Like Tree54Likes
 Old 02-03-2017, 11:18 AM   #1
Madison's Avatar
Posts: 18   (View Stats)
Madison is a name known to allMadison is a name known to allMadison is a name known to allMadison is a name known to allMadison is a name known to allMadison is a name known to all
Groaned at 6 Times in 3 Posts
Default Is my car going to blow up?
Hi guys! Pretty new to these forums, I just got my 2010 ms3 in September. It came with an intake, a blowoff valve, and a test pipe as far as I know. I just got an AP and loaded a stage 1 tune. and my hpfp reading is mid-high 1700's with boost around 15. Based on this, can you tell if my fuel pump internals have been upgraded? Are there any other mods I should be running with the AP to avoid problems? Any preventative maintenance I should do to avoid problems? Please give me all the advice you have!
Madison is offline   Reply With Quote
The Following 4 Users Say NO Thank You to Madison For This Un-useful Post:
g00s3y (02-03-2017), MD1032 (02-03-2017), stockms3 (02-03-2017), Vansquish (02-03-2017)
 Old 02-03-2017, 11:25 AM   #2
Bingo's Avatar
Posts: 684   (View Stats)
Groaned at 9 Times in 7 Posts
This first post is textbook. You've ticked all the boxes. Well done.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Moog endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges.
The Following 3 Users Say Thank You to Bingo For This Useful Post:
AwAfrican (02-04-2017), Code Monkey (02-03-2017), Thor Hammer (02-04-2017)
 Old 02-03-2017, 11:25 AM   #3
Mattyhawk1's Avatar
Posts: 731   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
Same as what has been said for years, only way to really know for sure is to pull the HPFP and physically check the internals. Otherwise you are just guessing.
At your 15psi boost levels, you are not going to tell if they are installed or not.
Mattyhawk1 is offline   Reply With Quote
The Following 3 Users Say Thank You to Mattyhawk1 For This Useful Post:
KiwiFlavor (02-03-2017), MD1032 (02-03-2017), Vansquish (02-03-2017)
 Old 02-03-2017, 11:28 AM   #4
Madison's Avatar
Why is that? If the boost was a different number would that make it obvious they had been installed?
The Following User Says NO Thank You to Madison For This Un-useful Post:
 Old 02-03-2017, 11:31 AM   #5
tek_88's Avatar
Posts: 93   (View Stats)
tek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to behold
Groaned at 13 Times in 2 Posts
I guess people don't know how to search now a days. Most if not all questions can be answered by searching. To answer your question, there is no way to tell if your internals are stock or not without taking it out.
2006 Titanium Grey MS6
Power
BNR S3 // Stock downpipe (hollowed) // Test pipe // Magnaflow CBE // Cp-e Tmic // 3" HTP // JBR Boost Tubes // JBR Thermal Gaskets // 3Bar Map // Corksport BPV // Egr Block-off // VTCS Disabled // AEM 100% meth (1000cc nozzle) // Cobb Ap V3 // Autotechs // GS 3-port // NGK 6510 // CA 91 oct
PurpleDrank Tuned by Will
Hardware
Cp-e Rear Diff Mount // SURE Juggernaut Front Diff Mount // AWR PMM // Cp-e RMM // Corksport TMM Inserts // DSS Axles // ACT 6-puck w/ Streetlite FW
Cosmetics
TRS Retrofit Bi-Xenon Projectors // 18x8.5 +35 XXR 557 // H&R Lowering Springs // S204 Lip
tek_88 is offline   Reply With Quote
The Following 2 Users Say Thank You to tek_88 For This Useful Post:
 Old 02-03-2017, 11:34 AM   #6
g00s3y's Avatar
Posts: 2,104   (View Stats)
Groans: 422
Nudes or no questions get answered
If that's you in the avatar...
The Following 6 Users Say Thank You to g00s3y For This Useful Post:
AwAfrican (02-04-2017), CJ Speed6 (02-13-2017), KiwiFlavor (02-03-2017), MikeBavaro (02-06-2017), monkey.bones.007 (02-07-2017), WetzMS3 (02-03-2017)
 Old 02-03-2017, 11:35 AM   #7
Madison's Avatar
You know, I really did search a bunch of things to try to figure it out because I knew people like you would tell me it's already been answered but I honestly just don't know enough about this yet to be able to look at another thread where someone is describing what mods they have on their car and know how the advice given would be different if applied to my car with my specific mods. So to avoid having my car blow up because I was too afraid to ask, I figured id just ask. 👍🏻
deepthinker22 likes this.
