> 2010 MS3 - ECU Computer Tuning
Like Tree25Likes
 Old 09-13-2011, 06:59 AM   #1
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Default Post-spool lean condition
Please help. Wacky AFRs
The above is my example of this issue I would like to have addressed. I have a lean spot post-spool up that cannot be influenced by the ATR maps. It is consistently a 13.44 AFR that my car hits for .5 second +- a little bit. I currently target 12.4 AFR, so that is a fairly large disparity.
In an attempt to remedy this, I did try several things with no positive results.
Electronically I altered the MAF curve in the affected area which did nothing to cure it. I also ensured all of my fuel tables were targeting the proper AFR, which they are. My LTFT learning zones max at 150 g/s, and my OL/CL transition happens at 1.25 Load. The shifting tables also seemed to have no effect on this condition.
I also physically inspected and cleaned the MAF and just replaced the MAP with a 3 BAR sensor as well as ensuring every hose clamp is properly tightened and is not leaking.
At this point, it is not necessarily a safety issue, but it is a concern to me. I want to have a spot on AFR curve and to be able to provide one for those that I have helped on their tuning adventures. As of now, I cannot provide this. Please help!
@djuosnteisn @Dano @Cobb Tuning @Calvin@COBB @Jaron@COBB @David@COBB
403whp/451ft/lb Dry Shot
The Following 4 Users Say Thank You to Bucker For This Useful Post:
atvfreek (09-15-2011), Dano (09-14-2011), djuosnteisn (09-13-2011), phate (09-15-2011)
 Old 09-13-2011, 01:05 PM   #2
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
I've seen it many times before, and have yet to find a solution. It's not on every car, but only a few. My guess is there's even more fueling tables to be discovered.
Good thread. I have some logs and maps i can post up to help show the issue if needed.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
atvfreek (05-01-2012), Bucker (09-13-2011), Dano (09-14-2011), phate (09-15-2011)
 Old 09-13-2011, 01:09 PM   #3
Blue 2 shims
Nazarite's Avatar
Posts: 2,254   (View Stats)
Nazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the worldNazarite is the leader of the world
Groans: 66
Groaned at 30 Times in 19 Posts
@Bucker keep trying. This is only your 789th thread about your fail tuning. We get it. You're a fail tuner.
JK. I love you.
Bucker likes this.
I used to drive a MazdaSPED 3. It was retarded fast.
Nazarite is offline   Reply With Quote
The Following 5 Users Say Thank You to Nazarite For This Useful Post:
Bucker (09-13-2011), Chriscote (09-15-2011), Dano (09-14-2011), phate (09-14-2011), Roddiy (11-15-2013)
 Old 09-13-2011, 01:17 PM   #4
Lytheum's Avatar
Posts: 187   (View Stats)
Lytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the world
had the same issue....maf curve did nothing. wasnt getting any knock either, but i just lowered my target afr from 2500-3500. pretty must just a band aid and it keeps the spike under 12 afr vs 12.5
Bucker likes this.
2008.5 MGM MS3
Cobb SRI, Cobb TIP, CP-E FMIC, Cobb Downpipe, CP-E HPFP, TRZ trans & RMM
Cobb AP, Forge BPV, Solid shifter bushings
Lytheum is offline   Reply With Quote
The Following 3 Users Say Thank You to Lytheum For This Useful Post:
Bucker (09-13-2011), djuosnteisn (09-14-2011), phate (09-15-2011)
 Old 09-14-2011, 06:39 PM   #5
Bucker's Avatar
Groans: 451
As more supporting information, here are 2 logs I just took. 13.44 AFR is the peak, then it makes its way back to targets.
The Following 3 Users Say Thank You to Bucker For This Useful Post:
atvfreek (05-01-2012), djuosnteisn (09-14-2011), phate (09-15-2011)
 Old 09-14-2011, 06:59 PM   #6
robry's Avatar
Posts: 862   (View Stats)
robry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the world
Groans: 27
Groaned at 9 Times in 7 Posts
virtual dyno chart
datalog1 = red
datalog2 = blue
virtual dyno correction factor = 0
smoothing factor = 6
File Type: jpg bucker-dynos-datalog1red-datalog2blue.jpg (152.0 KB, 1001 views)
Bucker likes this.
