Weird Anomalies 1 Attachment(s) I noticed every now and then when I'm logging I get a weird anomaly. I get about a 20ish second gap in the log and then my readings are as follows in the attached piece of that datalog. I called COBB about it but they said they've never heard of anything like it. If this has happened to anyone else or if anyone has any helpful info it would be gladly appreciated. I figure the numbers I'm getting in said anomaly are either 1.) not possible or 2.) would be a noticable thing so CLEARLY they aren't happening. |
Looks like your boost and fuel pressure switch places for a cell. |
Everything gets fucked briefly |
Weird. I guess a couple things you could try: - firmware - add or remove a column from the datalog. Could be a weird internal timing anomaly although it appears you are running the stock datalog parameters? - reflash your current map? - reflash a known good OTS map? Just try different shit to try and narrow it down. Just trying to help. |
All my firmware is up to date. And I have since removed a few data points from my log list. I'm running my version of the "Stage 1 SF+TIH 93 v210" OTS map. My version meaning I tweaked the LC and FFS and did MAF cal. Stock HPFP (that will change soon), and a CBE (which will become a TBE shortly after HPFP). I can't remember if it did it on any other map or not. Once I get the HPFP in I'll change maps and continue to look for shit going down and I'll update if y'all are interested enough. |
This is the first time I've heard of this. It really sounds more like a hardware issue to me, but I figured I'd throw some easy things to try out there. |
And I'm gonna change the topic slightly.. Don't want me to? It's my thread. Deal. Just need to say I'm glad my new hpfp internals are going in Tuesday. And now back to original topic.. I havn't had any weird shit happen with my datalogging since I posted this thread. Maybe the car/AP self fixed? |
@atvfreek - when pushing the pieces in, did you do it at the tip, the base, or both? I just tried it with decent pressure at the tip, but I don't think they moved at all...I'm trying to be as careful as possible here. Sent from my Galaxy Nexus |
Whoops...wrong thread! :banghead: Fucking phone...fucking me! Sent from my Galaxy Nexus |
| All times are GMT -7. The time now is 01:42 AM. |
