 Old 11-11-2017, 11:29 AM   #1
espenc's Avatar
Posts: 9   (View Stats)
espenc is an unknown quantity at this point
Default Ford XT-M5-QS Issue
Anyone here have issues with this oil? I recently started using this in my 2012, been noticing very poor shifting from 1-2 especially when cold, occasionally when warm.
espenc is offline   Reply With Quote
 Old 11-11-2017, 02:31 PM   #2
Djohns's Avatar
Posts: 3,925   (View Stats)
Groans: 105
Had the same issue. That oil is more geared towards gen Juan guys. For a pu I would recommend redline. I switched over to that in mine and I love it. Much better than the ford stuff.
2010 black mica speed3
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
AveryPlaysBass (11-14-2017)
 Old 11-11-2017, 02:45 PM   #3
alden's Avatar
Posts: 397   (View Stats)
alden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant future
Yea I changed mine a few months back with the ford stuff. Much ragrets. I'll be switching to Redline sooner than later.
alden is offline   Reply With Quote
 Old 11-11-2017, 04:55 PM   #4
espenc's Avatar
Huh. I will have to give the Redline a try. Its kinda odd that it works well in the gen juan's but not as much in the pu's...
 Old 11-14-2017, 10:48 AM   #5
nekret's Avatar
Posts: 419   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
FWIW I switched to Torco RTF and noticed significant cold weather improvement over the Redline.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 11-14-2017, 12:27 PM   #6
Db09ms3's Avatar
Posts: 254   (View Stats)
Groans: 58
Works great in my GenWon '09. I believe the weight did change between gens
 Old 11-14-2017, 01:15 PM   #7
5doorsoffury's Avatar
Posts: 1,030   (View Stats)
Groans: 74
Funny it has worked fine for me? There are many threads on unicorn tranny jizz and some people needed friction modifier some didn't some went redline so its up to the owner. The fuckin price of that shit was so much that i am not up to trying diffrent fluids out lol.
MECP
2012 BM
Rfinkle tune in progress
 Old 11-14-2017, 01:21 PM   #8
AveryPlaysBass's Avatar
Posts: 278   (View Stats)
AveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Damn i thought i was the only genpu that switched to Ford and was not all that thrilled with it. What would be a good recommendation for 2nd gens, Redline?
It's OK to cry" - Lil B
2012 MS3 w/Tech Package
Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, CFM Mount, CS Racepipe, Resonator delete, Tuned by FREEKTUNE
Trans: CS insert, CS bushings, Damond Shifter Plate
Suspension: Koni Orange with CS springs, Konig Controls 17x7.5 with 225/45 Conti DW's
Appearance: Plasti Dipped Emblems, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers
AveryPlaysBass is offline   Reply With Quote
 Old 11-14-2017, 02:01 PM   #9
aackthpt's Avatar
Posts: 1,449   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
Redline MTL. Just buy the gallon: https://www.amazon.com/Red-Line-5020.../dp/B002INJ69I
I've got it in now. For me, no real difference from the Ford juice, which was no real difference from factory fill. On the other hand no complaints and the whole gallon was cheaper than 3 quarts of Ford.
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
The Following User Says Thank You to aackthpt For This Useful Post:
 Old 11-15-2017, 09:32 AM   #10
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Here's what I got, one of the best deals since our transmissions need approx a little less than 3qt. For Redline 75w90
Redline special 3qts
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
The Following User Says Thank You to Bexar For This Useful Post:
AveryPlaysBass (11-15-2017)
 Old 11-15-2017, 11:53 AM   #11
aackthpt's Avatar
Good call! Same deal for MTL: https://www.ebay.com/itm/Red-Line-Oi...T/182738268188
MTL fits the specs from the manual better, at least for later years (not sure if the spec changed over the years). But reading the descriptions and specs there appears to be so little difference between MT-90 and MTL that it probably doesn't matter much.
Stage Bro
 Old 11-15-2017, 12:06 PM   #12
Bexar's Avatar
Hmmm...so did I get slightly the "wrong" one? I still haven't done the fluid change so I've still got the unopened bottles.
JBR:
 Old 11-15-2017, 04:17 PM   #13
aackthpt's Avatar
Check your manual but I just downloaded the 2013 ms3 manual from the Mazda site, it says GL-4 and 75w-80.
MTL says 75w80 in the title: https://www.redlineoil.com/mtl-75w80-gl-4-gear-oil
but also says "Satisfies the gear oil viscosity requirements of 75W, 80W and motor oil viscosities of SAE 30, 10W30 and 5W30"
MT-90 says 75w90 in the title: https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil
but also says "Satisfies the gear oil viscosity requirements of 75W90, 80W90, 90 and motor oil viscosities of SAE 40, 10W40 and 15W40"
Both say GL-4, syncromesh, etc etc blah blah blah. Interestingly there is a fair bit of viscosity difference between 80 and 90 weight oils: SAE viscosity grades ? viscosity table and viscosity chart
...80 -> 8.02-11.0 and 90 -> 13.13-18.5 ....I'm surprised it's that much different. Normal engine oil doesn't have nearly that much difference between 30 and 40 weight for example.
Stage Bro
The Following 2 Users Say Thank You to aackthpt For This Useful Post:
Bexar (11-15-2017), krimsonviper (11-21-2017)
Ford recalls new Escape SUV over braking issue Haltech Automotive News 0 07-15-2012 02:20 PM
Ford recalls 20,000 small pickups for light issue Haltech Automotive News 0 07-20-2011 09:00 PM
Ford Fusion, Mercury Milan probed for mat issue Haltech Automotive News 0 06-01-2010 09:40 PM
Ford-CAW talks continue, but key issue not met Haltech Automotive News 0 09-23-2009 12:50 PM
Ford, Nissan issue $4.25 billion in securities Haltech Automotive News 0 03-18-2009 11:50 AM
Page generated in 0.34256 seconds with 28 queries
