> 2010 MS3 - ECU Computer Tuning
Like Tree25Likes
 Old 02-21-2012, 03:21 PM   #201
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
I am a fan of the clutch in/out tables.
Jason
DarkPasseng3r likes this.
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
 Old 02-23-2012, 05:52 AM   #202
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Originally Posted by RichieRichness View Post
Did it only happen on your first logs? I'm thinking it has something to do with the engine not being up to temp or the o2 sensor needs to be a certain temp
I wanted to follow up on this. I've noticed that these lean spike are only happening when ECT is below 180*F....I feel like i'm on to something but thats all I have for now.
Maybe there are ECT fueling comp tables that need to be uncovered?
@Captain KR
 Old 02-23-2012, 06:35 AM   #203
Posts: 9,484   (View Stats)
interesting....more data needed but unfortunately no one logs ECT lol. If you are having the issue its time to add that to the list.
 Old 02-23-2012, 07:39 AM   #204
Groans: 35
@Bucker can you please start logging ECT and let me know if your seeing the same thing.
 Old 02-23-2012, 08:29 AM   #205
Eth Fiend
phate's Avatar
Posts: 6,849   (View Stats)
ECT should really be logged in order to ensure consistency. A cool engine will almost always produce more power, and may prevent knock.
In terms of fueling, cars typically run richer as the ECT cold start enrichment increases as coolant temp gets colder (due to poor atomization of fuel when cold). The DI engines don't seem to be affected by this, quite as much with gas [but with full E85 they do!!!].
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 04-13-2012, 01:47 PM   #206
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
So I am now getting this on a gen 1 I am tuning (08 ecu with 2011 motor). His maf is caled (even tried adding more fuel in the spot)
As the turbo spools and at max boost, it will run an afr in the mid 12's, and then drop down to my commanded of 11.83 and hold that the rest of the way, even post shift he has no afr issues.
So, what was the final verdict on fixing this?
 Old 05-01-2012, 11:27 AM   #207
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
@G26 is this with regular pump or e85? @atvfreek and I are also having this same problem.
I also have an 08. Afr's were fine on pump, now this is happening once we threw in a couple gallons of e85.
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
The Following User Says Thank You to ckMS3 For This Useful Post:
atvfreek (05-01-2012)
 Old 05-01-2012, 11:41 AM   #208
G26
G26's Avatar
Groans: 39
This is/was happening on straight 93 oct, and it wasn't every log either.
The Following 2 Users Say Thank You to G26 For This Useful Post:
atvfreek (05-01-2012), ckMS3 (05-01-2012)
 Old 05-01-2012, 11:49 AM   #209
atvfreek's Avatar
Posts: 7,784   (View Stats)
This has only happened on @ckMS3's car with e85, it was perfect with 93.
@Bucker did you figure out what your issue ended up being. There is still a couple things I want to try, but we've changed CL transitions, breakpoints and tried scaling the maf with no luck so far.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
ckMS3 (05-01-2012), djuosnteisn (05-01-2012), rfinkle2 (05-01-2012)
 Old 05-01-2012, 12:03 PM   #210
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
I'm 99% sure there are phantom trims at work during what we call "open loop", just not the standard STFT / LTFT we're used to.
Here's two logs from when i was doing some 5th port testing on my ms3. Both logs were taken with the EXACT same tune on the car. I never flashed a map. That tune would put me roughly around high to mid 11's with a regular 3 gal e85 mix and no aux fuel.
Now here's a log (again, on the exact same tune), with 1000 cc/min 5th port injector spraying... and cutting off in the higher rpms (this is before i added a pull down resistor to my trigger line on the box. Aux fueling would suddenly shut off due to a garbled trigger signal). Look at the AFR it leans out to when the aux fueling suddenly shuts off.....
Also note how the AFRs during the aux fueling pull weren't appreciably lower than without it.
Why would the AFR lean out to mid 12's when the aux fueling cut off, when i'm running a tune that hits and holds mid 11's without aux fueling? Unless there are trims at play, which i'm now fairly certain there is.
