jbr bushing install observation well i was installing my bushings today and realizes a couple things. the first being, you do not need to remove the two kick panels in the first step of the instructions. i skipped this all together and was fine. i had these bushings on my gen 1 as well and never knew if i felt that much of a difference. well, i looked at the stock metal sleeve and noticed one was bent out of shape pretty bad. if anyone is wondering about the effectiveness of these bushings, here is a picture of what may already have happened to the weak stock bushings... my car only has 2500 miles on it. the top sleeve in each shot. when looking at the shifter cage, this was the bottom left sleeve. hope this helps someone http://img577.imageshack.us/img577/2873/bushing1.jpg http://img16.imageshack.us/img16/7735/bushing2.jpg |
brand new car here and i think this may be the culprit i heard last night while getting on it |
Weird. Looks like they are all different. I didn't notice that with mine. |
How much improvement did you notice with the JBR bushings? |
Not much really at least on my car I didn't notice any drastic changes. But I think its worth it. I think the jbr are the cheapest and they all do the same thing. |
shit mine came out like the op's and it was a crazy change when installing |
I just looked at mine I still have them, they look the same. I have 2 with bigger holes, 1 with a smaller hole, and 1 with an oval like yours. Maybe its supposed to be like this? |
Or its forces applied when sprited driving causing the bending. All 4 of mine were more long then round. |
2 should be big round and 2 should be small round... the long oval ones are from stresses. like i said these aren't a drastic change, but... seeing as the stock ones were already giving way, i feel like they are a worth while mod (very cheap) |
with the bushings felt more soild smooth but other then that nothing really |
Wow I guess the stock bushings are really weak, mine only had ~1700 miles when I put them in. |
I'm thinking it's actually normal and they are supposed to look that way. Or at least come that way from the factory. Mine and another local's bushings look the same. FWIW. |
Mine looked the same as well. I'm pretty sure one of them is oval from the factory. |
here are mine...300 miles on the car when i changed them. the japanese must know something that we don't. the ones on my 3 GT were also shaped as such. this is the pattern when they are in the cage, looking down. that oval shaped one and the different sized holes...fuckin weird. http://s13.postimage.org/w5km3w547/bushings_small.jpg |
| All times are GMT -7. The time now is 01:53 AM. |
