> 2010 MS3 - ECU Computer Tuning
  • 1 Post By Lex
 Old 02-03-2013, 11:24 PM   #1
Speedster07's Avatar
Posts: 11   (View Stats)
Speedster07 can only hope to improve
Groaned at 13 Times in 5 Posts
Default Open source tune?
Does the speed3 have open source tuning? Im just wondering since i dont really know how to use the cobb ap, I bought a few mods for my 2013 speed3. I got ATP turbo inlet pipe and ATP intake and ATP downpipe and Cobb intercooler. Does anyone on here do email tunes or anything like that or is the only way to tune a speed thought a access port such as the cobb ap? Thanks.
Speedster07 is offline
The Following 4 Users Say NO Thank You to Speedster07 For This Un-useful Post:
alphasaur (02-04-2013), ASHMS3 (02-04-2013), boostdmazda3 (02-04-2013), Dream20b (02-16-2013)
 Old 02-03-2013, 11:31 PM   #2
jbmazda6's Avatar
Posts: 1,227   (View Stats)
jbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the world
First off, get an AP before you install all those mods. I also suggest getting fuel pump internals before you install that downpipe. There are e-tuners on this site that use the cobb ap to tune (only way to tune besides the hypertech in the US), just look around under all the forums.
Donate to get access to more stuff <-- recommended, just do it and don't argue.
JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray
Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers
Sponsored By: JamesBaroneRacing.com
jbmazda6 is offline
 Old 02-03-2013, 11:40 PM   #3
dgus429's Avatar
Posts: 189   (View Stats)
dgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond repute
Please do yourself and your car a favor and do a little research before installing all of the parts you mentioned, and don't say you did because internals would be mentioned in your original post if you did. Happy reading!
dgus429 is offline
 Old 02-03-2013, 11:46 PM   #4
What do you mean internals? You mean geting a stronger fuel pump? Sorry Im new to this speed stuff. Im tryn to learn.. where is a good starting point to start learning about tuning ? Why does the downpipe require all of that?
The Following User Says NO Thank You to Speedster07 For This Un-useful Post:
 Old 02-03-2013, 11:47 PM   #5
Spec's Avatar
Posts: 4,472   (View Stats)
A good place to start would be to read the stickies. Then read them again. After that look for the stickies and read those.
Spec is offline
 Old 02-03-2013, 11:56 PM   #6
No seriously. Where can I read about tuneing. I cant find anything about it.
The Following User Says Thank You to Speedster07 For This Useful Post:
ASHMS3 (02-04-2013), boostdmazda3 (02-04-2013), Dream20b (02-16-2013), exentix (02-04-2013)
 Old 02-04-2013, 12:02 AM   #7
cshunter's Avatar
Posts: 1,311   (View Stats)
cshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the world
Groans: 28
Cough...
2013 CWP That's slow
2012 LSM Totaled by an asshole red light runner
Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )
Previous: MILTUNED E85 K04
cshunter is offline
The Following 3 Users Say Thank You to cshunter For This Useful Post:
ASHMS3 (02-04-2013), Dream20b (02-16-2013), Mizzle (02-04-2013)
 Old 02-04-2013, 12:02 AM   #8
btstarcher's Avatar
Posts: 4,850   (View Stats)
Groans: 112
You should have received a welcome message with links. Read those.
SnailTune in progress
btstarcher is offline
sidekick (02-04-2013)
 Old 02-04-2013, 12:13 AM   #9
reko's Avatar
Posts: 26   (View Stats)
reko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of light
Subscriebd
received a msg about reading the stickies
didnt
now asks what a cdhpfp is.
Jeez.
reko is offline
 Old 02-04-2013, 12:14 AM   #10
But what do you need to do before installing a dp?
The Following 3 Users Say NO Thank You to Speedster07 For This Un-useful Post:
alphasaur (02-04-2013), boostdmazda3 (02-04-2013), exentix (02-04-2013)
 Old 02-04-2013, 12:21 AM   #11
btstarcher's Avatar
Groans: 112
Have you read the stickies yet?
 Old 02-04-2013, 12:38 AM   #12
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
We're being too nice.
Mizzle is offline
The Following 4 Users Say Thank You to Mizzle For This Useful Post:
dantes5823 (02-04-2013), phate (02-04-2013), rfinkle2 (02-04-2013), sidekick (02-04-2013)
 Old 02-04-2013, 12:41 AM   #13
exentix's Avatar
Posts: 1,568   (View Stats)
exentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the world
Groans: 46
Groaned at 15 Times in 6 Posts
Face palm... There's a whole freaking section titled ecu tuning... That MIGHT be a good start... Oh and the stickies... @Raider; plz help him
exentix is offline
The Following User Says Thank You to exentix For This Useful Post:
 Old 02-04-2013, 12:45 AM   #14
supertubesocks's Avatar
Posts: 404   (View Stats)
supertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the world
To far gone for help, or troll. Either way, banhammer!
Sent from my PC36100 using Tapatalk 2
supertubesocks is offline
The Following User Says Thank You to supertubesocks For This Useful Post:
 Old 02-04-2013, 12:45 AM   #15
jbmazda6's Avatar
Please just start reading...
Here's a link about tuning, hopefully this gets you in the right direction: MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning - Mazdaspeed Forums
Please don't be a troll......
jbmazda6 is offline
The Following 2 Users Say Thank You to jbmazda6 For This Useful Post:
dgus429 (02-04-2013), sidekick (02-04-2013)
 Old 02-04-2013, 05:56 PM   #16
Is there some one on this website that makes the tune depending on your mods and year of the car? Like a e tune. Do you guys have anyone to recommend me to?
caesura (02-04-2013)
 Old 02-04-2013, 06:08 PM   #17
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Yes, lots of us do. On the Forum home page, scroll down. There are several providers of etunes including Perm, Richtunes, Dizzy, Stratified, Etc.
403whp/451ft/lb Dry Shot
Bucker is offline
 Old 02-04-2013, 06:43 PM   #18
Posts: 12,651   (View Stats)
There is another option for the Gen1 cars and that is VersaTuner.
Bucker likes this.
Lex is offline
Bucker (02-04-2013)
Open Source Tuning for my car TWOptSL0W MazdaSpeed 3/6 - ECU Computer Tuning 4 12-05-2012 07:47 PM
Ford and Bug Labs partner on open-source in-car platform Haltech Automotive News 0 09-14-2011 06:10 AM
Geneva Preview: EDAG open-source Light Car Haltech Automotive News 0 01-20-2009 03:40 PM
BMW wants to help develop open-source in-vehicle platform Haltech Automotive News 0 10-24-2008 04:10 PM
Google Android open-source OS could come to cars Haltech Automotive News 0 09-25-2008 06:40 AM
Page generated in 0.38272 seconds with 32 queries
