maf-cal-logs-look-weird-103594/)
vrspeed10 01-29-2012 06:30 PM
3 Attachment(s)
[ATTACH][ATTACH]Attachment 50932[/ATTACH][/ATTACH]
ok did my three log to cal my maf but they dont look right. should my maf g/s be higher? i did a 2000k to 6500k in second gear slow roll into the throttle and didnt go into boost.. or are the logs fine?
rghispanic88 01-29-2012 06:37 PM
ok did my three log to cal my maf but they dont look right. should my maf g/s be higher? i did a 2000k to 6500k slow roll into the throttle and did go into boost.. or are the logs fine?
where's the rest of the logging parameter. i.e. throttle position, boost ?
the maf cal is done from 2 gear 1500rpm
0-130gs
slowly accelerate up to 130gs then let off, let the car idle for a few seconds and hit the gas up to 30gs and stop the log.
you defenitely need a maf calc
vrspeed10 01-29-2012 07:50 PM
I got rid of the other parameter to make it easier to read since you don't need than. Second gear pull from 2k to 6500k. Should I have given it more throttle. My maf g/s didn't ever hit 100.
Sid3wayS 01-29-2012 08:02 PM
First u need to start at a lower rpm and make sure your reading 3g's when u start, your log starts at like 11 and is missing an entire bracket. Also its a bit tricky at first but yeah you need to give it more gas basically.
vrspeed10 01-29-2012 08:53 PM
Will take some better logs tomorrow. so basically giving it just enough gas but not building any boost.
Sid3wayS 01-29-2012 09:28 PM
Best way I think to do it is start from a dead stop in 2nd and get to the point where u are rolling without holding the clutch or giving gas. Look a gs on yor ap n u should be at 3/4gs. Hit the log button wait like 1.5 sec. Then start rolling on the gas more n more till u pass 100gs, if you still have gear left take it till you run out. Lift your foot, coast a bit, give it a quick blip and end the log. Truthfully I never realize if Im in boost or not because its irrelevent. Your tryn to take readings of the gs gradually growing.
rghispanic88 01-29-2012 10:05 PM
i guess. 1500rmp works fine
vrspeed10 01-30-2012 02:45 PM
4 Attachment(s)
Attachment 50973
Attachment 50974
Attachment 50975
Attachment 50976
got some more logs. some are a little bumpy but 4 and 7 are not bad let me know what you think.
vrspeed10 01-30-2012 08:48 PM
Bump
SFWD 1934 01-30-2012 09:58 PM
Number 4 is the only one I would use to base any changes off of. You are basically right on the edge of the +/-8% window that COBB suggests. Most guys try and shoot for +/-4%. It shows you are pulling a little over 7% of fuel out. You will want to go in and alter those MAF voltages accordingly. then just flash and giver her some key cycles and city driving and monitor the LTFTs and see where they settle down to.
Jason
vrspeed10 02-04-2012 09:42 PM
Jason
thanks for the help but ran into a problem i think.. when i redid all my calcs in atr and under abilors tuning guide it tells you to copy maf table a and paste into maf table b. well in my atr there is no maf table b... do i just flash it anyway or is there a feature i need to turn on?
HARPER306 02-04-2012 09:53 PM
you should have at least 3 logs that have close to the same info to base your adjustments off of. if you just change stuff based on one log, there still variables that can make it so your adjustments arent that good. get 3 with similar readings then go from there (if that makes sense)
vrspeed10 02-04-2012 11:07 PM
So how do you do that. Since its one number you need to make the adjustments. What are you looking for in the three logs and which one do you use than??
HARPER306 02-05-2012 01:16 AM
maf g/s, rpm, ltft
get 3 logs that all look similar (ie; doing the logs the same throttle/speed/rpm all that shit 3 times) and it will make your changes a lot easier
:alcoholic::alcoholic:
vrspeed10 02-05-2012 07:27 AM
still need help with this. need to reflash my car. when i redid all my calcs in atr and under abilors tuning guide it tells you to copy maf table a and paste into maf table b. well in my atr there is no maf table b... do i just flash it anyway or is there a feature i need to turn on? maybe @rfinkle2 or @Bucker
Bucker 02-05-2012 07:50 AM
2010+ has no MAF table B, so ignore that step.
Page generated in 0.18189 seconds with 11 queries
