 Old 11-08-2019, 08:36 PM   #1
DadliMS3's Avatar
Posts: 13   (View Stats)
DadliMS3 will become famous soon enoughDadliMS3 will become famous soon enough
Default leaking transmission
A few weeks ago, I changed the oil in my MS3 for the first time since it was imported and noticed that there seemed to be oil residue/leakage around the transmission housing. Could it be a worn seal? at present the car has done just over 102k km, and i am planning to change the timing belt and sometime next year upgrade the engine mounts..
DadliMS3 is offline   Reply With Quote
 Old 11-11-2019, 12:13 PM   #2
GohanX's Avatar
Posts: 62   (View Stats)
GohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to behold
Probably the shaft pivot seal, my 6 is doing the same thing.
HOW-TO: shaft pivot seal replaced
How to is for the Speed 6, it's a little easier with a 3.
GohanX is offline   Reply With Quote
The Following User Says Thank You to GohanX For This Useful Post:
DadliMS3 (11-12-2019)
 Old 11-11-2019, 02:09 PM   #3
Jeff23spl's Avatar
Posts: 2,232   (View Stats)
it depend where the oil is coming from, pivot seal, axles seal or else ?
there is no timing belt but a chain, it could be loose and need replacement. you can found infos on the how too vvt thread but you will see it isn,t an easy job and on a second gen, you do it only when it is loose.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 11-12-2019, 07:07 AM   #4
Rose City Speed6's Avatar
Posts: 55   (View Stats)
Rose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to all
Groaned at 3 Times in 1 Post
It was axle seals for my Speed6.
Rose City Speed6 is offline   Reply With Quote
The Following User Says Thank You to Rose City Speed6 For This Useful Post:
 Old 11-12-2019, 10:51 AM   #5
DadliMS3's Avatar
Thank you, I was wondering if it was that.
 Old 11-12-2019, 12:56 PM   #6
DadliMS3's Avatar
i bought a belf for the alternator the day. but is definitely oil residue by the tranny. More towards the bottom end. noticed it when I was changing the oil.
The car has just done 103k km and i can imagine now is the time to update alot of things on it including seals etc.
Last edited by DadliMS3; 11-12-2019 at 12:56 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-12-2019, 02:03 PM   #7
deuce_WI's Avatar
Posts: 234   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
If the breather near the pivot shaft seal is clogged / bad, fluid will blow past the pivot shaft seal. If you replace one, I would just do both.
deuce_WI is offline   Reply With Quote
 Old 11-12-2019, 02:57 PM   #8
Jeff23spl's Avatar
clean it with brake cleaner and check again in a week to see where it comes from.
btw check fluid level asap to make sure there is enough
Wife drive 2010 CX7
 Old 11-12-2019, 04:22 PM   #9
DadliMS3's Avatar
When you say fluid level what fluid are you refering to?
 Old 11-13-2019, 06:43 AM   #10
Jeff23spl's Avatar
You talk about transmission leak...it would be logic to check fluid level on what it is leaking
Wife drive 2010 CX7
Leaking Transmission - MS3 Gen1 mktx01 MazdaSpeed 3 - Engine, Transmission & Driveline 1 04-12-2017 03:05 PM
Transmission Change Cover is Leaking embiggenedmini MazdaSpeed 6 - Engine, Transmission & Driveline 2 04-26-2016 02:06 PM
Transmission Leaking Mattyhawk1 MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-02-2015 08:57 AM
leaking transmission after downpipe install sundowned MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 06-08-2013 12:24 AM
Leaking something out of the transmission/transfer case I think. scnewt MazdaSpeed 6 - Engine, Transmission & Driveline 25 03-19-2013 06:46 AM
Page generated in 0.30281 seconds with 24 queries
