  • 1 Post By LowFlyin
 Old 06-14-2018, 04:55 PM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default Stock Short DP vs CS High Flow
I currently have a 3 test pipe and 3 Catback straight pipe, with the 3 test pipe having a reduced on the front that bolts to the OEM upper DP. My next upgrade is going to be a C-PE TMIC, but Im wondering if I would benefit from a high flow primary cat.
I also have a CS SRI and CS HPFP, just to get that out of the way.
achulz is offline   Reply With Quote
 Old 06-14-2018, 06:01 PM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Well... What are your ultimate goals? I firmly believe that shitty downpipe install doesn't need to be approached unless you're going big turbo or trying to break stock turbo records
 Old 06-14-2018, 07:42 PM   #3
achulz's Avatar
Not really, just want as much power from the stock turbo (without WMI) as possible, just not sure if replacing the stock cat with a high flow unit will really make enough of a difference to justify the $300 price.
 Old 06-15-2018, 03:43 AM   #4
Solarsurge's Avatar
Posts: 570   (View Stats)
A 3" test pipe can give a 5% increase (10-12 WHP) very cheaply on a otherwise stock Speed3. That's why so many people do it. Getting a upper downpipe with a high flow cat won't give you much more, maybe 2%. It's not nearly as cost effective. A full 3" DP with or without high flow cat can give you over a 10% increase over stock because you're also removing the restriction of the 2.5" flange. However, the stock turbo is only physically capable of moving enough air to support around 300 WHP, so the closer you get to that number via other mods, the smaller your gains for any of it.
 Old 06-15-2018, 04:33 AM   #5
achulz's Avatar
Im already pushing 21 PSI now, I just flashed my Stratified tune this morning. As it is I think I wont really benefit from the DP, and if I do go for a full 3, Is have to change the test pipe as well. I have V-band clamps for the entire straight pipe and the race pipe, but I used the stock 2.5 flange to connect my custom race pipe and the DP together. So Id have to cut apart my test pipe and weld something else on to adapt it to a 3 downpipe.
 Old 06-16-2018, 10:22 AM   #6
LowFlyin's Avatar
Posts: 177   (View Stats)
LowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant future
I would do it personally after having done a few downpipe installs now. If you're the least bit mechanically inclined and have tools(mainly extensions/impact) then it is a simple task.
Sent from my LG-H820 using Tapatalk
LowFlyin is offline   Reply With Quote
 Old 06-16-2018, 11:01 AM   #7
achulz's Avatar
Ive done engine rebuilds and custom turbo kits, also built an ECU myself. Im not worried about the install, I was wondering if $300 is really worth the small performance increase. To me it isnt, Id rather spend that money on a RMM or better TMIC.
 Old 06-16-2018, 11:27 AM   #8
LowFlyin's Avatar
I went with a catless ebay downpipe for a year or so then switched to a cracked cs dp I got basically free and fixed so no i agree not worth $300 unless bt.
Also sounds like you're a bit handy, its very easy to fab a crash bar to fit a tr10 fmic if you have a welder , much less prone to heatsoak than a tmic.
achulz likes this.
 Old 06-16-2018, 12:38 PM   #9
achulz's Avatar
How much does that core cost? And what else would I need piping wise?
 Old 06-16-2018, 01:40 PM   #10
LowFlyin's Avatar
It was 250 or 300 I can't remember exactly , treadstone makes it. As for the piping, I ordered the cx racing fmic piping kit, about 200$ I think I paid for that new. Only extra piece besides a crash bar is 2.5-3" silicone couplers if you get a tr10, I'm about to go big turbo, if you're staying stock turbski just get a tr8 intercooler and you won't need the couplers.
High FLOW/Low Boost Turbojocky13 MazdaSpeed 3/6 - Big Turbo Builds 6 05-05-2017 09:09 AM
BNR S3, high boost/high WGDC and low air flow mituc MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-26-2017 05:14 PM
Help! High BATs or do all the stock intake manifolds flow about the same? paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 7 11-11-2013 08:46 AM
K&N high flow air filter Jordanms3 2010 MS3 - Turbo Induction 10 04-22-2010 08:33 AM
Need High Flow Cat? rtaylor60
Cobb Access Port/Maps
6 07-22-2009 10:23 PM
Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHN Autosports HQ
Page generated in 0.31553 seconds with 23 queries
