 Old 12-28-2017, 04:22 PM   #1
Otter's Avatar
Posts: 8   (View Stats)
Otter is an unknown quantity at this point
Default 1 blink the 6 blinks
My son lives in Edmonton and drives a Mazda 3 speed. 2010 RED speed3. Today the car refuses to roll over.
It blinks once then 6 times
Here is the txt he sent me
have issues with the immobilizer flashing, red light on ignition (vs green), and refusal to start?
Thanks from Nova Scotia
Otter is offline   Reply With Quote
 Old 12-28-2017, 08:45 PM   #2
dp3
dp3's Avatar
Posts: 82   (View Stats)
dp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to behold
It sounds as if the anti theft system was activated. Insert key and try moving steering wheel back and forth. See if it starts.
You could also try disconnecting the battery and depressing the brake. Reconnect and see if the car will run.
This is the deactivation procedure.
1. Insert one of the pre-programmed transponder keys and turn the ignition to "on", leave on for at least one second ( wait until the red key symbol in the instrument cluster extinguishes), remove the key from the ignition.
2. Within 5 seconds insert the second pre-programed key and turn the ignition to on for at least one second but no more than 5 seconds (use the key symbol for this as well) then remove the second key.
3. Within 10 seconds insert the new key in the ignition and turn the ignition to "on", if you are successful the red key symbol will illuminate then extinguish after about a second.
If you are not successful the red key symbol will flash repeatedly to indicate that you have inserted an invalid key. Remove the key, wait a minute and try it again.
In a worst case scenario you might need an ecu reflash. It should not be terribly expensive.
13 MS3 Eibach Pro kit Springs, Koni Ylw. F and R, Tanabe strut tower brace, 25 MM rear bar,CPE R mount, ETS TMIC, Autotech HPFP, ITV-22, CS: CAI, Cold Air Box, Boost tubes, Race Pipe, front spoiler. Forge BPV, Hypertech tune, Amsoil fluids,Philips DV H-11's and 9505's, Traklite RPM 18x8 +45 offset rims, 15mm Ichiba spacers(F&R) Rolled fenders w 235-40 Y rubber, Tint, Remix Rear Lip, Radar detector.
dp3 is offline   Reply With Quote
 Old 12-29-2017, 05:24 PM   #3
Otter's Avatar
Thanks for your response Brownie
our son went to his car today to try again. Put the key in and steering wheel was still locked and the red light was on in the dash. He pressed the button just to make sure and........ it started. He had time to drive to the dealer and the service manager had a look at it. They turn it off and on a few times and all is well.. The manager thinks where it was super cold in Edmonton -39c that the battery was weak. A week earlier he also left the interior dome light on and ran the battery down also. It all adds up to.... shit happens
One other thing. His key fob was cracked (for lack of better words and long story also) and that might have been the problem. The electrical components may have taken a beating He has a second key fob and it's packed away some where. So he ordered a new key and fob which will be in on Wed next week and they have to program it on Thursday. Thankful it xmas break and he can get it repaired.
He is also going to get the battery load checked tomorrow even though it less than 1 year old. -39c and below is very hard on batteries.
 Old 12-29-2017, 11:25 PM   #4
Amplified's Avatar
Posts: 70   (View Stats)
Amplified has a spectacular aura aboutAmplified has a spectacular aura aboutAmplified has a spectacular aura about
i feel ya, i'm in calgary and it's freezing as it's -37 here.
Amplified is offline   Reply With Quote
 Old 01-20-2018, 04:58 PM   #5
Otter's Avatar
All is well so far
He bought a new key and fob
LED fast blink! Mazduhspeed6 MazdaSpeed 3/6 - Car Audio & Electronics 2 12-21-2016 09:32 AM
06 Speed6 not staring No sound but security light blinks carboyq MazdaSpeed 6 - Engine, Transmission & Driveline 2 10-22-2014 08:55 AM
Blink's 07 MS6 O'Doom!! Blink Members Rides Gallery 16 10-20-2013 04:30 AM
Ford adding three-blink function to turn signals Haltech Automotive News 0 12-29-2009 03:50 PM
Page generated in 0.29607 seconds with 22 queries
