![]() | | #1 | ![]() |
![]() Join Date: Nov 2010 Location: Memphis,TN
Rep Power: 104 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
(Thread Starter) | Not Ranked : 0 score Is it normal for the WG duty to spike above its target like it does? Its understand the psi to spike but why is it falling so far below target when it compensates? Never used to do this but I just recently turned the boost up beyond 20psi. What can I change to remove, reduce the effects? WG duty cycle targets (2500-7000) 70 71.00 75.00 81.00 88.00 97.00 100.00 100.00 100.00 100.00 Boost Targets (2500-7000) 14.00 20.00 20.50 20.50 20.00 19.00 18.50 17.00 16.50 16.50
__________________ 2010 Red MS3/ Corksport SRI+TIP/ NATOR Downpipe + CS Racepipe (Catless FTW)/ AP+(E30)selftuned/ KMD v3 HPFP/ S.S brake lines + ATF superblue/ stoptech brakes/ JBM EGR delete/ SWAS disconnect/ JBM 80 RMM+80PMM/ Mudflaps/ itv22/ Rx8 wheels with Yoko S.drive245/40/18 (no rubbing issues) |
![]() Join Date: Nov 2011 Location: Detroit, MI
Rep Power: 74 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
What do your wastegate duty boost and load dynamics tables look like ?
Rep Power: 12092 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43,280
Groans: 235
| Not Ranked : 0 score +1^ ztnedman1... What fuel are you running and do you have your knock sensor enabled past 5500 rpm?
![]() | | #4 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 911 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 424
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score This, what's your load dynamics this could be it Sent from my dizzLe using RaWr powers!
__________________ 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Next: TMIC(WTB PM me); meow DP Official 60-100mph Times Official Youtube Channels
| The Following User Says Thank You to ms3rick For This Useful Post: | ztnedman1 (09-20-2012) |
![]() | | #5 | ![]() |
![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
Make closer to zero the overboost side of the BEC table by 25%. Sounds like you are having boost oscillations (over-compensation) when the boost spikes. Tweaking the overboost side of the BEC can fix this. Also your WGDC values at 2500 and 3000 are very high.... but again it depends on the fuel you are running. Try lowering them. I'm assuming you are doing a pure boost tune (aka your LEC is zeroed out).... if you are using load values listen to the other guys and please ignore me.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
![]() | | #6 | ![]() |
This is a pure boost tune. I am using E25. I dont think I have a very strong turbo or wastegate spring. Turbo doesnt smoke at all but since day one it has not been very strong without high WG duty. Most of my <3000rpm values came from the OTS stage 2 map. WG dynamics should be set up according to albitors guide. Boost error ramp limiter high = 15% Boost error ramp low = -100% Boost error comp: 0.10 0.09 0.08 0.07 0.06 0.00 -0.06 -0.11 -0.22 -0.44 -1.10 WG duty RPM comp A = -20% throughout WG duty rpm comp B = 10% throughout rfinkle2 econman ms3rick
![]() | | #7 | ![]() |
Groans: 235
The < 3000 values may be what is causing the overboost as well. All of the suggestions in this thread are possibilities. You can see the wgdc ramp up, overcorrect, and then reactivate. If it were me, I would set a value of 50 from 500 - 3000 rpm's and allow the boost error comp table to bring the boost up to targets.
![]() | | #8 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,608
If it's within your budget, I would also suggest getting a 3-port EBCS from Grimmspeed or Cobb. That was some of the best money I've ever spent. Improved response, lower WGDC, and helped solve my spike at spool issues. Fine-tuning it is much easier than the stock EBCS.
__________________ 2011 MAZDASPEED 3 VIRTUAL DYNO: 339 hp / 397 ft-lbs (BNR) DYNOJET: 296 hp / 343 ft-lbs (K04) BNR Supercars Stage 3 Turbo Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 Denso ITV24 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • RMM • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Continental ExtremeContact DWS Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit ProSport Performance Boost Gauge Aeroforce Dual Interceptor Gauges TO BE INSTALLED: Aquamist HFS-4 Alcohol Injection Stratified Auto Guardian Angel |
![]() | | #9 | ![]() |
Also, skeurton is right on. Drop the $115 and buy a Cobb or Grimmspeed EBCS and run it in 3 port mode. That will help you out a whole lot. | |
![]() | | #10 | ![]() |
| Not Ranked : 0 score ztnedman1 I took a closer look at your log and there's some weird stuff going on. First take a look at this graph: ![]() I've plotted your logged boost and WG Duty versus the values you provided from your ATR tables. You'll notice that you barely overboost around 3300RPM. However, the car has already started pulling WG Duty command and overall lowers it by about 20 ppts. This causes your boost to drop about 2psi below what is commanded. Then things slowly start to regulate. Here's a graph of the boost error and wg compensation: ![]() It is even clearer in this graph that the car pulls WG duty cycles long before your boost goes over targets. You are missing a few few variables in your log. I'd really like to see your throttle position and your calculated load. My guess is that your load dynamics and load error comp tables aren't zero'd out, and you went over your target load so the car started to respond. Would it be possible for you to take another log and add those two variables? Also please check your map to see what your load dynamics and LEC tables look like. rfinkle2 If there is anything I am missing (or if I am incorrect) please chime in |
![]() | | #11 | ![]() |
Groans: 235
You have it 100%.
