  • 1 Post By san1234
 Old 05-13-2019, 10:27 AM   #1
san1234's Avatar
Posts: 20   (View Stats)
san1234 is an unknown quantity at this point
Default 2010 MS3 covered in oil
My MS3 rear end is covered in oil. I seem to be burning a qt. every 500-600 miles. I have had a compression test which the stealership said was in good in all cylinders, did not get the exact numbers. NO oil leaks anywhere except out the tail pipe. I had the stock k04 go out and replaced it with a CS turbo and CS TBE, CS boost solenoid. I still cant seem to find where this oil is coming from. . . I do not notice any excessive smoking, definitely none at startup or idle, i do get a little white/blueish smoke when I give it a WOT. Any help would be appreciated. I am currently tuning with dizzy tuning and everything is going well so far. The tuner has not seen anything out of the ordinary.
san1234 is offline   Reply With Quote
 Old 05-14-2019, 04:40 AM   #2
san1234's Avatar
I don't know if this could be an issue with valve clearances being out of tolerance, my car has never had a valve adjustment. But it seems that oil is being pumped out of the tail pipe, one way are another, once again, any help would be appreciated.
 Old 05-14-2019, 07:15 AM   #3
Carskick's Avatar
Posts: 315   (View Stats)
Black soot around your tail pipe is normal. Are you sure your burning oil out of the exhaust? There are other ways to loose oil, such as through the rear engine seal. If you let the car idle for 2+ minutes, do you get smoke?
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
 Old 05-14-2019, 07:45 AM   #4
san1234's Avatar
No, there is no excessive smoking, during idle or driving. It seems if I let my car idle and parking in one spot, i will see oil mist on the ground behind it. No oil spot under engine, but I'm actually probably losing more like 1 qt every 300 miles. Not sure where its going beside out the tail pipe. But yes, the back is covered with oil droplets, got to wash it off.
 Old 05-14-2019, 07:51 AM   #5
Carskick's Avatar
That is quite a bit of loss. I'm only losing about 1/2 qt every 1000 miles.
If you replaced the turbo with no change, then it must be something internal leaking. I wonder if it could be a small crack in a ringland. Maybe not bad enough to fail a compression test, but bad enough to loose oil. Not sure, thought.
Do you have an OCC?
 Old 05-14-2019, 07:52 AM   #6
san1234's Avatar
No OCC. Im just trying to figure out where it would be leaking and then able to be pumped out the tail pipe. . .
 Old 05-14-2019, 08:07 AM   #7
san1234's Avatar
So if I dont have a OCC, and the PCV was pushing oil out, I would have oil in the intake right? and or intercooler?
 Old 05-14-2019, 09:56 AM   #8
Carskick's Avatar
Most likely.
 Old 05-14-2019, 05:47 PM   #9
san1234's Avatar
Definetly found part of the issue, this doesent explain the oil on the rear end. Oil tube needed some tightening
Carskick likes this.
 Old 05-15-2019, 11:35 AM   #10
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,975   (View Stats)
Groans: 546
What you're seeing is most likely not oil mist. It's more likely to be soot in the exhaust that is blown out with the water vapor from combustion.
94 M
06 MS6
The Following 2 Users Say Thank You to Pu Manchu For This Useful Post:
danb (05-15-2019), Kellerspeed3 (05-15-2019)
 Old 05-15-2019, 11:56 AM   #11
san1234's Avatar
Thank you for replying. Im starting to think this also, either water vapor and soot or rain mixed with soot. I will see after fixing the oil tube leak if I lose anymore oil.
 Old 05-17-2019, 07:36 PM   #12
SSinstaller's Avatar
Posts: 3,964   (View Stats)
Groans: 58
You could also check the pcv, if the valve fails you will pressurize the crankcase and possibly push oil past the seals in the turbo.
Soon to be installed:
 Old 05-24-2019, 06:37 AM   #13
san1234's Avatar
anyone know if i have to drain the oil to take the oil return line gasket? I am going to replace the oil return line outlet gasket and wasn't sure if i had to actually drain the oil before.
 Old 05-24-2019, 07:17 AM   #14
Jeff23spl's Avatar
Posts: 2,009   (View Stats)
the tube return is above oil level. Just not sure if you jack just the front if it could sip a bit.....At worst you put a pan just in case and do it when it need a quart ....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-24-2019, 08:01 AM   #15
san1234's Avatar
thanks for the reply. maybe ill go ahead and drain it and put some fresh oil in her.
Have any suggestions on oil, ive always put the 5w-30 in her, but Ive heard a lot about the 5w-40 on here?
 Old 05-24-2019, 08:28 AM   #16
Jeff23spl's Avatar
a lot use 5w40. but just make a search and you will find plenty of thread about oil. Some even goes very deep in details about it...
Wife drive 2010 CX7
ETS has your suspension needs covered! ETS Michael [ETS] Extreme Turbo Systems 19 12-12-2015 01:39 AM
Report: 136 recall campaigns in 2010 have covered 17.2M autos, and it's still not a record year Haltech Automotive News 0 12-22-2010 04:50 PM
2010 LA Auto Show: Day One (obsessively covered) Haltech Automotive News 0 11-18-2010 05:20 AM
We obsessively covered Day Two of the... Haltech Automotive News 0 11-03-2010 06:30 PM
We obsessively covered the... Haltech Automotive News 0 03-03-2010 07:50 PM
Page generated in 0.53759 seconds with 25 queries
