Notices
Like Tree38Likes
 Old 08-19-2012, 03:12 PM   #41
Bromander J. Herrera
dereeek's Avatar
Posts: 1,469   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 242
Groaned at 15 Times in 14 Posts
I'm in, mines turning brown.
BNR3-FREEK-PU
dereeek is online now   Reply With Quote
 Old 08-19-2012, 03:31 PM   #42
aggierandy's Avatar
Posts: 1,708   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
As far as design is concerned. Especially around any sights or tubes, minimize the use of dissimilar metals or brittle plastics as the thermal range and corresponding expansion and contraction will eventually lead to failure.
Sent from my DROIDX using Tapatalk 2
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is online now   Reply With Quote
 Old 08-20-2012, 02:54 PM   #43
Brydon@CorkSport's Avatar
Posts: 228   (View Stats)
Brydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the worldBrydon@CorkSport is the leader of the world
The sight tube will be glass and everything else will be aluminum. I also plan to play with baffling to make sure the coolant stays where we need it. Our test MS3 sees autocross days so sloshing would not be a good thing.
Thanks for the help!
Brydon@CorkSport is offline   Reply With Quote
 Old 08-20-2012, 04:39 PM   #44
Ryguy's Avatar
Posts: 390   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
Groaned at 4 Times in 2 Posts
2012 MS3-COBB AP, SRI, TIP, air box; Autotechs; CS TMIC, strut bar, lca bar, occ, boost tubes, flaps, hangers; Forge BPV v2; TWM full replacement; Cobb rmm; ebay dp; UR ABE; NGK 6510; DDM 5000K; Dizzy tune in progress
Ryguy is offline   Reply With Quote
The Following User Says Thank You to Ryguy For This Useful Post:
Monotonous ONE (09-12-2012)
 Old 08-20-2012, 09:26 PM   #45
SFWD 1934's Avatar
Posts: 677   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
I would rock the black tank. I will keep my eyes peeled for when released. Hopefully before Mazfest or at least SEMA.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
 Old 08-21-2012, 10:57 AM   #46
Track Fiend
Standsideways's Avatar
Posts: 405   (View Stats)
Standsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the world
Glass TUBE?
What kind of glass is gonna be used?
Better be some high quality borosilicate.
Even then, one tap with a tool or something at the right temp and all your coolant comes pissing out?
Not the best idea unless you guys have figured out how to make in un breakable? Or will be using a very thick walled boro tube.
Standsideways is offline   Reply With Quote
 Old 08-21-2012, 11:56 AM   #47
MazdaBoy2.3's Avatar
Posts: 2,299   (View Stats)
MazdaBoy2.3 has disabled reputation
Put a dipstick on the cap lol.
But in all seriousness it would probably work...
That said, it would be less than convenient...
2010 Black Mica
Corksport: RP, SRI/TIP, Cold Airbox, RMM Inserts, Mudflaps
JBR: SSP & Bushings
SURE: Boost Tubes
COBB: Accessport
Other: AT Internals, 35% Tint, DDM 6k HID, NGK Plugs
My car is being rfinkle(d) with! VD: e85 tune 283hp/333tq
MazdaBoy2.3 is online now   Reply With Quote
 Old 08-21-2012, 12:16 PM   #48
Ryguy's Avatar
Originally Posted by Standsideways
Glass TUBE?
Check out the cs occ, i think that sight tube design
 Old 08-21-2012, 12:37 PM   #49
aggierandy's Avatar
In my mind, there are currently two different sight options. A glass tube (See Corksport OCC) and a porthole (See post #19 from UnknownSuperhero)
I think it would be better with a porthole design for two reasons:
1.) The porthole would be less susceptible to incidental contact inside the engine compartment.
2.) The porthole design would not be subject to clogging and, I believe, less susceptible to haze buildup
One major limitation of a porthole design would be light. You would need to open the lid to allow enough light in to see the fluid level or add another porthole in the top to allow light in.
Is the porthole design still being considered? @
The Following User Says Thank You to aggierandy For This Useful Post:
S-hendrix (09-24-2012)
 Old 08-21-2012, 12:43 PM   #50
Ray Danger 2020's Avatar
Posts: 528   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
You could just put a small glass piece in the lid. If the cap is ~2" across, then put a like ~1 1/4" window in it...Light problem solve-ed...lol...or maybe not.
