 Old 07-11-2011, 09:13 AM   #1
NinjaT1985's Avatar
Posts: 551   (View Stats)
NinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the world
Groaned at 33 Times in 10 Posts
Default 3rd gear grind...
Anyone else grinding 3rd with the JBR SSP when shifting fast? It never happens when shifting normally or slowly, just when shoving it quickly from a 2nd gear pull, I always end up grinding. I might redo the shifter selection setting and put the shifter into 3rd gear and then lock it down, maybe that'll help.
2012 Toyota Tacoma
NinjaT1985 is offline   Reply With Quote
 Old 07-11-2011, 12:12 PM   #2
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
yeah i have jbr ssp and still grind on fast shifts into 3rd. have also rmm and shifter bushings. got better, but still have grinds on fast shifts. Ordered today Castrol Syntrans 75w90 and hope it will fix the problem.
MPS_Fan is offline   Reply With Quote
 Old 07-12-2011, 09:04 AM   #3
Caboose's Avatar
Posts: 141   (View Stats)
Caboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond repute
Did some reading around here the other day. I think it was 9900rpm that said Ford XT-M5-QS was cure all for tranny shifting issues.
Look Here
Caboose is offline   Reply With Quote
The Following 3 Users Say Thank You to Caboose For This Useful Post:
9900rpm (07-13-2011), JBR (07-13-2011), NinjaT1985 (07-12-2011)
 Old 07-12-2011, 09:36 AM   #4
NinjaT1985's Avatar
Thanks, I'm going to switch over this weekend and see how it works
2012 Toyota Tacoma
The Following User Says Thank You to NinjaT1985 For This Useful Post:
JBR (07-13-2011)
 Old 07-12-2011, 12:38 PM   #5
MPS_Fan's Avatar
we don't have this Ford juice here in Germany. funny thing is that its produced here! But you can't buy it here!
 Old 07-12-2011, 12:43 PM   #6
Caboose's Avatar
I thought I read somewhere that it was made for the European market, but it's called something else over there. Try searching for the European equivalent and I bet you come up with something.
 Old 07-12-2011, 12:46 PM   #7
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
I put the ford tranny oil in my car and it still didn't fix my 3rd gear grind.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
 Old 07-12-2011, 12:51 PM   #8
ccspeedsix's Avatar
Posts: 152   (View Stats)
ccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond repute
Thats because of the AWD addition to the ms6 trannies. I was never able to get rid of my 3rd gear issues with changing the oil, what your going to have to do is adjust the shifter cables, as thats the only thing that every helped my shifting issues in my old ms6.
ccspeedsix is offline   Reply With Quote
 Old 07-13-2011, 02:58 AM   #9
MPS_Fan's Avatar
I found the name of the Ford Tranny fluid in Europe. Its called "Ford 75W-90 BO". Nothing more. It costs 18€ (26$) per quart!!! Fu**** expensive! I´ve paid for 3qt of Castrol 75w90 40€ (55$). It has about the same viscosity at 40° and 100° like the Ford.
 Old 07-13-2011, 07:47 AM   #10
MS3 Abuser
9900rpm's Avatar
Posts: 784   (View Stats)
9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world
Here in the US, the Ford XT-M5-QS stuff costs around $18 a quart. Buy the Ford stuff. It's been proven time and time again to work well in the MS3 transmissions. There is no substitute.
Yes it's expensive, but transmissions cost even more! Your call.
12.653 @ 109.90mph, Stock K04
2010 MS3
9900rpm is offline   Reply With Quote
 Old 07-13-2011, 12:39 PM   #11
MPS_Fan's Avatar
I´ve already bought the Castrol fluid before i knew that i can buy this Ford fluid here in Germany. I changed today the fluid. Difference is like night and day! Shifting is now extreme smooth. Tried some very hard shifts today, no grinding yet!!! I tried to drive slowly in first gear and full turn, i can notice a little LSD whine, but its hard to hear it. only happens on full turn and in 1. and 2. gear on part throttle. Can´t notice it in 3rd because of the speed. If it is only a sound problem, i can live with it. Maybe i had this before fluid change, never tried to hear it. And i can only hear it if climatic control is off, because its so quiet. i can say ++++++ for Castrol Syntrans. That shit rocks!!
