  • 1 Post By GohanX
 Old 01-04-2019, 08:07 AM   #1
Tru3's Avatar
Posts: 41   (View Stats)
Tru3 is on a distinguished road
Default 2nd Gear Grind - is there a fix?!
When I go into 2nd it grinds but only when the car is cold. When the car is warmed up it’s perfect. I’ve read countless threads on this but never found a real “fix”.
I’ve tried changing transmissions fluids, as well as adjusting the shifter cable (I can try again?), I have solid shift bushings in as well.
Is there a fix for this, any input?? Sorry to beat a dead horse but I feel like there has to be a fix besides buying a new transmission...
2010 MS3 // CS Tip * CS Sri * CS Boost Tubes * CS MZR Bpv * CS Hpfp * Cp-e TMIC * COBB AP (Freektune OTS +)
Tru3 is offline   Reply With Quote
 Old 01-04-2019, 10:18 AM   #2
08mzr's Avatar
Posts: 635   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
You could rebuild the transmission instead of buying a new one.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 01-05-2019, 06:35 AM   #3
Fstrnyou's Avatar
Posts: 2,148   (View Stats)
If this is your only car: buy a trans, have it rebuilt, swap it out when ready. Sell old trans or, depending on your vehicle intentions, save it as a spare.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 01-05-2019, 08:49 AM   #4
doublegmoto's Avatar
Posts: 14   (View Stats)
doublegmoto is an unknown quantity at this point
Only one thing will give you a few more miles out of your transmission before you have to replace it. Everybody's correct, once a syncro goes nothing you can do but replace it. But you can drive the car as if you were driving it without a clutch. With perfect shifts at the right RPM range like a rev match. Alot of skilled drivers could do this. If you could do this, you'll be able to do it without grinding. But you're going to eventually have to replace the tranny or the synchros like everybody else is saying there is no quick fix to something that's worn.
Sent from my LGMS631 using Tapatalk
doublegmoto is offline   Reply With Quote
 Old 01-05-2019, 01:10 PM   #5
Mazda3Blog's Avatar
Posts: 22   (View Stats)
Mazda3Blog is just really niceMazda3Blog is just really niceMazda3Blog is just really niceMazda3Blog is just really niceMazda3Blog is just really nice
Good news for you. I live in Canada and have a shit ton of experience driving/racing 2 Speeds through some really brutal winters here.
I really doubt that you need a new tranny. Our transmission, even when new, has a notchy/grindy second gear in cold weather.
If you're not popping out of second gear and it shifts normal when warm, you've got nothing to worry about.
The solution:
1. Use RedLine MTL transmission fluid.
This fluid is 75W80, often the second gen speed3 has 75w90 put in which makes cold crunches worse. This stuff is way better than the OEM or Ford fluid for cold weather. Also lets me shift faster in the warm.
2. Baby second gear for the first few cold shifts, first gear->neutral center->second gear
Instead of shifting directly from first to second, keep your foot on the clutch but pass the shifter into the center neutral area. Then go into second and it won't crunch. It's a trick that a lot of Speed owners use in the cold weather to avoid 2nd gear grinds.
There are some people who say the Ford fluid is better, but I've tried both and the RedLine MTL made a huge difference for my car in the cold. The canadian mazda3 forums also vouch for Redline over Ford fluid for cold weather.
I've also had second gear replaced under warranty a long time ago and it made no difference to second gear cold grinding.
Give it a shot and I bet you'll like the car a lot more in the cold.