 Old 02-03-2017, 11:37 AM   #8
KiwiFlavor's Avatar
Posts: 2,392   (View Stats)
+ Infinity
@Madison; you're going to need to open up your HPFP to be able to see if it has upgraded internals. I've said this a few times, but it's just a matter of WHEN it'll fail.
sharksinspace likes this.
2012 NASA Spaceship Gray MS3
 Old 02-03-2017, 11:39 AM   #9
Madison's Avatar
Hahahaha it is me in the avatar, I guess I'm not getting any questions answered then 😬 Hahah
So I guess I need to know how big of a deal this is like do I need to run home and open it up this weekend to be sure? Or worst case if I don't get around to it and it fails is my engine then blown up? Or would it just be a matter of replacing it and everything would be okay?
Last edited by Madison; 02-03-2017 at 11:39 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Madison For This Useful Post:
g00s3y (02-03-2017)
 Old 02-03-2017, 11:52 AM   #10
KiwiFlavor's Avatar
As long as you don't go pedal to the metal and WOT all the time you'll be fine. You really should get that taken care of soon tho. Genpu is not as tolerant as genjuan once you start putting flow mods (intake, test pipe)
 Old 02-03-2017, 12:00 PM   #11
Madison's Avatar
Okay thank you! Also what's your opinion on gas catch can and boost control? Someone told me I should get those but I'm not too sure. Alsooo should I upgrade spark plugs/check if they've been upgraded? What about coil packs? Should I just wait for those things to go out before I do anything?
 Old 02-03-2017, 12:14 PM   #12
sharksinspace's Avatar
Posts: 749   (View Stats)
Groans: 117
Oil* catch can; good for keeping the valves cleaner.
Car already has a factory EBCS; not a main point of upgrade on stock turbo unless you break the OEM piece.
2007 MS3
PD by Will
The Following User Says Thank You to sharksinspace For This Useful Post:
 Old 02-03-2017, 12:32 PM   #13
Police - Grammarhead
Vansquish's Avatar
Groans: 1,793
Groaned at 44 Times in 25 Posts
@Madison;, it is impossible to determine from any readings on the AP (much less datalogs) whether the HPFP internals have been upgraded. The OEM internals can hit over 2000psi, and so can aftermarket HPFP internals.
Literally the only way to determine what is inside the pump is to physically remove the pump from the vehicle, dismantle it, and check what's inside.
The Following 2 Users Say Thank You to Vansquish For This Useful Post:
g00s3y (02-03-2017), KiwiFlavor (02-03-2017)
 Old 02-03-2017, 12:37 PM   #14
MD1032's Avatar
Posts: 2,621   (View Stats)
Groans: 139
And then there's me. The first mod I did to my car was fuel pump internals because I logged fuel pressure dips to about 13-1400 psi at WOT when my pu was bone stock using Torque Pro...didn't even have an AP at the time.
Your best bet is to reach out to someone in your area (go into one of the nator regional forums on the boards and ask for help there) to help you take the fuel pump apart. It is really easy with a second pair of experienced hands. As a girl you shouldn't have too much trouble recruiting assistance.
KiwiFlavor likes this.
2007 Mazdaspeed3 GT
The Following User Says Thank You to MD1032 For This Useful Post:
 Old 02-03-2017, 12:38 PM   #15
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
pull dem internals bruh
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
The Following 4 Users Say Thank You to WetzMS3 For This Useful Post:
CJ Speed6 (02-13-2017), Mazdazilla6 (02-04-2017), MD1032 (02-06-2017), MS3Shadow (02-03-2017)
 Old 02-03-2017, 12:52 PM   #16
Yatta's Avatar
Posts: 1,862   (View Stats)
Yatta has disabled reputation
a hole in your block... higher boost = more fuel.... if the internals can’t hold it the pressure will drop, you will lean out and it will become quite obvious that you don’t have upgraded internals... it takes about 1 hour to remove, inspect and refit..... the how-to’s are on this site...
 Old 02-03-2017, 01:23 PM   #17
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 275
Breh, just pull the internals.
Sent from my Pixel XL
The Following 3 Users Say Thank You to MS3Shadow For This Useful Post:
KiwiFlavor (02-03-2017), MD1032 (02-06-2017), Yatta (02-03-2017)
 Old 02-03-2017, 01:31 PM   #18
WetzMS3's Avatar
Groans: 430
like an electrical connector, 3 bolts, and a flange nut. yank dem internals out and stoke em good to verify they are upgraded bro
2013 MS3 Black Mica
MD1032 (02-06-2017)
 Old 02-03-2017, 01:32 PM   #19
KiwiFlavor's Avatar
 Old 02-03-2017, 01:47 PM   #20
Code Monkey's Avatar
Posts: 7,635   (View Stats)
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
MCS coilovers|Brembo BBK|6UL 17x9|Nitto NT01|ACE 350|Delicious tuned
2000 E39 M5
2001 MR2 2ZZ
 Old 02-03-2017, 02:29 PM   #21
g00s3y's Avatar
Groans: 422
I can help check your internals...
