 Old 09-07-2014, 09:17 AM   #1
Jadcock's Avatar
Posts: 134   (View Stats)
Jadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud ofJadcock has much to be proud of
Default Slave/Master cylinder Intermittent Issues
I'm trying to figure out an occasional frustration with my clutch. Car has 23k miles. Stock clutch. I have shifter bushings and SSP.
What I've noticed sometimes at slightly uphill red lights is that when I come to a stop in gear, clutch pedal all the way down, the car won't roll back and it will be harder but not impossible to pull out of gear. Clutch pedal still down, I pull it out of gear and then the car rolls backwards.
Slave cylinder shouldn't be leaking because it won't slowly engage when I sit in gear with the pedal down.
Any ideas guys?
Thanks for any input.
Sent from my DROID RAZR HD using Tapatalk
Jadcock is offline   Reply With Quote
 Old 09-10-2014, 11:41 AM   #2
frequencysurfer's Avatar
Posts: 232   (View Stats)
frequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the world
If you look at your belly pan from the top, you can see the slave cylinder sitting right at the front bottom of the motor. When mine went out, it barfed up fluid everywhere on the belly pan. You can spot the drips before it goes out. That's if it's the slave... you may have some air in the lines, just try bleeding the clutch from the slave cylinder.
frequencysurfer is offline   Reply With Quote
 Old 09-10-2014, 11:50 AM   #3
Jadcock's Avatar
Thanks for the input. I can't remember if there's a resivoir under the battery tray since I had it off last I'm sure there is one.
Any special fluid preferred by you guys?
 Old 09-10-2014, 12:22 PM   #4
The clutch and brakes are serviced by the same reservoir. Just top up the brake fluid reservoir, and the fluid will get to the clutch lines. If you just DD, you can use any old Dot3, otherwise, get some Dot4 if you track\Autox.
Clutch master and slave cylinder repacement questions soulefx MazdaSpeed 6 - Engine, Transmission & Driveline 27 10-17-2016 12:03 PM
master and slave cylinder pics cocoleveo7686 MazdaSpeed 6 - Engine, Transmission & Driveline 22 01-20-2014 06:21 AM
Master and slave cylinder replaced leo766 MazdaSpeed 6 - Engine, Transmission & Driveline 2 07-23-2013 11:12 AM
Master Cylinder HELP! Mjeezy11 MazdaSpeed 3/6 - Suspension & Brakes 21 06-20-2013 06:09 AM
Clutch slave cylinder issues socks MazdaSpeed 3 - Engine, Transmission & Driveline 13 03-31-2009 04:36 PM
Page generated in 0.24852 seconds with 21 queries