So, with that all said, i think some of the post spool lean issues can be attributed to the maf cal being slightly lean, and relying on the phantom trim to pull it down. I think that, in conjunction with valve over lap (while pressure in int mani >> pressure in exh mani) passing fresh, unburnt oxygen into the exhaust can explain the whole issue.
atvfreek likes this.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 6 Users Say Thank You to djuosnteisn For This Useful Post:
atvfreek (05-01-2012), Boost_creep (05-01-2012), ckMS3 (05-01-2012), Mistersix (03-14-2013), rfinkle2 (05-01-2012), RichieRichness (05-01-2012)
 Old 05-01-2012, 12:07 PM   #211
ckMS3's Avatar
^ what he said lol. Good info, I love this forum.
The Following 2 Users Say Thank You to ckMS3 For This Useful Post:
atvfreek (05-01-2012), djuosnteisn (05-01-2012)
 Old 05-01-2012, 12:14 PM   #212
atvfreek's Avatar
I definitely have to agree there is some phantom stuff going on. Next step is to go old school and make the whole curve rich and see what happens. Lol
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
djuosnteisn (05-01-2012), RichieRichness (05-01-2012)
 Old 05-01-2012, 12:15 PM   #213
Captain
Groans: 79
You sir... have an email.
www.permtuning.com
atvfreek (05-01-2012), rfinkle2 (05-01-2012)
 Old 05-01-2012, 12:27 PM   #214
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Just to keep this alive, when I spray nitrous I get pretty significantly different AFR readings sometimes. I know bottle pressure, etc. can play a part but if I have been driving the car on a nitrous tune without spraying for awhile then spray I get leaner AFRs that if I have been spraying a lot.
403whp/451ft/lb Dry Shot
The Following 4 Users Say Thank You to Bucker For This Useful Post:
atvfreek (05-01-2012), djuosnteisn (05-01-2012), rfinkle2 (05-01-2012), RichieRichness (05-01-2012)
 Old 05-01-2012, 12:38 PM   #215
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Open loop trimming is almost certainly going on.
I've shifted my curve 10% and still hit wot targets.
The same goes for adding UP TO 2.5 gallons of e85 before shit goes haywire (within the open loop trim threshold?).
The gen1 cars are way more sensitive to whatever phantom trimming is going on than gen2 cars.
side note: I like the word phantom.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (05-01-2012), dantes5823 (02-08-2013), djuosnteisn (05-01-2012), phate (05-01-2012), Twofer (02-19-2013)
 Old 05-01-2012, 01:21 PM   #216
m4tic's Avatar
Posts: 4,922   (View Stats)
i started going through this thread again and was about to post a question and all these new posts were here when I refreshed haha.
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
 Old 05-01-2012, 03:34 PM   #217
G26
G26's Avatar
Groans: 39
I can also adjust my maf curve, and my wot afr is always perfectly dead on commanded. Hopefully this trimming doesn't decide to just do what it wants lol, that could mean bad news.
 Old 05-01-2012, 07:44 PM   #218
Groans: 35
I can confirm this open loop trip delima
3" MAF + Stock TMIC = Win?
The Following 2 Users Say Thank You to RichieRichness For This Useful Post:
atvfreek (05-01-2012), rfinkle2 (05-11-2012)
 Old 02-08-2013, 04:29 AM   #219
Mistersix's Avatar
Posts: 2,585   (View Stats)
Reviving this thread for further info. Was anything else uncovered in regards to post spool lean conditions?
 Old 02-09-2013, 08:40 AM   #220
Mistersix's Avatar
I've uncovered a post spool lean condition in 1st and 2nd gears only. All other gears hit target 11.8 consistently. mid 13's in the first two gears. Currently tightening up the maf cal. Anyone have any other ideas?
 Old 02-12-2013, 11:17 AM   #221
Groans: 35
Try ramping up boost slower. This will reduce the load/shock on your engine and allow your fueling to adjust.
The Following User Says Thank You to RichieRichness For This Useful Post:
Mistersix (02-13-2013)
 Old 02-13-2013, 04:09 AM   #222
Mistersix's Avatar
Via WGDC? I have a TR-8 with 2.5" piping on the K04 so spool is pretty tame already. It does ramp up fast in first and second though.