![]() | | #12 | ![]() |
Fin A dude. nice post! econman Here is a list of all the "load based" tables under WG dynamics: 1. WG duty baro error comp 0.00 -0.02 -0.20 -0.30 -0.60 -1.40 2. WG duty load dynamics (fine) 0 everywhere 3. WG duty load error comp(coarse) 10.00 4.38 2.50 1.25 0.00 -2.50 -5.00 -8.76 -12.52 -25.04 -50.08 4. WG load error ramp limit high 12% 5. WG load error ramp low -100% 6. WG duty throttle close Matrix table My questions is what of these need to be zeroed? Ill add Throttle and Load back into the logs and take one tomorrow. Requested loads are 2.3 from 3k plus for all the gears with normal BATs Max loads are 2.5+ and the fuel cut loads are at 5, just in case they make any difference
Edit: Attached my map for ease
__________________ 2010 Red MS3/ Corksport SRI+TIP/ NATOR Downpipe + CS Racepipe (Catless FTW)/ AP+(E30)selftuned/ KMD v3 HPFP/ S.S brake lines + ATF superblue/ stoptech brakes/ JBM EGR delete/ SWAS disconnect/ JBM 80 RMM+80PMM/ Mudflaps/ itv22/ Rx8 wheels with Yoko S.drive245/40/18 (no rubbing issues) Last edited by ztnedman1; 09-20-2012 at 03:37 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #13 | ![]() |
Its the WG Duty Load Error Comp table that's very likely causing your issues. For a pure boost tune, zero out that table (also to be safe, zero out your WG duty baro comp table as well). Take a look at this thread (http://www.mazdaspeedforums.org/foru...ml#post1009814) this will help you setup your RPM Comp A|B tables when you go pure boost tune. |
![]() | | #14 | ![]() |
| Monk Tuning ![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 923 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Post your 4th gear throttle req load NORMAL values...if those are set to low, and your current boost is causing you to go over this load, it will limit your car. Its an easy fix Also, you will need a grimmspeed...you are maxed out for far too long. Take another 4th gear log with throttle position and calc load checked to show in logs as well. Then post up
__________________ 2011 Speed3-CP-E Stage 2 RMM, JBR TMM, JBR SSP, JBR SSB, 3.5" JBR WP, DDM 55w 6000k, Hoen Fog Lights, Autotech Internals, Enkei 17x8.5 RPF1, TIGs, EGR Delete, OCC, Treadstone TR8, FoMoCo Trans Fluid, Swift Springs, BSD and Baffle Kit, Ported Intake Manifold ala Driver311, CPE Injector Seals,PTP injector stud kit, RB Fabrication Ex Manifold, PTP 1950 Rail valve, ITV22s, Cordova Throttle Body, E85 blend Tuned by ME!!! Waiting to install- JTMS3 SUB BOX!!! TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #15 | ![]() |
No logs but zeroing out the WG Duty Load Error Comp took care of the boost oscillating. Ill be installing the grimspeed tomorrow. Thanks again for the help guys! rfinkle2 econman ms3rick skeurton
![]() | | #16 | ![]() |
| Not Ranked : 0 score |
![]() | | #17 | ![]() |
| Not Ranked : 0 score ::dances::
| The Following User Says Thank You to ms3rick For This Useful Post: | rfinkle2 (09-27-2012) |
| Report: Volkswagen recalling small number of 2012 Beetle models over tire issue | Haltech | Automotive News | 1 | 07-23-2012 04:43 PM |
| Just finished my Stratified tune | zedekias | Stratified Automotive Controls | 11 | 07-18-2012 11:31 AM |
| Ford recalls 20,000 small pickups for light issue | Haltech | Automotive News | 0 | 07-20-2011 09:00 PM |
| finished dustin tune | Joe Isuzu | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 05-30-2011 06:38 PM |
| Small recall for big suspension issue on 2008 Honda Element | Haltech | Automotive News | 0 | 08-19-2008 11:50 AM |