2010 Black MS3 (autocross/track car)
Stratified tune, accessport, K&N intake, E-focus RMM, corksport RSB, solid shifter bushings, Corksport steering wheel + ebrake, RE-71R/Pilot Super Sport tires
2007 Black Speed6 (daily driver)
Freektuned, Accessport, Autotech HPFP, CPE TMIC, Cobb intake + TIP, Ultimate Racing test pipe, CPE xflex RMM, Corksport rear diff mount, Corksport rear brake pads, Matt Damond rear caliper bushings, solid shifter bushings, X-ice3 tires
Mazda3Blog is offline   Reply With Quote
 Old 01-05-2019, 01:31 PM   #6
GohanX's Avatar
Posts: 33   (View Stats)
GohanX has a spectacular aura aboutGohanX has a spectacular aura about
In addition to moving to neutral also double clutch the shift into second. That is, move the shifter to neutral, let out the clutch, push it back in, then shift into second, let it out. I've had to do that to my Speed 6 the first few shifts since it's been cold, and I used to have to do that in the old Miata too. I think it's just something when these Mazda transmissions, a lot of them have cold 2nd gear issues.
Mazda3Blog likes this.
GohanX is offline   Reply With Quote
 Old 01-05-2019, 01:37 PM   #7
Mazda3Blog's Avatar
Agreed, that's the next level move if he's still grinding. That works in almost any car with synchro issues. I luckily don't have to double clutch once I switched to Redline MTL.
I put in Redline MT-90 in the Speed6 and it made a huge difference for cold and warm shifts. My 6 is easier to shift in the cold and the transmission warms up faster than the 3. Cars both have around 130,000 miles.
 Old 01-05-2019, 02:36 PM   #8
Fstrnyou's Avatar
I've always thought double clutching was silly. Okay. I still think it's silly.
You don't need the clutch at all to disengage a gear if the trans isn't loaded.
As you let off the throttle, foot OFF the clutch, pull it out of first gear. This leaves the input side already meshed with the engine which is what your doing when you let out of the clutch the first time during double clutching.
Other rides:
History:
 Old 01-05-2019, 08:05 PM   #9
GohanX's Avatar
I just put some of the Ford unicorn jizz in mine this afternoon, we'll see how it does when it gets cold again. Also noticed my cv boot was ripped... Dammit.
 Old 01-08-2019, 07:52 PM   #10
Mazda3Blog's Avatar
Give the fluid a week of driving to break in, all the fluids I tried definitely got better after some driving. If you're still not happy with the cold shifts, try the redline MTL because it almost solved the crunches completely for me.
You can get cheap reman axles from RockAuto that work on the speed, I had an axle with a torn boot re-built for about $150 including labour a few years ago.
 Old 01-08-2019, 08:10 PM   #11
GohanX's Avatar
It still hasn't got really cold here yet but I haven't had any 2nd gear grinding yet! And yeah I ordered an axle from Rockauto, just got here today.
 Old 01-11-2019, 09:27 AM   #12
GohanX's Avatar
It was 24 degrees this morning, the shifter went right into 2nd, no grind at all. Very nice.
 Old 01-11-2019, 09:29 AM   #13
Fstrnyou's Avatar
I use Royal Purple. Was in the 20's this morning and always shifts fine.
Other rides:
History:
 Old 01-12-2019, 06:14 PM   #14
TruckHer's Avatar
Posts: 2   (View Stats)
TruckHer is an unknown quantity at this point
Default MTL
I live in Canada too and have used MTL. It worked great making every other gear shift as smooth as butter, winter or summer weather. Never got rid of my second gear grind if I shift relatively fast though. Mine was a different case though in that I tended to grind more when shifting from first to second when it got warmer. Never resolved it, just granny shifted into second or double clutched.
TruckHer is offline   Reply With Quote
2nd gear pop out and grind jellowood 2010 MS3 - Engine, Transmission & Driveline 112 08-15-2018 09:47 AM
Gear Grind intotheice 2010 MS3 - Troubleshoot/Diagnostics 23 05-18-2012 02:52 PM
2-3 gear grind manila 2010 MS3 - Engine, Transmission & Driveline 29 03-27-2012 05:17 AM
3rd gear grind... NinjaT1985 2010 MS3 - Engine, Transmission & Driveline 24 07-14-2011 02:24 PM
3rd gear grind Raysfan 2010 MS3 - Engine, Transmission & Driveline 45 06-22-2010 08:38 PM
Page generated in 0.31593 seconds with 26 queries