'12 Mazdaspeed 3
//SURE//JBR//Cobb Tuning//Ultimate Racing//Go Fast Bits//Corksport//Denso//Autotech//DDM Tuning//
277HP/320TQ Self Tuned On 93 (Mustang Dyno)
314HP/356TQ Rfinkle2 Tuned With 33% Corn (Dynojet)
Ray Danger 2020 is offline   Reply With Quote
 Old 08-21-2012, 05:41 PM   #51
That would never hold up to the temp and heat cycles. It will be likely a high pressure glass port hole to know where the coolant is. Plastic might work in mild climates but not in a lot of the US. I've ordered some parts and will test them. I will update the outcome.
The Following User Says Thank You to Brydon@CorkSport For This Useful Post:
aggierandy (08-21-2012)
 Old 08-21-2012, 07:17 PM   #52
SFWD 1934's Avatar
The glass port is similiar to what we use in our thermal fluid plant (steam generation). They are used for sight glasses to know the level of the hot oil. They see temps as high as 550 degrees F.
Jason
www.full-race.com
The Following User Says Thank You to SFWD 1934 For This Useful Post:
Easter Bunny (08-28-2012)
 Old 08-22-2012, 12:16 PM   #53
aggierandy's Avatar
I already said that (See bold above). Did you just stop reading mid sentence?
 Old 08-22-2012, 02:16 PM   #54
Lolz...I must have
'12 Mazdaspeed 3
 Old 08-22-2012, 03:12 PM   #55
aggierandy's Avatar
What about a sweet triangular porthole window in the angled piece near the passenger headlight? It would probably drive the cost up too much I'm guessing?
 Old 08-27-2012, 06:34 PM   #56
Very expensive. If I want anyone to buy these I have to keep them simple.
aggierandy likes this.
 Old 08-27-2012, 08:35 PM   #57
aggierandy's Avatar
Agreed. Keep on doing your thing.
 Old 08-29-2012, 04:52 PM   #58
This actually works better than I though it would. This is just the idea. The final product should look better.
kritz, Koke382 and The Nut like this.
The Following 11 Users Say Thank You to Brydon@CorkSport For This Useful Post:
aggierandy (08-29-2012), BOTTLEFED08 (09-20-2012), CosmicArkie (08-30-2012), dereeek (08-29-2012), Dr. Speed (09-07-2012), easy (08-29-2012), J'sSpeed3 (01-08-2013), Koke382 (01-03-2013), kritz (08-29-2012), MS3-a(sore)ASS-rex (09-19-2012), PokeyHokie (01-02-2013)
 Old 08-29-2012, 05:31 PM   #59
aggierandy's Avatar
Simple is always better. Nice work. Looking forward to it.
 Old 08-29-2012, 05:53 PM   #60
meltdown100's Avatar
Posts: 95   (View Stats)
meltdown100 has disabled reputation
This forum is an endless treasure trove, I'm really blown away by the amount of high quality aftermarket support for this car. Now that I know the stock tank is failure prone (learned something new right there) I'd definitely wanna get one of these at some point.
Black looks great, would be my color choice.
meltdown100 is offline   Reply With Quote
 Old 08-29-2012, 06:05 PM   #61
Ryguy's Avatar
Looks great
 Old 08-29-2012, 08:04 PM   #62
deadlandxtreme's Avatar
Posts: 986   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
Finalize the design and start production so you can take my money please.
2010 Mazdaspeed3- Installed Mods: - TWM Performance Full Replacement Short Shifter Kit, CP-E TMIC, COBB TIP, AEM CAI, Forge V2 BPV, Corksport boost and recir hoses, Corksport coolant hoses, Denso ITV-22, COBB AP, CNT DP, Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Grimmspeed EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.
deadlandxtreme is offline   Reply With Quote
 Old 08-30-2012, 06:55 AM   #63
jbaum06's Avatar
Posts: 20   (View Stats)
jbaum06 will become famous soon enough
When will this be ready for purchase and how much!!!!
jbaum06 is offline   Reply With Quote
 Old 09-07-2012, 02:25 PM   #64
Soon enough. Making them takes awhile so we will all have to wait a bit. I will have an estimated price next week. Thanks for the support guys and gals.