2014 Mustang GT Premium 6MT - GT Track Pack/Leather Recaros/Glass roof in Sterling Grey Metallic | Barton SS/2 Post | J&M LCA | Steeda Street UCA | JBA 3" O/R X | GT500 ABs | JLT plastic CAI | SCT xcal with AED HP custom tune
SOLD2011 Mazdaspeed3 Celestial Blue Mica
robry is offline   Reply With Quote
The Following 3 Users Say Thank You to robry For This Useful Post:
Bucker (09-14-2011), djuosnteisn (09-14-2011), phate (09-15-2011)
 Old 09-14-2011, 07:07 PM   #7
Bucker's Avatar
Groans: 451
Lol, @phate
Proves my point about the AFR's though.
The Following User Says Thank You to Bucker For This Useful Post:
phate (09-15-2011)
 Old 09-14-2011, 07:53 PM   #8
Posts: 9,484   (View Stats)
i've seen some lean shift but no where near that bad and it is typically IN the spool range.
that looks like some old skool CL exit hang shit.
BTW mention isn't notifying me...guess I need to turn that on in user CP.
dougefresh_ (09-19-2011), phate (09-15-2011)
 Old 09-14-2011, 08:20 PM   #9
m4tic's Avatar
Posts: 4,922   (View Stats)
i just posted about this in the BT 101 thread
Originally Posted by bmorrisj View Post
ok what was the trick to have AFR drop a little faster.. im targeting ~12.1 - 12.2 ... when i hit it (you know 3rd gear around 3k) my AFRs hang around 13.3~13.5 but after a shift it hangs on normally.... but damn i see 2.4 calc load on there!
skeeter149 and Bucker like this.
2007 MS6 w/ Cheez
The Following 4 Users Say Thank You to m4tic For This Useful Post:
Bucker (09-14-2011), djuosnteisn (09-14-2011), phate (09-15-2011), skeeter149 (09-16-2011)
 Old 09-14-2011, 08:35 PM   #10
Bucker's Avatar
Groans: 451
Sucks to see that I am not the only one... 13.44 is not a health WOT and peak load AFR... meh. Hopefully @Cobb Tuning can do something about it.
phate (09-15-2011)
 Old 09-14-2011, 09:13 PM   #11
What do your CL Max throttle tbls look like.?
Tappin
phate (09-15-2011)
 Old 09-14-2011, 09:15 PM   #12
Captain
Groans: 79
I've tried CL exit delays of 0 and 1, 40, and 80, and 100..... and i even think 150. None made any difference. I've tried CL throttles of 50, 70, and 100.... and i've tried various loads. Again, not many did much.
I think i suggested that Bucker try lowering the max CL break points to 150 (all of the max values), instead of the normal 200.... and i don't think this helped either.
I don't think its a sensor issue either... just some yet-to-be-known logic in the ecu.
www.permtuning.com
Bucker (09-15-2011), Dano (09-15-2011), phate (09-15-2011)
 Old 09-15-2011, 05:37 AM   #13
Bucker's Avatar
Groans: 451
I actually use all of the LTFT break points and the highest is at 150. All CL max throttles are 100, CL max load is 1.10, CL exit delays are 10/20/20.
@Dano
The Following 2 Users Say Thank You to Bucker For This Useful Post:
 Old 09-15-2011, 06:52 AM   #14
you are running E correct? Did it do this on petrol? The cars I am seeing only lean up from say 11.8 to 12.2 maybe 12.4 for only one or two cells and are on 91-93. Perhaps the E is magnifying the leanness due to the different stoich ratio and this is a clue as to what the ECU is targeting.
Fobio (09-15-2011), phate (09-15-2011)
 Old 09-15-2011, 07:56 AM   #15
Bucker's Avatar
Groans: 451
Yeah, I have an e85 mix and that's definitely possible. It did NOT do this until about 2 weeks ago when my ECU got bricked and then reset by Cobb to "factory".
EDIT:
The only other change that happened was the ATR update from the BETA ATR we were using.
phate (09-15-2011)
 Old 09-15-2011, 08:24 AM   #16
Man, ask Cobb about the possibility of my ECU theory being possible. That dealer flashes can alter the logic enough to cause this and now you have an "ass shipped" ECU and not one that has been dealer updated.
IDK how Cobb restores the ECUs but this could be a possibility.
Bucker likes this.
phate (09-15-2011)
 Old 09-15-2011, 08:32 AM   #17
Eth Fiend
phate's Avatar
Posts: 6,846   (View Stats)
Bucker, have you tried a different MAF sensor?
