-   2010 MS3 - ECU Computer Tuning (http://www.mazdaspeedforums.org/forum/f426/)
-   -   Stage 2, not a big difference? (http://www.mazdaspeedforums.org/forum/f426/stage-2-not-big-difference-101695/)
eb2292 01-09-2012 06:48 AM
Hey guys,
Before I put my fuel pump internals in, I was running Stage1+CS+TIH 93. This was a HUGE increase of power over stock.
This weekend I put the internals in and the first thing I did after a hundred miles or so was flash Stage2+CS+TIH 93. I don't have an upgraded intercooler or DP yet. But I figured I should see a pretty significant increase in power, going from stage 1 to 2. The increase is minimal at best.
Is this how it's supposed to be? and the increase in power is when you have a DP and intercooler? or is there something wrong?
On a side note, I have not calibrated my MAF yet, but I was checking out my LTFTs and they are not horrible (around abs 6 without any adjustment), but not perfect. I'm not sure, but I don't think this would have a huge effect on my power.
Thanks,
Eric
Bob-o 01-09-2012 06:53 AM
A downpipe pretty much defines stage 2, with supporting mods. You should be on a Stage 1 map, and just do a MAF cal.
eb2292 01-09-2012 06:58 AM
Gotchya, thanks.
Any rants/raves on some downpipes? I haven't done a ton of research on them yet.
zatara 01-09-2012 07:03 AM
Originally Posted by eb2292 (Post 1200770)
Gotchya, thanks.
http://www.mazdaspeedforums.org/foru...-thread-99627/
jvella22 01-09-2012 07:03 AM
Believe there are a few threads about them. I have the ebay DP (catless) and love it. Only thing I don't like is the stench.
atvfreek 01-09-2012 07:06 AM
Originally Posted by eb2292 (Post 1200756)
Hey guys,
Thanks,
Eric
Downpipe is a pretty good gain. I just tuned a friend and he gained 20tq with just a dp install. The biggest gain though IMO is with a tune. The OTS maps are pretty conservative, because of the variations in peoples mods and potentially fuel. All the tunes I do usually see about a 30hp/tq gain over OTS. Technically COBB defines stage 2 even with a test pipe, so you should still be good on the stage2 map. I would either read up on tuning yourself or having a tune done to get the most potential out of your set up.
SWAY 01-09-2012 07:22 AM
You put in internals and just switched to stage 2 and thought you were gonna get a big power increase??? If you read what you need for stage 2 it would make more since but apparently no one reads anymore and just put on parts or flash a map and go. READ FIRST!!! Before you fuck up something.
~Sent from my Galaxy Nexus on Cm9~
Onelovesoccer 01-09-2012 08:06 AM
internals are just a requirement to get to stage 2 safely. but then you have to actually do some mods to see a difference. a DP plus a stage 2 OTS map (or e-tune) would give you the increase you are expecting. and honestly, at stage 2, you should be in the process of getting a custom tune for your car. lots of good e-tuners on here.
personally, i will be getting the Cobb DP despite it being more expensive.
SWAY 01-09-2012 08:57 AM
Another fail thread!!! Seems to be a trend lately.
sg1320 01-21-2012 01:24 PM
The biggest gain I got was from my perm tune.
Started with the stage1 setup which was a noticable power jump. And then added the stage2 stuff, dp, tmic, hpfp, and the stage2 map and noticed NO gain. It actually felt slower. But after getting the tune fixed up the car runs pretty good now.
Look into an etune, best money spent so far
MSpeed3013 03-15-2012 09:08 PM
How much do etunes usually go for??? And who is recommended??
dpolseno41 03-15-2012 09:12 PM
LEX! I just got finished with my tune by him and he was great, my car is a beast now. It will be the best $200 you ever spend mod wise
Page generated in 0.17910 seconds with 11 queries
