Like Tree8Likes
  • 1 Post By tegxsi
  • 1 Post By g00s3y
  • 1 Post By MS3Shadow
  • 1 Post By sheston
  • 1 Post By Djohns
  • 1 Post By KiwiFlavor
 Old 02-17-2017, 09:11 AM   #1
kade66's Avatar
Posts: 1   (View Stats)
kade66 has a little shameless behaviour in the past
Exclamation clueles
so I have an 07 ms3 that ive had for almost 4 years. a little over 100k miles on it and the turbo starts leaking oil. at this point I have tubo back exhaust with no kat so it just dumps smoke all over. I pull the turbo out and the housing has a giant crack in it. so I order a new ko4 and a set of headers. im in the process of putting the header, turbo, dp, and rest of exhaust back on. Im just curious if I should get it tuned after putting an aftermarket header on it. its an aftermarket ko4 with downpipe and aftermarked exhaust the rest of the way back. also have cold air intake.
ive been kind of looking into an accessport but not sure if that would be beneficial in my situation. im new to this stuff so any input would be greatly appreciated.
kade66 is offline   Reply With Quote
The Following User Says NO Thank You to kade66 For This Un-useful Post:
Vansquish (02-18-2017)
 Old 02-17-2017, 09:33 AM   #2
balint's Avatar
Posts: 33   (View Stats)
balint is a glorious beacon of lightbalint is a glorious beacon of lightbalint is a glorious beacon of lightbalint is a glorious beacon of lightbalint is a glorious beacon of lightbalint is a glorious beacon of light
If I read that correctly, you have an aftermarket downpipe correct? If so please please please tell me you have at least upgraded HPFP internals, cause otherwise you're gonna long term playing with fire. And HPFP and accessports are the first two upgrades most people on here recommend, as they are essentials to this platform once you start building.
balint is offline   Reply With Quote
The Following 4 Users Say Thank You to balint For This Useful Post:
MS3Shadow (02-17-2017), sharksinspace (02-17-2017), Vansquish (02-18-2017), Varomnia (02-17-2017)
 Old 02-17-2017, 09:58 AM   #3
Bingo's Avatar
Posts: 659   (View Stats)
Groaned at 9 Times in 7 Posts
So this thread is basically Is my car going to blow up? except with a dude. I'm very curious to see how differently this turns out. OP, best of luck with what's to come. I would recommend in the meantime reading your welcome PM.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Moog endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges.
Bingo is online now   Reply With Quote
The Following 2 Users Say Thank You to Bingo For This Useful Post:
sharksinspace (02-17-2017), Varomnia (02-17-2017)
 Old 02-17-2017, 10:02 AM   #4
tegxsi's Avatar
Posts: 1,197   (View Stats)
Groans: 79
You didn't read your welcome message...so yeah, it's gonna blow up.
sharksinspace likes this.
2013 CWP Mazdaspeed3
CS Turbo
2007 TSX 6MT
The Following 2 Users Say Thank You to tegxsi For This Useful Post:
KiwiFlavor (02-21-2017), Varomnia (02-17-2017)
 Old 02-17-2017, 10:05 AM   #5
sharksinspace's Avatar
Posts: 708   (View Stats)
Groans: 76
QFMFT. Get dem HPFP internals now if you don't have them already, and go light on the throttle until they're installed.
A custom tune will also do wonders for any Speed, even on a completely stock setup. AP or VT and then work with one of our established and excellent e-tuners; very highly recommended to safely get the most out of the car.
2007 MS3
Ghettofab 3" CBE; DM PMM, TMM; CS Stage2 RMM, RSB, Lower tie bar
Koni Str.t + Bilstein B8; Swift Springs; JBR STS; Sumi HTR Z III on RX8s
PD by Will
The Following User Says Thank You to sharksinspace For This Useful Post:
 Old 02-17-2017, 10:33 AM   #6
g00s3y's Avatar
Posts: 2,077   (View Stats)
Groans: 410
Found @Madison;'s bf account...
Yes it will blow up, amazing it hasn't already without internals.
And you don't have headers, you have an exhaust manifold. What one did you go with on the shit k04? The ebay $179 special?
Had the car for 4 years, and you are new to this? You don't think once about maybe learning about the $10,000+ investment that you made and use everyday?
Nailedit187 likes this.
The Following 2 Users Say Thank You to g00s3y For This Useful Post:
Jonb82 (02-19-2017), KiwiFlavor (02-21-2017)
 Old 02-17-2017, 10:40 AM   #7
Omega's Avatar
Posts: 428   (View Stats)
Omega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the world
I don't think OP realizes the tune is where the power really comes from... That poor speed, ringlands are probably already done for.
inb4 "still smoking" bad compression
2006 Super Clean BCM MS6
Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module
Waiting to be installed: Diff Braces - TMM Insert
Omega is offline   Reply With Quote
 Old 02-17-2017, 10:59 AM   #8
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 267
get a lot of parts, and wonders when it's gonna get fasts without tuning it.
Accessport and HPFP should have been the first you things gotten.
Omega likes this.
The Following User Says Thank You to MS3Shadow For This Useful Post:
balint (02-18-2017)
 Old 02-18-2017, 07:55 AM   #9
Fstrnyou's Avatar
Posts: 1,170   (View Stats)
Originally Posted by MS3Shadow View Post
Versatune and HPFP should have been the first you things gotten.