Or do you mean physically with my throttle input? I was just mashing the throttle in that log as i wanted to see what the loads were.
 Old 02-13-2013, 05:39 AM   #223
Groans: 35
2.5" piping won't really slow the ko4's spool....i'm running the same size
yeah...regulate that shit via wgdc, load targets and/or boost targets. I always target about 16 psi @ 3k rpm and horizontally interpolate down to 500 rpm (when boost tuning). Load tuning is of course a different story.
Mistersix (02-14-2013)
 Old 02-14-2013, 03:09 AM   #224
Mistersix's Avatar
I'm currently load tuning. I developed a boost tune and ran it for the last year and it did well. Made decent numbers on a stingy mustang dyno and dropped my 0-60 to a 4.8 but i wanted to try my hand at load tuning so i started over. This uncovered the lean 1st and second.
My load targets are already pretty conservative in 1st and 2nd from 3k and down. Its worth a shot though.
And for what its worth. My fmic set up definitely effected spool. Granted i only really notice it when i datalog and got WOT at about 2.7k I can feel and see in the log that it takes longer to reach full boost. But when ripping threw gears it feels about the same as the tmic as far as lag goes.
 Old 03-20-2013, 05:01 AM   #225
Mistersix's Avatar
So i tried this and no difference. I'm still trying to figure this out. When i do WOT pull for a datalog afr's hit fine. It does its little lean dance when ever in any gear and just getting on a bit. Even in 6th on the highway. I've been watching it and what happens is as soon as it transitions into open loop it hits targeted for a split second, (11.8) then goes lean by about .8-1.0 then settles back down to targeted.
This has me spooked everytime i get on it, even just a little, like merging. When your getting into the throttle for moderate load and moderate boost but your only in each gear for a second or two the afr's are in the mid 12's because there's no time for them to settle before you shift. 1st and 2nd gear are even worse, going into the 13's!
To avoid damage i'm targeting 11.0 to be safe. Its still does the same thing but it only leans out to 11.8-12 now. VD show the same hp/tq as we know afr doesn't effect output to much.
Does anybody have any insight? The wot log below was the newly flashed 11.0 afr map but doesn't show the lean thing. I'll get one to post today. FWIW, i have pretty much all the bolt ons including a 3bar map sensor, fp internals and all the breather mods.
 Old 03-25-2013, 06:50 AM   #226
Groans: 35
I don't see any lean issues with the log you posted....only lean spot is at low boost/low load before you hit full boost. I would suggest you pull back on boost/load targets at 3k rpm as your hitting 23 psi and that could cause you some ZZB.
Mistersix (03-26-2013)
 Old 08-11-2013, 05:39 PM   #227
Blackrider's Avatar
Posts: 356   (View Stats)
Blackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the world
Groaned at 20 Times in 14 Posts
I started to have this problem out of the blue, its really strange, it doesn't appear to be MAF Cal related. It goes pig rich during spool then leans to about 12.2 - 12.4 for a sort while then comes back to 11.9 where I'm targeting. Its almost like the ECU is being too aggressive trying to lean out the rich condition...
2008 MazdaSpeed 3
Exhaust - Mazdaspeed & Ebay Downpipe
Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC
Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS
Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's
Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM
Random - Pontiac G8 Horns
2013 Ford Edge Sport AWD, the family car...
Blackrider is offline   Reply With Quote
 Old 05-11-2014, 08:50 PM   #228
speed23's Avatar
Posts: 1,469   (View Stats)
Sorry to bump an old thread, but has anyone had any success fixing this recently? I am running across this issue also.
EDIT: I fixed the issue by lowering the closed loop afr targets at loads below the OL transition to the afr that I wanted at open loop.
 Old 05-18-2014, 12:53 PM   #229
Mistersix's Avatar
I've never found a fix for it. I've just live with it. Other car's I've tuned don't seem to have this problem. But mine sure does.
The Following User Says Thank You to Mistersix For This Useful Post:
speed23 (05-18-2014)
 Old 05-18-2014, 01:59 PM   #230
rfinkle2's Avatar
Groans: 298
Drop the CL exit delays to 5 Mistersix and see if that fixes things.
