Like Tree4Likes
  • 1 Post By g00s3y
  • 1 Post By zenit
  • 1 Post By 5doorsoffury
  • 1 Post By g00s3y
 Old 08-10-2017, 12:32 PM   #1
The_Boost_Buddha's Avatar
Posts: 102   (View Stats)
The_Boost_Buddha is just really niceThe_Boost_Buddha is just really niceThe_Boost_Buddha is just really niceThe_Boost_Buddha is just really nice
Groaned at 33 Times in 12 Posts
Default Pulling stock K04, Veterans please advise
So where the exhaust manifold bolts to the turbos hot side housing with 4 bolts started to leak, I tracked it down with LTFT and STFT. 2 studs were backed out and it was about an 1/8 separated, pretty bad leak. Story short I snapped off a stud inside the turbo housing. What set of tools am I gonna need specifically for the stud back out, and what are some of the known, "while your in their might as well do this too" mods/fixes that should be done. Know any links for a k04-22 rebuild kit? Seals, gaskets? Lines replaced? Thanks guys.
ps: car is full bolt ons stage 3 gen pu
And please dear god don't say "BNR that shit and build the motor" lol
Last edited by The_Boost_Buddha; 08-10-2017 at 12:32 PM. Reason: MSF Database - Automerged Doublepost
The_Boost_Buddha is offline   Reply With Quote
The Following 2 Users Say NO Thank You to The_Boost_Buddha For This Un-useful Post:
g00s3y (08-12-2017), Neverlift (08-11-2017)
 Old 08-10-2017, 12:40 PM   #2
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
Find a machine shop that will take it out.
or, if there is some of the bolt sticking out you can grind flats on it so you can get a wrench on it or vise grips. If its still stuck drill a hole in it and use a easy out.
As for replacement stuff for sure the copper gasket between the turbo and the mani. I think edge auto also has replacement bolts and the gaskets.
P.S.
use PB blaster next time.
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
 Old 08-10-2017, 01:46 PM   #3
Man I know haha but I did I used PB blaster and used a dremel etcher to vibrate it loose (trade secret), and it still snapped while tightening. And I am a machine shop lol, I have a 1000 sq ft machine shop fully stocked. Every tool you can dream off. But what type of drill and back out and tap should be used. Any brands? Not new to engine building or effing exhaust bolts. Just not gonna pay someone and have access to most tools/gadgets
 Old 08-10-2017, 02:34 PM   #4
Colepidd55's Avatar
Just get a easy out set and drill a hole ON CENTER then use an easy out. Start out small and work your way up to a bigger size drill. The bigger the easy out the more torque on the bolt. The key is to stay on center so that you don't fuck the threads up. I would soak that shit in PB blaster until you get it out.
Do you have a Manual Mill? that would make it 10X easier. set it up on the mill and drill it out.
SOLD
2009 CWP Speed3
 Old 08-10-2017, 02:42 PM   #5
Of course I have a mill it wouldn't be a machine shop without one. If i remember correctly it was about $20,000 new so I trust it immensely. Ok yeah figured it would have to be a big hole, otherwise the easy out wouldn't have enough surface area far enough away from the rotational axis to apply enough torque to unstick it. Shweeeet
Then again a retard could use a 20k dollar mill and mess it up FUBAR but you get my point.
Last edited by The_Boost_Buddha; 08-10-2017 at 02:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-12-2017, 04:26 PM   #6
Reedy's Avatar
Posts: 376   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
Please post pics when you mess it up. Thx.
Reedy is offline   Reply With Quote
The Following 4 Users Say Thank You to Reedy For This Useful Post:
Colepidd55 (08-12-2017), g00s3y (08-12-2017), JSmith (08-12-2017), KiwiFlavor (08-16-2017)
 Old 08-12-2017, 06:33 PM   #7
g00s3y's Avatar
Posts: 2,077   (View Stats)
Groans: 410
You're a machine shop, but you don't know how to extract a bolt that snapped off?
Stage 3... lmao
sharksinspace likes this.
The Following 2 Users Say Thank You to g00s3y For This Useful Post:
KiwiFlavor (08-16-2017), sharksinspace (08-13-2017)
 Old 08-12-2017, 07:03 PM   #8
Colepidd55's Avatar
[QUOTE=g00s3y;3125165]You're a machine shop, but you don't know how to extract a bolt that snapped off?
yeah..... I was skeptical too..
SOLD
2009 CWP Speed3
 Old 08-13-2017, 01:01 AM   #9
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,669   (View Stats)
Groans: 524
Groaned at 169 Times in 106 Posts
you're a good dude
06 MS6
The Following 2 Users Say Thank You to Pu Manchu For This Useful Post:
Colepidd55 (08-14-2017), KiwiFlavor (08-16-2017)
 Old 08-13-2017, 08:37 AM   #10
speed23's Avatar
Posts: 1,436   (View Stats)
How bad were your fuel trims with the 1/8 inch gap? I am trying to sort a possible leak myself. Found the drivers side bolts on the exhaust manifold to be a tiny bit loose - only an 1/8 of a turn to fully tighten though.
