 Old 09-11-2018, 10:55 AM   #1
Tru3's Avatar
Posts: 44   (View Stats)
Tru3 is on a distinguished road
Default Best Gen 2 Transmission Fluid?
Any recommendations? Iíve seen that the Motorcraft XT-M5-QS, works best for gen ones.
What are you running in your Gen 2? And purchase links are appreciated
2010 MS3 // CS Tip * CS Sri * CS Boost Tubes * CS MZR Bpv * CS Hpfp * Cp-e TMIC * COBB AP (Freektune OTS +)
Tru3 is offline   Reply With Quote
 Old 09-11-2018, 11:42 AM   #2
Thor Hammer's Avatar
Posts: 1,783   (View Stats)
Groans: 203
No difference in fluid requirements between gens. Come on man. Its just trans fluid. Use the Motorcraft unicorn oil and get it on Amazon. Search next time brownie!
 Old 09-11-2018, 11:43 AM   #3
Tru3's Avatar
I can link you to a thread of people saying it didnít work well for them? All gen twos
 Old 09-11-2018, 12:03 PM   #4
Db09ms3's Avatar
Posts: 286   (View Stats)
Groans: 65
Just do it. You'll be fine.
Stockish
 Old 09-11-2018, 12:13 PM   #5
cyclist20's Avatar
Posts: 634   (View Stats)
cyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the world
Technically, gen 2 requires 75W80 and gen 1 75w90. I have used both redline 75w80 and Ford unicorn jizz. I will be going back to redline. I think it just a touch better in the cold.
2013 LSM Speed BNR S3v2
AP V3
Corksport: HPFP Internals, Injector Seals, bpv, TMM insert, battery box
Full Race: Exhaust Manifold, ceramic coated for lovliness
CNT:Catted DP
Treadstone TR8 with CX piping
CP-e: Stage II RMM
HTP:3" intake
Stratified: 3port, Guardian Angel
JBR RSB, Shifter Bushings, EGR Delete/Blockoff
Matt Damond:OCC, PMM
UR Axleback
Rice: Corksprt CF Hoodscoop & Spoiler // 12mm spacers // Bayson R lip // Bayson R GV grill // Okiefam powercoated VC, coil, and HPFP covers
Tuned by PURPLE DRANK
cyclist20 is offline   Reply With Quote
 Old 09-11-2018, 12:26 PM   #6
Tru3's Avatar
Thanks! Looking to get Redline MT-90
 Old 09-11-2018, 12:27 PM   #7
GohanX's Avatar
Posts: 47   (View Stats)
GohanX is just really niceGohanX is just really niceGohanX is just really niceGohanX is just really niceGohanX is just really nice
I just got a few quarts from Rockauto for my Speed 6, right now it's quite a bit cheaper than Amazon at $15.11 a quart. Haven't put it in because some asshole tightened the fill plug with an impact wrench...
GohanX is offline   Reply With Quote
 Old 09-11-2018, 12:42 PM   #8
Groans: 203
Then I guess you know better already right? It didn't work well for them because they beat the shit out of their cars. And when the trans stops shifting smooth and pops out of gear they blame it on the fluid. That's just ignorant.
Seriously dude, its a manual trans and just about any fluid with the correct ratings will work. If you don't like Motorcraft then use Redline. Don't make it complicated. We don't like oil discussions around here. Go check with your bro's on Facebook. they will talk about it all day long.
I've been using this fluid for the past 60K miles and changed it twice. My trans works perfectly. I don't drag race or beat on it though.
Last edited by Thor Hammer; 09-11-2018 at 12:42 PM. Reason: MSF Database - Automerged Doublepost
Db09ms3 (09-11-2018)
 Old 09-11-2018, 06:23 PM   #9
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
On a semi-related note, I've been having issues with my transmission grinding randomly (with clutch on the floor), I've got 20k mile old Redline MTL in the transmission (car has 50k miles), so thinking some Motorcraft or Motul Gear 300 is going in next oil change.
I have however noticed something rather strange, in that reflashing between maps seems to cure my notchy shifting temporarily. Like no joke, it goes from "my 2nd and 3rd synchros are fucked" to "feels like a fresh transmission". It seems like as my ECU relearns the adaptations, the shifting gets progressively more clunky, same with general on/off throttle transitions, starts off smooth, then gets more and more lurchy. It usually takes a couple weeks of commuting to notice this, but it has happened every time I reflashed this summer. Any thoughts?
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
Used Transmission Fluid Question stoickiwi 2010 MS3 - Engine, Transmission & Driveline 12 10-22-2014 08:16 AM
OEM transmission fluid spinixguy MazdaSpeed 3 - Engine, Transmission & Driveline 6 10-13-2014 11:04 AM
Enough Transmission fluid? mxrider518 2010 MS3 - Engine, Transmission & Driveline 5 07-01-2013 09:49 AM
Transmission Fluid Crazyspeed3 Mazdaspeed3/6 General Discussion 6 12-23-2011 07:32 PM
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A Haltech Automotive News 0 05-15-2009 04:10 PM
©Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHNô Autosports HQ
Page generated in 0.29958 seconds with 25 queries
