> 2010 MS3 - ECU Computer Tuning
  • 1 Post By SFWD 1934
 Old 11-23-2011, 10:57 AM   #1
neofandango's Avatar
Posts: 124   (View Stats)
neofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond repute
Groaned at 16 Times in 5 Posts
Default New Data Logs
Crazy that the 7th Log shows over 400 hp. Has to be a fluke but not sure why lol. If someone could take a look and let me know what they think. HP seems a bit low but I have a OTS tune.
2010 Graphite Mica Mazda 3 5door (no Mods)
Liquid Silver 2011 Mazdaspeed3 GT
Installed
Cobb Accessport, DIZZY Ap Tune, Corksport SRI/TIP, Corksport Racepipe, Forge V1 BPV,
CPE 75 Duro RMM, Autotech HPFP, Denso Spark Plugs ITV22, Armor Mud Flaps, 10" Kicker Subwoofer, Tinted (+5hp)
309whp 380tq
neofandango is offline   Reply With Quote
 Old 11-23-2011, 03:42 PM   #2
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
You can command a leaner AFR. Somewhere in the 11.6-11.8 range. Look at your load for the gear you are using (well any for that matter) and make changes. The power/torque should alter accordingly if you allow more load. Also you VSS says it is reaching approximately 80 MPH. But your VD says gear 4. That is why it would show a higher HP/TQ reading. There are a bunch of other things that can be altered over the OTS settings to make the desired HP/TQ for the modifications installed.
On a side note, you can go through and turn off the following so they are not in the log:
Columns:
G
H
J
K
Q
V
W
Jason
neofandango likes this.
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
 Old 11-23-2011, 04:38 PM   #3
Columns:
G
H
J
K
Q
V
W
Jason
Thanks Im a bit new to tuning. I have some help and was not sure what to have loged and what not to so that helps a ton!
Installed
309whp 380tq
My first data logs Speedin 2010 MS3 - ECU Computer Tuning 4 10-16-2011 04:52 PM
First Data Logs booostin MazdaSpeed 3/6 - ECU Computer Tuning 0 10-15-2011 01:26 PM
WTF IS UP WITH MY DATA LOGS Fatguy729 MazdaSpeed 3/6 - ECU Computer Tuning 14 05-27-2011 02:46 PM
Three Data Logs ATAZ MazdaSpeed 3/6 - ECU Computer Tuning 1 01-02-2010 02:46 PM
how do my data logs look ? jracer MazdaSpeed 3/6 - ECU Computer Tuning 10 01-01-2010 04:38 PM
Page generated in 0.33980 seconds with 22 queries
