 Old 07-01-2013, 07:49 AM   #1
mxrider518's Avatar
Posts: 34   (View Stats)
mxrider518 has much to be proud ofmxrider518 has much to be proud ofmxrider518 has much to be proud ofmxrider518 has much to be proud ofmxrider518 has much to be proud ofmxrider518 has much to be proud ofmxrider518 has much to be proud ofmxrider518 has much to be proud ofmxrider518 has much to be proud of
Default Enough Transmission fluid?
I just did a transmission oil change on my MS3, I put in a full 3 quarts of MT90 and it did not seem to be full to the point that is was coming back out of the fill hole? I hope there is enough in there, what would I notice if there wasn't?
mxrider518 is offline   Reply With Quote
 Old 07-01-2013, 07:53 AM   #2
BigBoostMS3's Avatar
Posts: 1,429   (View Stats)
BigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the world
Did you fill it with only the front on jack stands? If the car isn't level that will change the amount it takes. 2.5 liters or 2.6 quarts is all it needs.
Scott
Mazda Dragon Camp - Event Coordinator
// PTE 5858 // FREEKbuilt & tuned \\ M-1 Meth\\
www.TorqueSteerStickers.com
BigBoostMS3 is offline   Reply With Quote
 Old 07-01-2013, 08:05 AM   #3
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I always refill once the car is back down on even ground. Usually takes 2.8 ish before it starts running back out.
 Old 07-01-2013, 08:07 AM   #4
mxrider518's Avatar
Ya I filled it with a jack only, so the car was tilted slightly and that was probably exaggerated more so by the slope of my driveway, should I drain some? What kind of damage could be done?
Ok, well three bottles of mt90 is 2.85 so maybe it is only slightly over filled and ok?
Last edited by mxrider518; 07-01-2013 at 08:07 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-01-2013, 08:18 AM   #5
evil MS3's Avatar
Posts: 1,294   (View Stats)
evil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the worldevil MS3 is the leader of the world
Groans: 55
Put it on level ground, open the fill bolt and let whatever overage drain out. Pretty simple for piece of mind.
evil MS3 is offline   Reply With Quote
The Following User Says Thank You to evil MS3 For This Useful Post:
SpeedThrizzle (07-01-2013)
 Old 07-01-2013, 08:49 AM   #6
mxrider518's Avatar
Put it on level ground and drained some. Surprisingly, only drops came out.
Transmission fluid question MazdaSpeed3NY MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-19-2012 11:43 AM
Transmission Fluid Crazyspeed3 Mazdaspeed3/6 General Discussion 6 12-23-2011 06:32 PM
Adding Transmission Fluid Justin Lee MazdaSpeed 3 - Engine, Transmission & Driveline 8 04-21-2011 08:27 PM
Gen 2 transmission fluid consensus paradigme 2010 MS3 - Engine, Transmission & Driveline 15 07-10-2010 07:21 PM
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A Haltech Automotive News 0 05-15-2009 03:10 PM
Page generated in 0.26415 seconds with 23 queries