 Old 07-13-2011, 01:58 PM   #12
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Do they sell this Ford tranny fluid at any auto parts store? I'm changing it this weekend
 Old 07-13-2011, 02:00 PM   #13
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
just go to a ford dealership. n try not to get convinced to scoop up a new 5.0 cuz they tried convincing me lol.
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 07-13-2011, 02:13 PM   #14
adlpb's Avatar
Groans: 669
Lol. How many quarts did u buy from them?
 Old 07-13-2011, 02:15 PM   #15
2011speed's Avatar
FreeKtuned
fitty fitty
The Following User Says Thank You to 2011speed For This Useful Post:
adlpb (07-13-2011)
 Old 07-13-2011, 02:31 PM   #16
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groans: 98
Groaned at 72 Times in 51 Posts
my local ford dealer has them in stock too. 18 bucks per quart.
im perfectly fine with the shifter feeling, so i won't bother changing it yet.
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 07-13-2011, 04:25 PM   #17
WillyH's Avatar
Posts: 316   (View Stats)
WillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond repute
Groaned at 53 Times in 27 Posts
Just bought 3 quarts here in Canada.....bill came to $86.22. FML.
Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid
WillyH is offline   Reply With Quote
 Old 07-13-2011, 04:34 PM   #18
MS3 Abuser
9900rpm's Avatar
Holy shit! Does your ass hurt?
2010 MS3
 Old 07-13-2011, 04:35 PM   #19
NinjaT1985's Avatar
I actually moved the shifter selector cable setting and I haven't grinded since. I put the shifter on 4th gear and released the spring and so far it shifts soo much smoother
2012 Toyota Tacoma
JBR (07-19-2011)
 Old 07-13-2011, 04:43 PM   #20
JS + MS3's Avatar
Groans: 98
Nice.
2010 Mazdaspeed3
 Old 07-13-2011, 06:34 PM   #21
WillyH's Avatar
Yeah, it guess I took a good ass raping. Fuck Canada - we get ripped off for everything.
My 2010 speed came to 38k.......
 Old 07-13-2011, 11:01 PM   #22
MPS_Fan's Avatar
in germany, you pay for new Speed 3 about 40k ! Thats what i call "to get ripped off"
 Old 07-14-2011, 09:20 AM   #23
MS3 Abuser
9900rpm's Avatar
Ouch! You guys have white as a color option, and had HID's with AFS, heated seats and LED tail lights in 2010. We did not.
OUCH!! You guys get a lot of cool cars over there though, which we can only dream of.
2010 MS3
The Following User Says Thank You to 9900rpm For This Useful Post:
SLOWHATCH (04-02-2012)
 Old 07-14-2011, 09:23 AM   #24
zatara's Avatar
Posts: 1,505   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
Poland is much the same. ~40,000 for an MPS. I was curious because I may be moving, and I was seeing what would be cheaper, getting the one I currently own legal there and importing it, or just buying one....neither is pretty
zatara is offline   Reply With Quote
 Old 07-14-2011, 01:24 PM   #25
MPS_Fan's Avatar
i noticed today some LSD whine in hard corners in 1st gear. i've read somewhere that its no problem. for me the whine is no problem. what do you think guys?
3rd gear grind 9900rpm 2010 MS3 - Troubleshoot/Diagnostics 103 06-29-2012 10:23 PM
2nd and 3rd gear grind blakkat 2010 MS3 - Engine, Transmission & Driveline 25 07-07-2011 12:23 AM
3rd gear grind Raysfan 2010 MS3 - Engine, Transmission & Driveline 45 06-22-2010 07:38 PM
Why does 3rd gear grind. help? parapdrapa MazdaSpeed 3 - Engine, Transmission & Driveline 30 08-31-2008 09:26 AM
Page generated in 0.42695 seconds with 30 queries