-06 MS6
-Corn fed 07 MS3 - Sold
rfinkle2 (09-16-2011)
 Old 09-15-2011, 08:43 AM   #18
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
@Bucker
You very friendly with any local dealers? It would be very interesting to see if you could get the dealer to flash the lastest and greatest FW they have, load up the same map you are having problems with and see what the result is.
I know that back when I first got the AP, I started out by loading up the "stock" installed, so basically the lastest "stock" flash that Cobb had at the time. I noticed immediately that the car was running a little different that what it was doing before on the truly stock tune. I also know that the previous owner had been to the dealer for updated ECU flashes at least once before I bought it....
@Dano there are quite a few instances that I can think of that support your dealer flash theory.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following 3 Users Say Thank You to BigjohnB20 For This Useful Post:
 Old 09-15-2011, 09:17 AM   #19
indeed...I can think of about 5 over the years that support it.
different load caps for different year/flashed ECUs for example.
different CL exit hangs on cars post shift
different lean condition after FFS shifts
the list goes on and it was always dismissed as "oh different setups are different" which is true to a point but I think the dealer flashes could very well have at least some effect on the above situations.
phate (09-15-2011)
 Old 09-15-2011, 10:15 AM   #20
Bucker's Avatar
Groans: 451
Nope. I really don't think its sensor related though, but I did clean my MAF for the hell of it. No change.
@Bucker
not very friendly, but I want to try and get it in there for that... No idea when I can make it happen though.
Last edited by Bucker; 09-15-2011 at 10:15 AM. Reason: MSF Database - Automerged Doublepost
phate (09-15-2011)
 Old 09-15-2011, 10:22 AM   #21
2zz mr-s
dooderek's Avatar
Posts: 5,114   (View Stats)
Groans: 239
rebrick the ecu
Bucker likes this.
The Following User Says Thank You to dooderek For This Useful Post:
phate (09-15-2011)
 Old 09-15-2011, 10:24 AM   #22
Posts: 12,649   (View Stats)
Before you get too wrapped up about this, log inj PW. This can give you a good idea of how the ECU commands fueling.
Remember there is a lag between inj PW and AFR being read by the O2.
Dano (09-15-2011), djuosnteisn (09-15-2011), kmac (09-15-2011), phate (09-15-2011)
 Old 09-15-2011, 11:43 AM   #23
kmac's Avatar
Posts: 1,792   (View Stats)
Why don't u try monitoring Long term and short term fuel trims as well, if your car is in open loop they should zero out, if they r correcting then It's still in closed loop and hopefully that will lead u in the right direction.
The Following User Says Thank You to kmac For This Useful Post:
phate (09-15-2011)
 Old 09-15-2011, 11:45 AM   #24
Eth Fiend
phate's Avatar
You are probably correct it is not sensor related, but swapping it out with a known good piece will eliminate one more variable
-06 MS6
kmac (09-15-2011)
 Old 09-15-2011, 11:53 AM   #25
Bucker's Avatar
Groans: 451
Attached. Doesn't seem too crazy although the spike was not as severe this time.
phate (09-15-2011)
 Old 09-15-2011, 11:55 AM   #26
Bucker's Avatar
Groans: 451
It is in OL. I have LTLFTs in all of my logs, and the hit 0 right around where they should.
Good point. I dont have any other speeds that are local and active on here though.
Last edited by Bucker; 09-15-2011 at 11:55 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-15-2011, 11:55 AM   #27
he has his LTFT breakpoint set to 150 g/s so it will trim in OL to a point. But to be that lean seems to be something else...he would have to go in to OL with a +8% LTFT IIRC target of 12.4 13.5\12.4 = 1.08
interesting thing though in the logs his LTFT is zero from 32 g/s all the way up ...I doubt very seriously his MAF is THAT dialed in. hum...
What does that point to?? ECU is the only hardware that was changed but then he flashed with his old map.
@Bucker
did you ever rebuild your map from a new base map. moving maps forward through all the changes and cobb revisions can def corrupt it. I have seen it first hand with my maps.
 Old 09-15-2011, 12:03 PM   #28
Bucker's Avatar
Groans: 451
@Bucker
Yessir, I sure did after you (I think) suggested it before. Sadly, there was no happy result .
 Old 09-15-2011, 12:08 PM   #29
haha yes I suggested it...
so the facts in evidence:
car was fueling correctly at ~12.4 on the same E mix
Then flash went bad and ECU was bricked
Cobb worked magic on same ECU and sent it back
now car starts to fuel correctly then gives up.
well then I am firmly planted in the ECU is the difference camp and back to my "dealer flash" theory.
unless you developed a leak pre turbo and as airflow increases you get leaner.