In the longer gears, the ecu has more time to correct, in the short gears, not so much.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Mistersix (10-14-2014), Roddiy (05-19-2014), speed23 (05-18-2014)
 Old 03-31-2016, 07:34 PM   #231
calinflorinalexandru's Avatar
Posts: 90   (View Stats)
calinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud of
Groaned at 32 Times in 15 Posts
@Captain KR
For sure there is a ECT based fueling table which is not yet uncovered. I can tell you this after I had cooling problems due to head lifting and the ECT pegged to 116 *C . You can see in the attached logs that ECU is adding a lot of fuel during overheating. My Lambda target was ~0.82 ( 12.0 AFR).
Silver Mazda 6 MPS /Built Engine/ GramLights 57xtreme 18x8.5 et45 \ Vredestein Ultrac Vorti 225x40R18
calinflorinalexandru is offline   Reply With Quote
 Old 04-03-2016, 05:57 AM   #232
Originally Posted by Bucker View Post
Please help. Wacky AFRs
The above is my example of this issue I would like to have addressed. I have a lean spot post-spool up that cannot be influenced by the ATR maps. It is consistently a 13.44 AFR that my car hits for .5 second +- a little bit. I currently target 12.4 AFR, so that is a fairly large disparity.
In an attempt to remedy this, I did try several things with no positive results.
Electronically I altered the MAF curve in the affected area which did nothing to cure it. I also ensured all of my fuel tables were targeting the proper AFR, which they are. My LTFT learning zones max at 150 g/s, and my OL/CL transition happens at 1.25 Load. The shifting tables also seemed to have no effect on this condition.
I also physically inspected and cleaned the MAF and just replaced the MAP with a 3 BAR sensor as well as ensuring every hose clamp is properly tightened and is not leaking.
At this point, it is not necessarily a safety issue, but it is a concern to me. I want to have a spot on AFR curve and to be able to provide one for those that I have helped on their tuning adventures. As of now, I cannot provide this. Please help!
@djuosnteisn @Dano @Cobb Tuning @Calvin@COBB @Jaron@COBB @David@COBB
I don't wanna continue the dispute started in the "VVT Tuning" thread ,but try to reduce the VVT advance during spool-up and see if the AFRs will lower. If my theory is correct it should alievate the spool/ post-spool AFR leaning
 Old 06-19-2017, 04:32 AM   #233
BuddySpeed3's Avatar
Posts: 412   (View Stats)
BuddySpeed3 has disabled reputation
Groaned at 7 Times in 4 Posts
Sorry for the thread revival but has a solution to this post lean spike been found?
My car is doing the same thing with the bigger turbo. Maf curve adjustments have a small effect on it, but not enough to keep the curve smooth. Fuel tables are good. Exit delays are 10/20/20. Targeting 11.8:1, spikes to 12.3-12.75 afr. Only happens as boost reaches full spool around 3600 rpm to about 4500 rpm and then settles down to target.
I've checked for leaks on the intake and exhaust side. Cleaned Maf sensor, and epoxied threads on intake. Not sure if maybe the VE tables can help
Here's the log:
Post Spool Lean Spike.csv
- 2009 Speed 3 - BNR S4 v2 - HTP 3" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Cpe Tmic - Cnt Catted Tb - Cobb Xle Bpv - Cobb Shift Knob - Autotech Internals - Jbr Boost Tubes - Jbr Occ (Vta setup) - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Unplugged Egr - Koni Yellow Shocks - Eibach Springs - 94 Oct w/ In Tank Methanol (2 Gallons) - SP Stage 1 WMI 50/50 Mix (Strictly Cooling) -
 Old 06-19-2017, 01:47 PM   #234
Mazdaspeed3GT's Avatar
Posts: 79   (View Stats)
Mazdaspeed3GT is a jewel in the roughMazdaspeed3GT is a jewel in the roughMazdaspeed3GT is a jewel in the roughMazdaspeed3GT is a jewel in the rough
Here's the log:
Attachment 232522
Everything I've seen during my tuning has been that it leans during the CL/OL (Low/High) Ign switch.
(Retarded timing compensated with leaner mix?)
What's your Max Load D table values?