 Old 08-13-2017, 10:37 AM   #11
Djohns's Avatar
Posts: 3,751   (View Stats)
Groaned at 7 Times in 6 Posts
Yea you're not going to be able to use an easy out or anything like that on those studs. Think of how hot that gets and how many heat cycles it's been through. You're going to have to drill it out and tap, possibly add a helicoil. Ask me how I know.
2010 black mica speed3
Soon:built motor
The Following 3 Users Say Thank You to Djohns For This Useful Post:
KiwiFlavor (08-16-2017), MD1032 (08-17-2017), monkey.bones.007 (08-13-2017)
 Old 08-13-2017, 10:39 AM   #12
zenit's Avatar
Posts: 1,350   (View Stats)
Groans: 56
@The_Boost_Buddha; "BNR that shit and build the motor" lol
KiwiFlavor likes this.
-feejay
-wetzel
The Following 2 Users Say Thank You to zenit For This Useful Post:
 Old 08-13-2017, 10:47 AM   #13
Don
Don's Avatar
Posts: 181   (View Stats)
Don has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond repute
Wait wait wait. You have a machine shop stocked with equipment but you're asking MSF on how to extract a stud???? I'm confused
2010 speed3
Corksport catted turbo back
Corksport SRI W/TIP
Autotech internals
AP3 Running PD tune
Stock turbo. Waiting for it to go
Konig deception wheels
BC br coilovers
Oh yea..... I won the lottery!!!!!
Don is offline   Reply With Quote
The Following 3 Users Say Thank You to Don For This Useful Post:
Djohns (08-13-2017), MD1032 (08-17-2017), sharksinspace (08-13-2017)
 Old 08-13-2017, 01:01 PM   #14
STFT 25% and LTFT 10%
Stage 3... lmao
I'm a machine shop, was a funny response to another guy. I am not a machinist no, and haven't had experience working in a machine shop. I just have 24 hr access to a machine shop. Don't have to be a dick, no idea what you get out of going out of your way to be a fuck ass. Sorry god gave you a little dick
Last edited by The_Boost_Buddha; 08-13-2017 at 01:01 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to The_Boost_Buddha For This Useful Post:
speed23 (08-13-2017)
g00s3y (08-14-2017), MD1032 (08-17-2017)
 Old 08-13-2017, 01:47 PM   #15
zenit's Avatar
Groans: 56
Oh my. You're definitely new around here.
@Djohns; - that's just a regular K04, right?
-feejay
-wetzel
 Old 08-13-2017, 03:59 PM   #16
Djohns's Avatar
Yea just a regular ko4, that happened a little while ago.
Soon:built motor
KiwiFlavor (08-16-2017), MD1032 (08-17-2017), zenit (08-13-2017)
 Old 08-13-2017, 05:59 PM   #17
5doorsoffury's Avatar
Posts: 903   (View Stats)
Funny i thought shit like torching and kroil on exhaust bolts were trade secrets you must know what your doing.
Sounds like a pro to me.
Sooooooooo why the fuck wouldnt you ask a machinist who works there to help you......
I would trust a epileptic teen with a strobe light drill after 5 beers with my turbo before i would trust you with a 20k machine. You sound like an ass hat throwing big words and numbers to look impressive since you cant figure out how to deal with a snapped stud. IMHO you shoulda just googled how to drill and tap broken stud since it is common and there isnt any exotic metals here....
You should just bnr that shit and build the motor.:
thatguy0o0 likes this.
MECP
2012 BM
Rfinkle tune in progress
The Following 5 Users Say Thank You to 5doorsoffury For This Useful Post:
Djohns (08-13-2017), g00s3y (08-14-2017), KiwiFlavor (08-16-2017), Pu Manchu (08-13-2017), zenit (08-13-2017)
 Old 08-13-2017, 09:59 PM   #18
Djohns's Avatar
How hot would said teen be and approximate age for legal purposes.
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
 Old 08-14-2017, 12:21 AM   #19
Bahahahahahaha winning
 Old 08-14-2017, 11:50 AM   #20
g00s3y's Avatar
Groans: 410
Don't be sorry, your girl said it was the best she's ever had.
You don't know how to remove something from a hole. I wouldn't expect you to know how to put something in one correctly either.
