Notices
 Old 06-11-2012, 06:49 AM   #1
blakkat's Avatar
Posts: 568   (View Stats)
blakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the world
Default blown rear main seal
ok, so my clutch has been slipping and i think my rear main seal is blown, i can see a small amount of oil where the trans mates up to the engine. and the slip is intermittent, im assuming caused by oil on the flywheel. why would it blow at 20k miles? should i be worried about zzb like keith, because it seems like im having the same issues he did leading up to his blown motor
2011 black mica ms3.
Mods:
mounts- jbr 80duro rmm, jbr 80duro trans mount
engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned
shift- sure shortcut, countershift, anchors
looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit
blakkat is offline   Reply With Quote
 Old 10-09-2012, 03:04 PM   #2
himurax13's Avatar
Posts: 2,189   (View Stats)
Groans: 34
Well I just had my clutch replaced at 49,000 miles and my rear main seal was blown. I still had 20% of clutch life left.
Ohnononono pinoyboi.
Listen my adobo cooking friend. You will move to NJ. I shall take you under my wing. You will void that warranty. Your wife will be very upset with you that you spend every Tuesday night with us, and you use all your extra monies to buy all the parts I shall find for you. You will sushi roll and ffs up and down the GSP with us. You will end up on YouTube and in the street racing videos. And last, but not least, you will allow us access to employee pricing on all parts thru your dealership.
Are you sure you still want to come to NJ? We go hard here.....be warned.
I too once was a naive ayshun with a stock pu. Then I met these fuckers. My wife hates me now Tuesday nights. My neighbors hate my car for the uber cool cold start. My garage is a fucking mess. My warranty went out the window. My life has not been the same since April. I should have bought a Mazda2.
himurax13 is online now   Reply With Quote
 Old 10-09-2012, 04:33 PM   #3
Posts: 9,588   (View Stats)
The leak may just be from the oil pan. which is far more common at that mileage.
 Old 10-15-2012, 08:46 AM   #4
jhample's Avatar
Posts: 63   (View Stats)
jhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud of
i have 33k on mine and the rear seal went, oil pan leaking, ruined clutch and flywheel from too much oil in it... headed to the shop now to see the damage
jhample is offline   Reply With Quote
 Old 10-15-2012, 09:09 AM   #5
speed14's Avatar
Posts: 494   (View Stats)
speed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the world
Post up results. thinking this might be the reason i'm seeing clutch slippage at 36k.
2010 Mazdaspeed 3 | Black Mica
COBB AP | CS SRI | CS TIP | CP-E TMIC | Denso ITV22 | UR Catback | UR Racepipe | UR Downpipe | DO Meth Injection | Autotech Internals | Turbosmart BPV | DDM 6000k lows | 3000k fogs | 18x8 TSW Nurburgrings | 235/45/18 Toyo Proxes | H&R Springs
speed14 is offline   Reply With Quote
 Old 10-15-2012, 09:12 AM   #6
Are you guys seeing a lot of crankcase pressure/blowby?
 Old 10-15-2012, 10:58 AM   #7
jhample's Avatar
I've only owned it for 8k so this damage is likely from the previous owner, but the mechanic asked me how often I go to the track. I said never and he was surprised. I also had a blown pmm too so we are assuming that that extra movement combined with too much torque from launching at the track moved stuff around allowing the leak. I never noticed any clutch slippage but after seeing it out of the car I'm surprised it was working. The rubber between the two flywheel pieces was completely rotted and wobbly. The Oem flywheel is about 1200. Luckily we found a used one that we can put in for 400. Total I'm looking at about $2200 with parts and labor. If you have a 2011 you should still be in warrantee. I'm just out of it with a 2007
DON'T BUY A USED MODIFIED CAR!!!
