![]() | | #1 | ![]() |
![]() Join Date: Jun 2012 Location: Hooksett,NH
Rep Power: 437 ![]() Thanks: 75
(Thread Starter) | Not Ranked : 0 score I am in the middle of repalcing mine and ran into a snag. I cannot get leverage on the two lower bolts due to the alternator being in the way. I have removed the manifold shield as well as the alternator cooling shield. Are there any other brackets or shields I need to remove to get to the bolts? Are you guys getting all of them from the top?
__________________ -13' CWP MS3- JBR 88a Rmm // Full3 Aeros ID300 Intake // At Internals // UR Catless Tbe // JBR Occ // Forge V2 // Cobb FMIC // Ngk(6510)@.026 // Devils Own WMI // Freek Tune // Swift Springs 323hp/351tq SAE Sold // 12' Ms3 // 305hp 336tq SAE |
| Garage Queen ![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 2730 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,304
Groans: 53
From the top, closest to the block use a mid sized extension with a u-swivel and a deep 14mm socket. On the one closest to the fire wall just an extension. Use pb blaster and hulk strength There is also a how to in the review on the cobb DP by Haltech in the reviews section. Booyah!!! http://www.mazdaspeedforums.org/foru...-review-16310/
__________________ 2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail Cobb:Ap,Sri,Tip//JBR:Egr,Rsb,IM/TB Tigs,Rmm,Tmm//ATP:Catless long DP ETS:3.25" TMIC//M/D:OCC//Forge:v.2 BPV//AutoTech:FP Internals//PTP:Seals&studs Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:Coilovers//RotaGrids:18x9.5 Meth/E85/Nitrous TUNING BY LEX |
Thank You^^ After i cut my hand 3 times on that damn firewall shiled I finally got all the bolts off. The worst one is pictured below wth what I used. Snap on flex ratchet along with extensions and a wobble extension. Sorry for the worthless thread. ![]()
![]() | | #4 | ![]() |
![]() Join Date: Jun 2012 Location: Albuquerque, NM
Rep Power: 276 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
This is WAY easier if you take that whole metal cowl that the windhshield wiper motor sits in off. Its only a few bolts and gives you like 4 more inches of wiggle room. At least, thats how it is on the 6
__________________ 2006 Mazdaspeed6 - COBB AP, 3' Magnaflow CBE, Autotech HPFP, AEM CAI, NGK plugs, RMM, megan springs. 1995 Miata - adjustable Tokiko Illumina shocks, FM springs, HardDog M2 rollbar w/Single diagonal, GV rep front lip, Moss Miata braided lines, Flyin' Miata rear shock mounts. |
![]() | | #5 | ![]() |
Groans: 53
On the 3 you dont need to do that. On the 6 you need every inch you can get lol undoing the rmm helps too.
| The Following User Says Thank You to Sid3wayS For This Useful Post: | Colin1337 (07-14-2012) |
![]() | | #6 | ![]() |
![]() Join Date: Feb 2010 Location: Kailua
Rep Power: 552 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Make sure you tighten the fuck out of those lower bolts. When I was stocking out, my lower bolts were loose and I was missing the top closet to the exhaust mani. I did have all my motor mounts upgraded though. Anti-seize may not be a good idea.. I covered all mine with it. Not sure If it allowed the bolts back out from all the vibes.
![]() | | #7 | ![]() |
| FY"IED"N ![]() Join Date: Nov 2010 Location: Alexandria, VA
Rep Power: 514 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 913
Groaned at 6 Times in 4 Posts
and wear gloves.... you wont cut yourself
__________________ 2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint. ![]() |
![]() | | #8 | ![]() |
Groans: 53
| Not Ranked : 0 score QFT The first time I helped MS6FL do his I sliced my hand open n bathed his bay in blood. I just saw it as an offering to the mazda gods.
| The Following 3 Users Say Thank You to Sid3wayS For This Useful Post: |
![]() | | #9 | ![]() |
![]() Join Date: Dec 2011 Location: Red Deer,AB Canada
Rep Power: 1602 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,910
Groans: 121
Groaned at 49 Times in 15 Posts
Gloves are for pussys.
__________________ 2010 Mazdaspeed 3 Black Mica w/ Tech Package Insalled: Corksport SRI/TIP // Cobb AccessPort// Autotech Internals // Corksport LED Kit // Corksport Stubby Antenna // Forge v2 BPV // JBR SSP// JBR 80a RMM // JBR Weighted Shift Knob // ETS TMIC // Corksport Catless Downpipe // Corksport RacePipe // Denso itv22 // Stratified Guardian Angel // block8head Defrost Pod // Prosport Boost Gauge // Zoom Boom Box Awaiting Install: HTP 3" TIP // HTP Battery Tray // Sure 3" MAF // Stratified Boost Dial |
![]() | | #10 | ![]() |
![]() Join Date: Jun 2012 Location: Yukon, OK
Rep Power: 140 ![]() Thanks: 238
Which down pipe did you buy an install if you don't min me asking... I am trying to decide what I want...
__________________ 2012 MAZDASPEED3 W/ TECH PACKAGE - COBB SRI - COBB TIP - COBB FMIC - COBB AP - CP-E RMM - JBR 80 DURO PMM AND TMM - AUTOTECH FUEL PUMP INTERNALS - JBR STAGE 2 SSP AND SOLID BUSHINGS - CP-E CATTED DOWNPIPE - CP-E TRITON CBE - FORGE V2 BPV - CORKSPORT OCC - DEVILS OWN DVC-30 WMI - NGK LTR7IX-11 PLUGS - 18" KONIG BACKBONES W/ PIRELLI PZEROS - FREEK TUNED |
![]() | | #11 | ![]() |
| The Cone Killer ![]() Join Date: Nov 2010 Location: Miami, Florida
Rep Power: 511 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,720
Groans: 40
__________________ Ariel![]() COBB SRI/TIH/XLE/ECBS/AP/Knob, PnP'ed IM, ETS TMIC, Autotech FP internals, Guardian Angel, M2 DP, JBR SSP/EGR Delete, AWR 88 RMM, SURE Dreadnaught/Juggernaught, Whiteline RSB, MD OCC, IM/TB TIGs, Battery Relocate, Trunk Monkey, ITV 22s, Rotella T6, Eibach Pro kit springs, Powerslot rotors, Hawk HP+ Pads, SS lines, 18x8.5 +42 Focal F16s, 235/40/18 NT05s "Eyes for an eye, Teeth for a tooth." | |
![]() | | #12 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ultimate Racing Catless
![]() | | #13 | ![]() |
| Not Ranked : 0 score i wear gloves...and diffuse bombs for a living. i'm a huge pussy
| The Following 3 Users Say Thank You to dMuze For This Useful Post: |
| Downpipe install help! | eb2292 | 2010 MS3 - Engine, Transmission & Driveline | 23 | 01-23-2012 09:22 AM |
| Downpipe install | Jkelley | MazdaSpeed 3/6 - Turbo Induction | 10 | 02-10-2011 02:39 AM |