I'm talking about the car...
You guys have dirty minds...
The Following 3 Users Say Thank You to g00s3y For This Useful Post:
KiwiFlavor (02-03-2017), MD1032 (02-06-2017), sharksinspace (02-03-2017)
 Old 02-03-2017, 02:37 PM   #22
Djohns's Avatar
Posts: 3,883   (View Stats)
Groans: 105
I can also help check your internals.
I'm not talking about the car
You have the correct mindset.
sharksinspace and KiwiFlavor like this.
2010 black mica speed3
Soon:built motor
The Following 4 Users Say Thank You to Djohns For This Useful Post:
impossible (02-07-2017), KiwiFlavor (02-03-2017), MD1032 (02-06-2017), sharksinspace (02-03-2017)
 Old 02-03-2017, 04:12 PM   #23
Groans: 117
P.S. You're named after the city I live in and I only 10% believe you're real.
KiwiFlavor and Biobandit like this.
2007 MS3
PD by Will
 Old 02-03-2017, 05:10 PM   #24
sheston's Avatar
Posts: 1,844   (View Stats)
I didn't see it explicitly said but if you increase boost, you need more fuel. You also run the risk of KR which tells the ECU to add fuel and run richer. Flow mods like intake and test pipes usually increase boost. I didn't see where you are from, but colder weather also can increase boost and airflow, needing more fuel. The problem with just monitoring fuel is by the time the fuel pressure drops, it can be too late. Checking and replacing the HPFP internals is the safest thing you can do. It probably doesn't need to be done before you drive more, but try not to race too many Mustangs before you do :-)
Otherwise, changing the oil with a good oil (I choose Rotella) more than regularly I feel is the other best preventative medicine for these cars.
I'm not a big fan of gas catch cans or oil catch cans (they are supposed to catch the blow by oil and keep it out of the intake and valves), and wouldn't think you should need one at your level. As far as a boost controller, your AP does that as pointed out earlier.
I'm a believer in pay it forward, so.....
 Old 02-03-2017, 06:00 PM   #25
stockms3's Avatar
Posts: 823   (View Stats)
Groans: 68
Groaned at 6 Times in 6 Posts
I can see where you are coming from as without much knowledge this forum can be overwhelming. You really do need to study what everything is. These cars are fun little rockets but without knowing simple stuff, I suggest you don't do any more mods.
If you want help don't ask questions like will my car blow up. What you can do is learn how to do a data log and have people look at your log. However, a better option would be to physically open the fuel pump, and verify if it is upgraded or not. Then, pay a etuner to tune your car.
Also, from your description I can tell your car is going to explode. I would stop driving immediately. /s
2007 TR MazdaSpeed3:Autotech FP inernals, Cobb AP, Toyota Injector Seals, FR stud mod, FMIC, Fidanza flywheel/stock clutch, Forge BPV, CorkSport Stage 2 RMM, COBB SRI/PG Inlet pipe, Wiseco .20 Pistons/Manley Rods/BSD, DM/ebay catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, CNT catback
Soon to come: CS turbo, TR8 front mount, JBR 3" intake, EBCS, and maybe a clutch.
2005 Mazda 3 SP23: mod include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
The Following User Says Thank You to stockms3 For This Useful Post:
 Old 02-04-2017, 01:41 PM   #26
AwAfrican's Avatar
Posts: 1,036   (View Stats)
Why is this thread still growing? She said she wasn't going to get her questions answered....Which means we aren't getting nudes
OP: pull your hpfp and check, the gen2 ms3 don't even like having just an intake on without upgraded hpfp internals. However given that they're showing 1700psi you're probably fine, my upgraded internals show 2000psi under wot to give you an idea.
2013 Black MS3
 Old 02-04-2017, 02:30 PM   #27
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Never pull out.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
KiwiFlavor (02-05-2017)
 Old 02-04-2017, 03:52 PM   #28
Djohns's Avatar
Groans: 105
Mostly because if that avatar really is OP, she's pretty damn good looking. If this was a male it would have went 1 of 2 ways. 1. No one responds. Or 2. Everyone responds, flaming the fuck out of him.
AwAfrican and danb like this.
