 Old 08-03-2016, 03:44 PM   #1
shadow102's Avatar
Posts: 971   (View Stats)
shadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the worldshadow102 is the leader of the world
Default Occ intake vacuum cap options
After running lean at idle and having a boost leak i have determined one of the areas i am having a problem with is the vacuum cap on the intake manifold. I guess after almost 3 years and 55k miles the rubber cap has had it. Before i run to the autoparts store and throw a generic rubber vacuum cap on there does anybody make anything better, like a silicon cap? I believe it is a 5/8" vacuum cap.
2013 CWP MS3 w/tech package
JBR SRI - JBR TIP - CorkSport TMIC - CNT Catted TBE - DevilsOwn Stage2 WMI - Autotech internals - Cobb AP - NGK ITV22's - JBR dogbone RMM - CorkSport TMM insert - Turbosmart BPV - JBR Boost/BPV tubes - JBR SSP w/bushings - CorkSport OCC - Koni sport shocks - Ground Control Coilovers - JBR rsb - JBR Camber Arms - 18x7.5 Work Emotion CR Kai
shadow102 is offline   Reply With Quote
 Old 08-03-2016, 05:44 PM   #2
torquemaniac's Avatar
Posts: 705   (View Stats)
I used a very short length of 5/8 ID oil & fuel resistant hose, with an old 3/8 to 1/4 ratchet adapter to plug the hose end...secured everything with 2 worm clamps
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler // 3-port EBCS // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Forge BPV v.2 // Crankcase evac system // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
Coming soon : Composite ram-air intake // Hood with heat extraction vent
 Old 08-05-2016, 08:13 PM   #3
nekret's Avatar
Posts: 414   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
You can find silicone vacuum caps on eBay. I've had one on the bottom port of my K04 wastegate for a year now and it seems to hold up pretty darn well to the heat. Downside though is Silicone isn't very resistant to Oil vapor so the aforementioned line with a plug may work better. They also have PCV hose that is designed for exactly this purpose which should give you a very long life.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 08-05-2016, 08:31 PM   #4
BLKspd5's Avatar
Posts: 65   (View Stats)
BLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really nice
Not trying to thread Jack but what symptoms were you having? Were you still hitting target AFR or not? What did your trims look like? I think I might have the same issue.
Edit 8/7/16
While changing the oil today I checked my cap, it's already cracking really bad but no leaks. I've only had the catch can about 3 months. I'll email Corksport tomorrow. Maybe they should switch to silicone caps?
BLKspd5 is offline   Reply With Quote
Intake vacuum elbow chumpsteak MazdaSpeed 3 - Engine, Transmission & Driveline 19 02-21-2018 10:41 AM
cp-e™ Intake Manifold Color Options www.cp-e.com Custom Performance Engineering (cp-e.com) 201 12-24-2015 07:27 AM
Intake and Exhaust Valve options JDMCRX MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-04-2014 07:04 AM
BT intake options Fobio MazdaSpeed 3/6 - Big Turbo Builds 22 12-03-2013 01:47 PM
Intake manifold options?? MS6FL MazdaSpeed 3/6 - Turbo Induction 8 07-24-2012 05:50 PM
Page generated in 0.25429 seconds with 23 queries