The Following 4 Users Say Thank You to Brydon@CorkSport For This Useful Post:
easy (09-07-2012), MS3-a(sore)ASS-rex (09-19-2012), Ryguy (09-07-2012), UnknownSuperhero (09-07-2012)
 Old 09-12-2012, 11:42 AM   #65
greatdane68's Avatar
Posts: 511   (View Stats)
greatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the world
Groaned at 42 Times in 19 Posts
Can't wait to see this made, because I want one too!
2010 Mazda Speed3
Hypertech Tune, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP,
Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ebay 15mm Wheel Spacers
Soon to come: Fuel Pump internals (On order from Edgeautosports)
1995 Honda Prelude
2003 Chevy S-10
greatdane68 is offline   Reply With Quote
 Old 09-12-2012, 11:53 AM   #66
Unicorn Farts
Deldran's Avatar
Posts: 2,143   (View Stats)
Groans: 96
Groaned at 35 Times in 28 Posts
The only issue to overcome would be a float or some sort of sight for the coolant level.
Here is another thought that might be cheaper, John Deere used to use it on there lawn mowers and such but its pretty simple and should work.
Build the float into the cap, and build a gauge into the top of the cap itself, super easy to check your coolant levels.
something like this
Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms
Deldran is online now   Reply With Quote
The Following 3 Users Say Thank You to Deldran For This Useful Post:
aggierandy (09-12-2012), CosmicArkie (09-12-2012), LittleredMPS (09-26-2012)
 Old 09-19-2012, 03:37 PM   #67
MS3-a(sore)ASS-rex's Avatar
Posts: 6,267   (View Stats)
Groans: 193
Groaned at 75 Times in 63 Posts
Seems I'm a little late to add my input but regardless it's beautiful and I'm glad someone finally got around to doing this!
If it is NOT too late however, then I would like to suggest integrating the power steering reservoir into the design. I'm a big fan of the kill two birds with one stone philosophy and would gladly buy that.
BOTTLEFED08 and The Nut like this.
MS3 has officially been retired to daily duty
Project 1G is officially under way; 1991 Eagle Talon TSi.
Stock Turbo & Stock Motor Grand Champion of the World!
NATOR PA
MS3-a(sore)ASS-rex is online now   Reply With Quote
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
BOTTLEFED08 (09-19-2012)
 Old 09-19-2012, 04:00 PM   #68
BOTTLEFED08's Avatar
Posts: 652   (View Stats)
BOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the world
Groaned at 11 Times in 6 Posts
In for more engine bling.. I deff like the idea of getting ride of the bulky coolant overflow, and that god awful yellowish/brown power steering reservoir!
2008 MAZDASPEED 3 THE TORQUE MONSTER
BOTTLEFED08 is offline   Reply With Quote
 Old 09-21-2012, 06:03 AM   #69
Groans: 82
Brydon@CorkSport - While Im sure most of us appreciate the R&D and quality prodution, do you all have any sort of ETA as to when these might be available for purchase? Even a ballpark would be sufficient.
Thank you for the help.
 Old 09-24-2012, 09:11 PM   #70
Canada17's Avatar
Posts: 8   (View Stats)
Canada17 will become famous soon enough
If it is anything like the occ, I'm in. Please take my money.
Canada17 is offline   Reply With Quote
 Old 09-24-2012, 09:38 PM   #71
S-hendrix's Avatar
Posts: 984   (View Stats)
S-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the world
I will purchase one of these when released.
DroidX2-TapTapTaparooo
BNR S3 . FREEKTUNED . COBB FMIC . COBB CBE . SURE full 3" . CPe Safe Seals . KMD Internals . Grimmspeed EBCS . Guardian Angel . TWM Short Shifter Replacement . MSD DashHawk V2 . Turbo XS DP+RP . Turbosmart Hybrid BOV (full recirc) . JBR SSP+Bushings+Knob/ Rear Sway Bar/ Rear Camber Arms . Sure PMM/TMM . JBR EGR Delete . AWR Adjustable Front/Rear Endlinks . TRZ Dogbone RMM . Denso ITV-22 . Eibach Sport Line . Koni Yellows
S-hendrix is offline   Reply With Quote
 Old 09-24-2012, 09:44 PM   #72
RoyalDex's Avatar
Posts: 74   (View Stats)
RoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond repute
How about something for a ms6?