The Following 4 Users Say Thank You to g00s3y For This Useful Post:
Djohns (08-14-2017), Jonb82 (08-15-2017), KiwiFlavor (08-16-2017), sharksinspace (08-16-2017)
 Old 08-14-2017, 04:28 PM   #21
zenit's Avatar
Groans: 56
This is what I hear:
-feejay
-wetzel
The Following 5 Users Say Thank You to zenit For This Useful Post:
Djohns (08-14-2017), g00s3y (08-15-2017), KiwiFlavor (08-16-2017), MD1032 (08-17-2017), sharksinspace (08-16-2017)
 Old 08-15-2017, 06:07 AM   #22
GroceryGtr's Avatar
Posts: 349   (View Stats)
 Old 08-15-2017, 03:12 PM   #23
Jonb82's Avatar
Posts: 388   (View Stats)
Jonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the world
Groaned at 24 Times in 9 Posts
Holy fuck! "I would trust an epileptic teen with a strobe light drill after 5 beers...", you sir are my hero today
Sent while probably pooping
CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune
Jonb82 is offline   Reply With Quote
The Following User Says Thank You to Jonb82 For This Useful Post:
 Old 08-15-2017, 07:17 PM   #24
You guys rock! Anyway back to the reason this thread was started, are there any, "while you're in the might as well" mods or replacements I should do, and are there any NON EBAY, NON CHINESE k04-22 rebuild kits available to us
 Old 08-15-2017, 10:23 PM   #25
Reedy's Avatar
The K04 is not serviceable. Buy a new one or upgrade to an ATP bolt on.
The Following User Says NO Thank You to Reedy For This Un-useful Post:
g00s3y (08-16-2017)
 Old 08-16-2017, 05:55 AM   #26
KiwiFlavor's Avatar
Posts: 2,275   (View Stats)
Buy a BNR and build that motor.
2012 NASA Spaceship Gray MS3
BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front)
The Following 6 Users Say Thank You to KiwiFlavor For This Useful Post:
5doorsoffury (08-16-2017), Djohns (08-16-2017), Fstrnyou (08-16-2017), g00s3y (08-16-2017), MD1032 (08-17-2017), zenit (08-16-2017)
 Old 08-16-2017, 10:45 AM   #27
g00s3y's Avatar
Groans: 410
Wow, that's amazing. How was I able to rebuild mine, when I was still k04, if that's the case?
 Old 08-16-2017, 03:13 PM   #28
Reedy's Avatar
Probably by wasting your money. What parts did you actually replace? The advice I've been given is its not designed to be serviceable. Maybe that was a translation for not worth doing.
Edit: You're right, but the kits are out of spec right out of the box so in some cases it's abit of a lottery. (Just checked to make sure, that's the reason why my guy won't do them)
 Old 08-16-2017, 03:56 PM   #29
Did you use a kit from eBay or otherwise?
 Old 08-16-2017, 06:04 PM   #30
zenit's Avatar
Groans: 56
In order of priority, please:
#1 - search noob
#2 - suck it
-feejay
-wetzel
The Following 3 Users Say Thank You to zenit For This Useful Post:
Djohns (08-16-2017), MD1032 (08-17-2017), sharksinspace (08-16-2017)
 Old 08-16-2017, 06:37 PM   #31
speed23's Avatar
Ive been using a rebuilt ebay parts ko4 for 60k miles. Going strong still.
Edit: This is the guy I bought mine from - apparently sold 20 and no issues with ebay kit. Somewhere in his posts I recall him saying exactly which kit he used:
http://www.mazdaspeedforums.org/foru...lt-k04-191182/
That said, the PITA it is to switch on the 6, I would just go BNR stage 3.
 Old 08-17-2017, 06:48 AM   #32
GroceryGtr's Avatar
its a lottery because its ebay. If you buy the kit from a respectable turbo service shop you'll be just fine. Keep in mind there are several versions of the K04(think vw). Its EASIER to just buy a bnr/cs, that doesn't mean that the K04 doesn't have potential. The problem is/was that people wanted silly money to modify the K04 that approached the prices of just getting a bnr/cs upgrade. There are several issues/limitations with the stock unit, but that doesnt automatically mean its garbage. Got an extra $1200 to spend on an upgrade have at it, but you can make plenty of power on the stocker.
 Old 08-17-2017, 08:37 AM   #33
g00s3y's Avatar
Groans: 410
It was before I started having everything automatically backed up by google photos, so this is the only photo I have of it. Everything worked perfectly fine after, no loss of any kind, no problems of any kind.
People really need to chill with all the ebay hate. It's no longer the clusterfuck it was 10+ years ago with 75% of the products being garbage. Its basically the site to get shit from china for cheap, since it's the same place a "name brand rebuild kid" is coming from also.
Bexar likes this.
Veterans Helping Veterans With Mazdas CorkSport CorkSport 0 09-26-2013 12:10 PM
On Veterans Day, a word of thanks Haltech Automotive News 0 11-11-2009 08:00 AM
Page generated in 0.54247 seconds with 33 queries