Soon:built motor
 Old 02-04-2017, 06:32 PM   #29
sheston's Avatar
I posted some answers hoping for some more pics :-)
 Old 02-04-2017, 06:47 PM   #30
Nailedit187's Avatar
Posts: 153   (View Stats)
Nailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond repute
Shit. If it was me I'd already have my own thread full of nudes. That way i could get anything i wanted
Biobandit likes this.
2007 MS3: CORKSPORT SRI, BS CBE, RED ROKBLOKZ, CAR SEAT MOD, EBAY TP, TURBOFART BPV
1995 CHEVY K1500
1968 CHEVY C20
2015 FZ09
CRF250R BUILT
Nailedit187 is offline   Reply With Quote
 Old 02-04-2017, 07:18 PM   #31
g00s3y's Avatar
Groans: 422
Old MSF would have had black ops already find out if it's really a man or a woman, and then flame regardless of gender.
Djohns (02-05-2017), KiwiFlavor (02-05-2017), WetzMS3 (02-06-2017)
 Old 02-04-2017, 07:29 PM   #32
AwAfrican's Avatar
And this gents is why we scare some of the ladies away haha. One can only hope though
Nailedit187 likes this.
2013 Black MS3
 Old 02-04-2017, 11:15 PM   #33
Thor Hammer's Avatar
Posts: 1,428   (View Stats)
Groans: 132
I call BS. Prove it.
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
 Old 02-05-2017, 06:48 AM   #34
Biobandit's Avatar
Posts: 204   (View Stats)
Biobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the world
Inb4 "she" starts posting dick pics
Sent from my ONE A2005 using Tapatalk
danb likes this.
Biobandit is offline   Reply With Quote
The Following User Says Thank You to Biobandit For This Useful Post:
 Old 02-05-2017, 07:55 AM   #35
WAMBUSHHHH!'s Avatar
Posts: 1,596   (View Stats)
WAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the world
I thought it was understood that this place loves the cawk so we've been subtly sabotaging ourselves by scaring the tits away to allow more room for the dick..
2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017
2017 LGM Golf R - South Bend stage 3 daily clutch / DFG intake / Wagner IC / AWE downpipe / Indvidia catback
2004 Yamaha R6 - Micron Ricer Pipe / PC
2005 Honda CBR 600 F4i - R.I.P. 10/29/13
WAMBUSHHHH! is offline   Reply With Quote
The Following 2 Users Say Thank You to WAMBUSHHHH! For This Useful Post:
AwAfrican (02-05-2017), KiwiFlavor (02-05-2017)
 Old 02-06-2017, 11:04 AM   #36
Madison's Avatar
Hahaha that is one of the reasons I made sure to change my avatar to one that was actually me before posting this because I KNEW everyone would assume I was a guy and just roast me without helping me at all!
I guess you're just gonna have to trust me haha. I'd post my last name so you could find me on Facebook but then, judging by this thread, I'd just get a ton of friend requests from randoms hahah.
Last edited by Madison; 02-06-2017 at 11:04 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-06-2017, 11:05 AM   #37
Djohns's Avatar
Groans: 105
See I don't have a Facebook so you're safe there. Guess I'd just have to ask for your number. Or IG name works too.
Soon:built motor
 Old 02-06-2017, 11:07 AM   #38
Madison's Avatar
Okay so I should still pull them and check, but they're probably not upgraded but also probably not on the verge of failure. Right?
My IG is @madisonbuchanan_ I think
Last edited by Madison; 02-06-2017 at 11:07 AM. Reason: MSF Database - Automerged Doublepost
Nailedit187 (02-06-2017)
 Old 02-06-2017, 11:07 AM   #39
Djohns's Avatar
Groans: 105
The thing about the OEM internals is you never know when they're going to fail, they just do. No signs or symptoms before they go. Definitely need to pull them.
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
KiwiFlavor (02-06-2017)
 Old 02-06-2017, 11:08 AM   #40
Madison's Avatar
Thank you for being understanding! Thanks for the advice as well, I'll do that.
Blow Through MAF Voltwings 2010 MS3 - ECU Computer Tuning 88 10-05-2012 04:14 AM
Blow through MAF ESB Jiu JItsu MazdaSpeed 3/6 - Turbo Induction 84 09-14-2012 06:57 AM
blow through maf TWOptSL0W Mazdaspeed3/6 General Discussion 4 11-24-2011 11:30 AM
Will i blow? Grim MazdaSpeed 3 - Engine, Transmission & Driveline 26 02-20-2009 09:22 AM
Page generated in 0.59480 seconds with 42 queries