RoyalDex is offline   Reply With Quote
The Following User Says Thank You to RoyalDex For This Useful Post:
PhillyCheese (02-25-2013)
 Old 09-26-2012, 01:18 PM   #73
pinkcheese's Avatar
Posts: 336   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
You say this will work for all the mazda, and mazdaspeed 3's? Verifying this would be greatly appreciated.
I've already gone through 1 coolant tank and I doubt this next one will hold up much longer, I can speak from experience with these plastic coolant tanks they fade, and crack especially when you start generating heat from added performance with these cars.
Does cork sport plan to use same pressure rating for the cap, 21psi stock or will there be different available caps?
pinkcheese is offline   Reply With Quote
 Old 09-28-2012, 05:27 AM   #74
Groans: 82
And that price is?????
The Following User Says Thank You to deadlandxtreme For This Useful Post:
irishking03 (10-03-2012)
 Old 10-04-2012, 01:46 AM   #75
world famous z's Avatar
Posts: 55   (View Stats)
world famous z will become famous soon enoughworld famous z will become famous soon enough
Groaned at 42 Times in 8 Posts
I'm in as well.
IF you have an idea of final production dates yet and are able or willing to take pre orders I would gladly jump on board asap
world famous z is offline   Reply With Quote
 Old 10-04-2012, 02:24 AM   #76
Eatin' Your Tuna
Haltech's Avatar
Groans: 212
Well we can take this even one step further and integrate a methanol reservoir on the other side the possibility is endless when you remove the crappy oem tanks and shape the alumn.
Id like to see these things quick to market so i can raffle them off.
The Following 7 Users Say Thank You to Haltech For This Useful Post:
aggierandy (10-04-2012), deadlandxtreme (10-04-2012), easy (10-08-2012), MS3-a(sore)ASS-rex (10-04-2012), S-hendrix (10-04-2012), Todd98SE (10-10-2012), UnknownSuperhero (10-04-2012)
 Old 10-04-2012, 05:12 PM   #77
IE.SD.Manny's Avatar
Posts: 87   (View Stats)
IE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond repute
Agreed, it would clean up the whole left side nicely and would personally justify the cost bit more for me.
08 MS3- Autotech HPFP Internals, Braile 21lb Battery, Cobb SRI, Evo IX MR BBS Wheels, HKS HipermaxIII Sport Coilovers, JBR SSP, JBR Knob, JBR 88aRMM, JBR Rear Sway, TB Suspension Adjustable Trunk Bar, TB Suspension Traction Bar, Test Pipe, Ultra Gauge Monitor
IE.SD.Manny is offline   Reply With Quote
 Old 10-10-2012, 10:56 AM   #78
I think it will be a few months before we are done with enough to sell. I added some baffling and shortened the box to fit more models of cars. The price should be around ~$150. Trying to make it cheaper but the amount of labor is cost prohibitive.
deadlandxtreme likes this.
Code Monkey (10-16-2012), deadlandxtreme (10-10-2012), MS3-a(sore)ASS-rex (10-10-2012), Todd98SE (10-10-2012)
 Old 10-10-2012, 11:03 AM   #79
The Angry Goose
Hectik1's Avatar
Posts: 3,158   (View Stats)
Groaned at 9 Times in 6 Posts
Damn, why must I see things like this that make me want to spend more money!
Hector
2008 Mazdaspeed3
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 10-10-2012, 11:06 AM   #80
Groans: 193
Did you integrate the power steering fluid reservoir as well, or just keep it focused on the coolant overflow?
NATOR PA
Coolant Reservoir Removal ZPrice 2010 MS3 - Engine, Transmission & Driveline 3 01-01-2011 07:56 AM
Coolant boiling over exhaust in coolant bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-15-2010 01:39 PM
WI reservoir? Speedn3 MazdaSpeed 3 - Engine, Transmission & Driveline 20 12-19-2008 09:50 PM
Page generated in 0.52686 seconds with 43 queries
