Notices
  • 1 Post By Matt H.
 Old 06-04-2012, 02:15 PM   #1
peter_parker8740's Avatar
Posts: 65   (View Stats)
peter_parker8740 has a spectacular aura aboutpeter_parker8740 has a spectacular aura about
Default full motor mount install.... now have knocking sound
Well I have all my cp-e mm installed. Had the rmm and passenger side mm in for about 3-5 thousand miles on each. Finally installed the transmission mm last week. I now have a knocking sound when shifting from 1st to 2nd in high rpm. Before its asked yes they are all torqued to proper spec and none of the bushing are bad on the mms. Any thoughts to what else it could be ?
Thank you for your time
AMERICA
peter_parker8740 is offline   Reply With Quote
 Old 06-20-2012, 05:17 PM   #2
Matt H.'s Avatar
Posts: 55   (View Stats)
Matt H. is a glorious beacon of lightMatt H. is a glorious beacon of lightMatt H. is a glorious beacon of lightMatt H. is a glorious beacon of lightMatt H. is a glorious beacon of lightMatt H. is a glorious beacon of light
I can't speak for having all mounts but when I installed my stage 2 rmm from cpe it didnt take.long for me to notice that since I had to push the Engine forward to install it I had no idea until later that it seemed to keep the bottom of the engine pushed forward inturn I think pulls on the exhaust I looked at my exhaust which is cpe catted Downpipe and corksport three inch catback and found all hangers are pulled forward if there is a solution I would like to know what it is. Not sure if this is what you are dealing with but my exhaust was hitting on the center cross member and at the first turn
Kade likes this.
Matt H. is offline   Reply With Quote
 Old 06-20-2012, 05:21 PM   #3
Able
helmetface's Avatar
Posts: 4,408   (View Stats)
Groans: 124
Is this with your foot on the clutch? Or before/after engagement?
My story is similar, I'm putting my JBR side mounts, first the TMM till I become used to the noise. Anyhow, after installation I experience what I find to be similar to your description.
I would say it's normal it's normal if the bolt is seated correctly and all the adjacent bolts are tight.
CP-E Rear Motor Mount Install PiKA West 2010 MS3 - How-To's 52 01-19-2011 01:40 PM
Rear motor mount install mzdaspeed3 2010 MS3 - Engine, Transmission & Driveline 18 12-06-2010 05:42 PM
PMM failure + AWR passenger motor mount install jamesthebikeguy MazdaSpeed 3 - Engine, Transmission & Driveline 19 11-23-2010 08:08 PM
Should I get inserts or full motor mount? HLR Element MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-25-2009 08:27 PM
TRZ motor mount install Pics + thoughts jamesthebikeguy MazdaSpeed 3 - Engine, Transmission & Driveline 19 07-17-2009 04:04 PM
Page generated in 0.27218 seconds with 22 queries
