 Old 02-24-2013, 08:33 AM   #1
TheRealDefman's Avatar
Posts: 532   (View Stats)
TheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the world
Default Injector seals - need to replace injector/fuel line O-rings?
Reviewing the cp-e directions for the SAFEseals and they advise replacing the blue injector O-ring and the high pressure fuel line O-ring. I've read a bunch of threads about replacing injector seals and don't recall seeing anyone else mentioning this.
Necessary?
(Since cp-e doesn't post a link to the install PDF on their site that I can find, Google "mzr high pressure fuel line o-ring" and you'll find it.)
2012 Black Mica with Tech package.
Chock full of goodies and Dizzy tuned
TheRealDefman is offline   Reply With Quote
 Old 03-02-2014, 08:19 PM   #2
mrinjector516's Avatar
Posts: 11   (View Stats)
mrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond repute
Default Injector "O" ring replacement.
Yes always a good idea when replacing Injectors.Cheap Insurance too,against volatile fuel leaking at high pressures onto potentially hot engine parts and having to spend another four hours ? having to do it right,the second time.
mrinjector516 is offline   Reply With Quote
 Old 03-02-2014, 08:28 PM   #3
LatinKraze's Avatar
Posts: 804   (View Stats)
LatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the world
Recommended but I didn't
2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD
2016 CX-5 GT AWD
LatinKraze is offline   Reply With Quote
 Old 03-02-2014, 08:35 PM   #4
alphasaur's Avatar
Posts: 2,847   (View Stats)
alphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the world
Groans: 235
Groaned at 60 Times in 48 Posts
Make sure you lube them shits.
/91 miata with basic suspension bits
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/possessed speed 6- dead ((((((
/lol nator.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
LatinKraze (03-02-2014)
Cp-e injector seals - fuel pump internals - etc kpsoerensen MazdaSpeed 3 - Engine, Transmission & Driveline 4 01-22-2012 09:08 PM
Fuel Injector Seals starscream MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 06-07-2011 05:27 AM
fuel injector seals kachow22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-15-2009 07:28 PM
Page generated in 0.25584 seconds with 23 queries
