 Old 08-13-2019, 05:29 PM   #1
roostmeyer's Avatar
Posts: 1   (View Stats)
roostmeyer is an unknown quantity at this point
Default Shimming Stock LSD
Has anyone over shimmed the factory cone type differential or is the carrier not easily split-able?
My LSD is shot, one wheel peel in the rain is out of control with TCS turned off. Car has 144k, so it's not a huge surprise that the stock LSD is worn out. I've just been living with it, since it's just a fun daily driver that I occasionally autocross.
In the last week or so my clutch has started to slip. I'd like to address the diff while the transmission is out. If I had $1450 sitting around it would be going to a lift and transmission jack to make the clutch job easier, not to a quaife or OSG for a ten year old car.
I've shimmed the diff 3 or 4 times on my trans am with a borg warner 9-bolt:
https://www.youtube.com/watch?v=8B4EoeU0l38
Not exactly rocket science, just add shims until all free play is gone on the spider gears. Of course access is a lot easier on a solid axle.
roostmeyer is offline   Reply With Quote
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 02:32 PM
Page generated in 0.63163 seconds with 20 queries