 Old 10-15-2012, 11:00 AM   #8
jpshotya's Avatar
Posts: 103   (View Stats)
jpshotya has much to be proud ofjpshotya has much to be proud ofjpshotya has much to be proud ofjpshotya has much to be proud ofjpshotya has much to be proud ofjpshotya has much to be proud ofjpshotya has much to be proud ofjpshotya has much to be proud ofjpshotya has much to be proud of
Groaned at 11 Times in 2 Posts
well i just had an oil change done.. he saw leaking at the seal also. 34k mile 2010 ms3.. i can assume its covered under warranty?
Justin - NJ
2010 MS3 Celeste Blue
Performance - Cobb SRI - GFB Dual Port BPV
Support - Sure RMM
Visual - DDM 6K Hid
jpshotya is offline   Reply With Quote
 Old 10-15-2012, 11:04 AM   #9
himurax13's Avatar
Groans: 34
I was seeing quite a bit of blowby/high crankcase pressure. I think the problem stems from the inadequate PCV system that has a difficult time dealing with 50%+ more boost than stock.
 Old 10-15-2012, 11:27 AM   #10
Engine movement won't cause a rear main seal leak. Rear mains leak due to too much crankcase pressure or just wear over time.
You guys are diagnosing rear main seals by pulling off the oil pan and seeing oil coming from above it right? Because leaking around the oil pan is most likely the oil pan RTV.
charlesfist (10-15-2012)
 Old 10-15-2012, 11:44 AM   #11
himurax13's Avatar
Groans: 34
My mechanic replaced my rear main seal when he installed my new clutch. The seals were basically folded out. There was still a bunch of oil in that area that he was not able to clean out so I am closely monitoring my oil levels to see if the new seal is holding up. The amount of leakage seems to be dying down but the oil pain RTV may be an additional culprit.
I am also going to be monitoring how much oil my vented catch can will be catching. It was alot at first but I think that was due to the fact that I did not have the lines set up to drain directly into the catch can. Since there is no vacuum, basically only gravity and excess crank pressure will move oil into the catch can. I am ordered a straight 10 AN fitting from SSP so that I can have the PCV drain directly into the can.
So far everything seems OK and my car seems to like running without oil gushing into the intake .
The Following 3 Users Say Thank You to himurax13 For This Useful Post:
charlesfist (10-15-2012), Lex (10-15-2012), lilred (10-15-2012)
 Old 10-15-2012, 11:49 AM   #12
jpshotya's Avatar
well the guy said my oil levels were good , just a little oil around the seal.. so before i bring it back to the stealership .. ill monitor the levels now that i know about it. I was just shocked to see that kind of issue on a low mile car that has not seen the track or constant beatings
Justin - NJ
Support - Sure RMM
Visual - DDM 6K Hid
The Following User Says Thank You to jpshotya For This Useful Post:
speed14 (10-15-2012)
 Old 10-15-2012, 02:30 PM   #13
speed14's Avatar
Lex, what is the best indicator of excessive crankcase pressure of these cars, would it be an accumulation of oil in the intake tract comming from the PCV line?
 Old 10-15-2012, 02:39 PM   #14
Generally oil through the intake/TIP crankcase vent.
 Old 10-15-2012, 02:57 PM   #15
himurax13's Avatar
Groans: 34
Or your dipstick popping out and oil flooding your engine bay more than once ...
From what I can tell this usually caused by the breather vent on the valve cover has some blockage or overfilling your oil.
Leaking Rear diff axle seal BigjohnB20 MazdaSpeed 6 - Engine, Transmission & Driveline 9 03-25-2012 10:06 AM
Leaking rear main seal. Seaton 2010 MS3 - Engine, Transmission & Driveline 3 02-14-2012 06:43 PM
rear main seal LiEast MazdaSpeed 6 - Engine, Transmission & Driveline 0 03-25-2011 01:33 PM
rear main seal woes wribbels MazdaSpeed 6 - Engine, Transmission & Driveline 11 02-10-2011 08:57 PM
Blown Seal? Rican219 MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-19-2008 08:52 AM
Page generated in 0.35096 seconds with 25 queries
