 Old 12-23-2014, 07:44 AM   #1
KCi
KCi's Avatar
Posts: 93   (View Stats)
KCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond repute
Default ARP main studs and balance shaft
I am in the middle of deciding if I should go ahead with BSD and insisting in installing ARP main studs for the motor built? Installing ARP main studs will have clearance issue with OEM balance shaft. I am inclining towards BSD given advantages of ARP studs. Else, I may need to find way to trim the studs to fit the OEM balance shaft back. What are you guys opting for this scenario?
KCi is offline   Reply With Quote
 Old 12-23-2014, 09:29 PM   #2
shaneski's Avatar
Posts: 490   (View Stats)
This build shows trimmed ARPs 2010 MPS brand new engine build + swap
Freek uses OEM mains and rod bolts in 500whp+ without a problem, don't think i have seen the OEM mains etc cause a zzb unless someone has a link to them taking a shit.
The Following User Says Thank You to shaneski For This Useful Post:
KCi (12-23-2014)
Balance shaft question pekka83 MazdaSpeed 3 - Engine, Transmission & Driveline 22 11-29-2013 11:13 PM
How to - Balance shaft delete danesti MazdaSpeed 6 - How-To's 105 04-04-2012 06:49 PM
Why you need to remove your balance shaft TheDoc MazdaSpeed 3 - Engine, Transmission & Driveline 43 09-04-2009 03:39 PM
Rods and main studs ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 2 06-08-2009 10:11 AM
Page generated in 0.23328 seconds with 21 queries