When you removed the ECU did you thrash your TIP or intake in disgust? or perhaps pull the vacuum port from your BC out of the TIP?
Bucker likes this.
 Old 09-15-2011, 12:20 PM   #30
Bucker's Avatar
Groans: 451
Haha absolutely not. Since this started I have pulled the TIP, Intake, TMIC, Throttlebody, etc. No change. Ill try to get to my dealer next week, but it isnt likely to happen.
phate (09-15-2011)
 Old 09-15-2011, 12:27 PM   #31
Eth Fiend
phate's Avatar
Can I put my bid in for MAF sensor/calibration issue?
-06 MS6
 Old 09-15-2011, 12:29 PM   #32
Captain
Groans: 79
You can.... but if his issue is the same i saw, it doesn't helped. I intentionally recal'd the maf so that the fuel trims were pulling like 5% before switching to OL, and nada.
www.permtuning.com
phate (09-15-2011)
 Old 09-15-2011, 12:35 PM   #33
Eth Fiend
phate's Avatar
The airflow in that region looks a little turbulent, and I'm only looking at one log, but the airflow is slightly lower than what I think it should look like. But where it goes turbulent is where you have AFR variation (both lean and rich).
Looking at one log is not conclusive, by any means, but it is suspect.
PS - I still agree the ecu does funny things, we've all seen it, and I could be wrong here
-06 MS6
Last edited by phate; 09-15-2011 at 12:38 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-15-2011, 12:36 PM   #34
working on a tune now where I have added 6% to the maf and the AF hasn't changed one bit...still remains at 12.2 and I am commanding 11.9. it just won't budge but it is only for 1 second then it falls to target...this is in the spool range 3.7-4.0 vt on a KO4 car.
it was 2% lean so I added 2% = no change
I added another 2% same VT range = no change
added another 2% = nadda
clutch/in out tables to 1.0 = nadda
I gave up since it isn't that bad but bucker needs to do something with those 13.5s and so does bmorris.
edit: I wish I knew WHAT they needed to do LOL
djuosnteisn (09-15-2011), phate (09-15-2011)
 Old 09-15-2011, 12:43 PM   #35
m4tic's Avatar
in my case how would you explain my afrs going back to normal after shifting?
Sent from my iPhone using Tapafawk
2007 MS6 w/ Cheez
The Following User Says Thank You to m4tic For This Useful Post:
phate (09-15-2011)
 Old 09-15-2011, 12:52 PM   #36
Bucker's Avatar
Groans: 451
Like @Dano said, I have thrown up to 10% correction on the MAF table with no impact at all in that range.
Dano (09-15-2011), djuosnteisn (09-15-2011), phate (09-15-2011)
 Old 09-15-2011, 12:56 PM   #37
Eth Fiend
phate's Avatar
And it always goes to 13.44, or it just goes lean, in general?
If this is the case, we are effectively saying there is not just a fueling table we don't have access to, but there is a MAF table/MAF modifier/MAF something which we don't have access to...
Edit: I'm a little slow today...maybe this is what you guys were thinking, anway?
-06 MS6
 Old 09-15-2011, 01:20 PM   #38
Bucker's Avatar
Groans: 451
Yes lol, you are with us now It goes lean in general, but 13.44 is right about the point it peaks at then it settles right back to target. Its bananas. Good think I am sticking with the eth mix, I think, lol.
 Old 09-15-2011, 01:23 PM   #39
m4tic's Avatar
or 13.4 is fine and we're pansies with our 12.4 targets
Bucker likes this.
2007 MS6 w/ Cheez
 Old 09-15-2011, 01:25 PM   #40
Bucker's Avatar
Groans: 451
Honestly, I believe that it is but I don't think there are any gains to really be made by running at that AFR. I would think it would increase BATs unnecessarily. As far as your stuff is concerned, it looks like it is stuck in closed loop. Have you tried to adjust the shifting tables at all yet? Also, what is your final LTFT break point at?
phate (09-15-2011)
GT35r Spool jhershorin MazdaSpeed 3/6 - Turbo Induction 25 02-21-2013 06:13 PM
Dealers got lean; many plan to stay lean Haltech Automotive News 0 05-30-2010 09:10 PM
lean condition under boost Super Unique Mazdaspeed3/6 General Discussion 13 06-15-2008 10:02 PM
Page generated in 0.84644 seconds with 32 queries