CS 3" SRI | CX Racing + TR6 FMIC | CS HPFP | M2 Test Pipe | ClutchMasters FX100
COBB AP | CP-e RMM | Forge V2 | CS Shift Plate + Bushings | E30 Mix
CP-e Triple Gauge Pod | ProSport Evo Boost Gauge & Oil Temp Gauge
Mazdaspeed3GT is offline   Reply With Quote
 Old 06-19-2017, 02:42 PM   #235
speed23's Avatar
Same for me. I had to make sure that before the transition, the open loop afr was already at the value I wanted the closed loop at. That fixed my issue.
 Old 06-19-2017, 06:32 PM   #236
I have all Max Load Tables A-E as follows:
Here's the map I'm trying to dial my AFR on (All my tables are good lookin):
BNR S4 Maf Cal.ptm
I set my Closed Loop Load Limits A-C to the same values in the Max Load Tables A-E to dial in the maf curve with no OL trims, then raise them back up to 2.6 load once AFR is dialed in. This is when I discovered the lean spike with the bnr s4.
I'm not sure if it's a CL/OL transition issue because in my posted log, the car goes into open loop and hits AFR targets well before the lean spike. I floor it at 2300 rpm, it goes into open loop, hits targets, then spikes lean for about 1k rpm when the turbo spools, then settles back down to target.
I don't know what else to change in the map aside from the Maf curve, but even that doesn't seem to work very well. The curve isn't smooth anymore. I don't remember the K04 having this issue (at least for me).
I thought about making the fuel tables more rich in the rpm region it spikes lean in just to smooth out the spike (as many have done), but I'd rather have it work the way it should! lol
I think my map tables look pretty solid, but as many have said before, there might be uncovered fuel tables that we don't have access to. Any insight on this issue?
@Lex; @Bucker; @phate; @Dano; @rfinkle2; @Ziggo; @djuosnteisn;
 Old 06-19-2017, 06:44 PM   #237
Eth Fiend
phate's Avatar
Check "Calc Load Max A/B" in Load Tables folder. Make sure they're all 5.00.
-06 MS6
MD1032 (06-20-2017)
 Old 06-19-2017, 06:47 PM   #238
Ok thank you, I'll giver a shot and report back
 Old 06-20-2017, 07:06 AM   #239
My other thought is it happens when bumping up against the boost limits.
I've seen in some of my other logs if I roll into WOT in higher RPMs in 3rd/4th, and the boost gradually reaches target rather than a small overshoot, I'm not seeing the lean spot.
I can't open your map. Are you boost tuning or load tuning?
Let's take a look at your Boost Limits and Boost Targets tables.
My "Calc Load Max A/B" have always been 5
 Old 06-25-2017, 08:21 PM   #240
Perfect! That fixed it. Here is a log:
Spot on AFR.csv
I had to redo my maf cal from scratch because it was super rich with the old maf curve (9.5:1). Now it hits target perfectly with OL fuel trims disabled. Thanks very much for that, I couldn't have done it without you
Yes setting those "Calc Load Max A/B" tables to 5.00 load across the board fixed it I wasn't sure if it was an air leak, a bad maf sensor, a bad o2 sensor, or a tuning issue. The search has now ended, and I can now drive with piece of mind.
I'm hybrid tuning. Targeting boost, and limiting load. The car feels great.
As you can see in the log I leaned out to 11.8:1 which slightly lowered IDC's. Running 22 psi never felt so good. I'm wondering if I should stay at 22 psi to have fueling headroom in colder ambient temps and use timing to make power, or target a bit more boost.
I'll probably stop around 95% IDC although I know I can make good power at lower boost levels (22 psi) with more timing.
Idk what's harder on ringlands...Timing or boost?
The Following User Says Thank You to BuddySpeed3 For This Useful Post:
phate (06-26-2017)
GT35r Spool jhershorin MazdaSpeed 3/6 - Turbo Induction 25 02-21-2013 06:13 PM
Dealers got lean; many plan to stay lean Haltech Automotive News 0 05-30-2010 09:10 PM
lean condition under boost Super Unique Mazdaspeed3/6 General Discussion 13 06-15-2008 10:02 PM
Page generated in 0.60926 seconds with 37 queries