Fixed.
2006 MS6 GT - 148k Miles
Versatuner, CS Turbo/DP/RP/HPFP/BPV
JBR Tru-3.5/3-port EBCS/EGR-D, Bosch 3bar, ITV22's
eBay Stage 1 OCC, DM RMM/PMM/Stage 2 OCC
Forged build ongoing. Manley H-Tuff Rods, Manley 2618 Pistons, King Bearings
Other rides:
2002 Tacoma ExtCab 2.4L 5spd 2WD - Parts Getter
History:
 Old 02-18-2017, 07:59 AM   #10
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 267
Originally Posted by Fstrnyou View Post
Fixed.
Bruh, some people don't want to carry an laptop to take an log of their car or want to tune their own car. Each has it own advantages.
Sent from my Pixel XL
The Following 2 Users Say Thank You to MS3Shadow For This Useful Post:
sharksinspace (02-18-2017), Vansquish (02-18-2017)
 Old 02-18-2017, 08:08 AM   #11
Fstrnyou's Avatar
You get used to it. I take my backpack (with laptop and cables inside) everywhere I go. Doesn't matter if I'm just going down the street to drop off trash, my laptop is with me.
Other rides:
History:
 Old 02-18-2017, 09:41 AM   #12
Omega's Avatar
Guy doesn't even realize hes hardly making extra power with bolt ons and no tune. Versatune would likely new too complex Shadow is right an AP would likely be the better bet for OP.
 Old 02-18-2017, 11:46 AM   #13
Groans: 76
AP definitely still has the convenience factor going in its favor, if you ask me.
2007 MS3
PD by Will
 Old 02-19-2017, 06:50 PM   #14
sheston's Avatar
Posts: 1,843   (View Stats)
There does seem to be a difference between OP and Madison, he left quicker.
Or maybe the car blew up and he doesn't need any help
Djohns likes this.
The Following User Says Thank You to sheston For This Useful Post:
 Old 02-19-2017, 07:50 PM   #15
Djohns's Avatar
Posts: 3,751   (View Stats)
Groaned at 7 Times in 6 Posts
I'm still pissed @Madison; left so quick. She was hot.
KiwiFlavor likes this.
2010 black mica speed3
Soon:built motor
Djohns is online now   Reply With Quote
The Following 2 Users Say Thank You to Djohns For This Useful Post:
KiwiFlavor (02-21-2017), SofaKingAwesome (02-21-2017)
 Old 02-19-2017, 08:19 PM   #16
Nailedit187's Avatar
Posts: 153   (View Stats)
Nailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond repute
Headers....did you do an LS swap? What dp do you have? Might be interested in it when zzb
Sent from my LG-D851 using Tapatalk
2007 MS3: CORKSPORT SRI, BS CBE, RED ROKBLOKZ, CAR SEAT MOD, EBAY TP, TURBOFART BPV
1995 CHEVY K1500
1968 CHEVY C20
2015 FZ09
CRF250R BUILT
Nailedit187 is offline   Reply With Quote
 Old 02-19-2017, 08:28 PM   #17
Yea me too. Better creep hard on her ig
1995 CHEVY K1500
1968 CHEVY C20
2015 FZ09
CRF250R BUILT
 Old 02-19-2017, 08:29 PM   #18
Djohns's Avatar
Meh. I do follow her but I don't care enough to creep haha.
Soon:built motor
 Old 02-20-2017, 07:10 PM   #19
sheston's Avatar
Are you guys talking about her boost creeping?
Still no OP return
 Old 02-20-2017, 07:21 PM   #20
g00s3y's Avatar
Groans: 410
@kade66; come back, we want to know what is happening with the car
The Following User Says Thank You to g00s3y For This Useful Post:
 Old 02-21-2017, 09:39 AM   #21
Thepedigree13's Avatar
Posts: 608   (View Stats)
Thepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the world
Groans: 64
It has been a long time since I have been on the forums. Been so busy with new career.
I can't believe I missed the release of headers for the platform. Good to see innovation still exists here.
Missed you guys.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs)
JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC)
Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+
》》》SUPPORT YOUR MSF VENDORS《《《
Thepedigree13 is offline   Reply With Quote
 Old 02-21-2017, 10:04 AM   #22
KiwiFlavor's Avatar
Posts: 2,275   (View Stats)
@Djohns; someone found her # on IG lolz!
OP PLEASE COME BACK!! I NEED SOME ENTERTAINMENT! SHOUT IS NOW DEAD!
2012 NASA Spaceship Gray MS3
BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front)
 Old 02-21-2017, 10:25 AM   #23
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 267
It's not thursday yet and you broke shout?
 Old 02-21-2017, 11:22 AM   #24
KiwiFlavor's Avatar
Probs!
monkey.bones.007 (02-21-2017)
 Old 02-21-2017, 02:14 PM   #25
monkey.bones.007's Avatar
Posts: 3,707   (View Stats)
Groans: 98
::kiwifail::
Crapatalk, it sucks for free!
monkey.bones.007 is online now   Reply With Quote
Page generated in 0.44221 seconds with 33 queries
