 Old 02-13-2017, 12:13 PM   #1
JoeFromCocomo's Avatar
Posts: 19   (View Stats)
JoeFromCocomo is on a distinguished road
Groaned at 13 Times in 4 Posts
Default Trans Noise After Installing CS TMM
So I just got done installing the Corksport Transmission Mount. I hear a rumble, almost bass sounding noise coming from the transmission, but only after I rip on it. It almost sounds like running over the rumble strip on the highway. The sound starts about 2 seconds after ripping on it and lasts for about 2-3 seconds. It does not make the sound if I put the car into neutral after high rpm driving. I know with any mount you will have added NVH, but this noise doesn't seem normal. I searched the forum for someone with the same kind of problem but none of the noises described seemed similar to mine. Anybody else know anything about this? I also have CS PMM and RMM.
2013 Speed 3 Non Tech Package / CS SRI&TIP / CS HPFP / CS DP with High Flow Cat / CS CBE Resonated / CS EBCS / CS BOV / CS Strut Bar / CS RMM / CS TMM / CS PMM / JBR EGR Delete / Cobb AP / NGK Iridium 1 Step Colder Plugs / CS Shifter Bushings / DDM HIDs / CS LED Fogs / CS LED Interior Lights / FREEKTUNED!!
JoeFromCocomo is offline   Reply With Quote
 Old 02-13-2017, 03:29 PM   #2
Thor Hammer's Avatar
Posts: 1,466   (View Stats)
Groans: 134
Nice avatar.
Take out the inserts. Noise still there? Process of elimination.
Do you rip on it all the time? If so, you have to expect things to wear out faster and start making noise. Though these transmissions are quite strong.
I had an AWR TMM. Garbage. Bushing puked out in a month and the NVH was terrible. Installed CS inserts and back to normal. Nice and quiet. I have an OEM PMM so I cant compare to your setup.
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
cyclist20 (02-17-2017)
 Old 02-13-2017, 04:00 PM   #3
MoMS3's Avatar
Posts: 224   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Does it rumble after on engine braking after you let off and coast down at high rpm or as you get on it?
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 02-13-2017, 05:42 PM   #4
Varomnia's Avatar
Posts: 387   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
When was the last time your transmission fluids have been flushed and how many miles are on your speed?
Your installation of a better TMM is not to blame, nor the product itself, however, it is very likely something relating to the transmission.
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
 Old 02-13-2017, 05:51 PM   #5
It has 31k on a 2013. Trans has not been flushed yet. All things have been maintained. And the noise happens when I keep it in gear after going over 4k or so... I'm about to leave where I'm at now and test it out again. It's just weird. There has been a lot of nvh though because I put pmm on last week then tmm on Saturday. I might just be paranoid. I don't rip on my car all the time I've always babied it. But like anyone that has a speed it's hard not to have fun here and there.
On another note I'm almost wondering what temp the fan turns on at? I sit right at 180 and when I rip on it she runs a little hotter, then back to 180. I'm wondering if the rumble is a fan rumbling my dashboard. Nothing with the transmission has been giving me issues since I bought the car brand new. I'll keep you all posted.
Sent from my SM-G930P using Tapatalk
The Following User Says Thank You to JoeFromCocomo For This Useful Post:
Thor Hammer (02-14-2017)
 Old 02-13-2017, 05:56 PM   #6
Varomnia's Avatar
I had the same thing happen with my speed, and my stock 04 civic. It's not the fans, mate. I thought transmission maintenance was every 30k/miles? Tried ctrl + F "flush" and "tran" to no avail. You could be exceptionally lucky and tire(s) be out of balance.
https://www.mazdausa.com/siteassets/...ers-manual.pdf
https://www.mazdausa.com/siteassets/...e-schedule.pdf
Then again, i'm blind as a bat.
 Old 02-14-2017, 05:06 AM   #7
MD1032's Avatar
Posts: 2,622   (View Stats)
Groans: 139
It's obviously related to the transmission mount because the problem started right after installing it. Uninstall and inspect, then reinstall.
Very few people run this mount, and for good reason. Overall Corksport's engine mounts are poorly designed in my opinion and I have never seen them last very long before the bushings deteriorate.
2007 Mazdaspeed3 GT
The Following User Says Thank You to MD1032 For This Useful Post:
 Old 02-16-2017, 05:07 PM   #8
Prodigalson's Avatar
Posts: 133   (View Stats)
Prodigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud ofProdigalson has much to be proud of
I've got that same noise with just a Damond RMM. it's a resonance, happens when you let the engine spin down after a wot run.. It's not a big deal.
2012 MS3 Crystal White, Tech; Upgraded HPFP, Damond SSP, RMM, PMM, TMM CS RSB, shift knob, mud flaps, hood scoop, TMIC, JBR shifter bushings, leather shift boot w/red stitching, Stoptech lines, Bayson-R front lip.
Not yet installed: JBR EGR delete, catless DP
2007 Kawasaki Mean Streak Special Edition
Low & Mean CRS, Hepco & Becker crash bars, Marauder headlight w/3800 lumen LED bulb, MBW LED front signal rings, Chrome Glow LED rear signals, 420 lumen LED 1157 taillight bulb, Danny Gray Raven solo seat, Muzzy 2-to-1 exhaust, black front calipers w/red lettering, Thunder Tornado intake, 200/55 rear tire, Progressive front springs w/Racetech Gold valves, Progressive 444 rear shocks (12.5"), Bad Ace rear caliper relocation bracket, Bad Ace Cam Chain Tensioner Extenders, Bad Ace Fork Cap Covers, Bad Ace Fuel Enrichment Knob Relocation Bracket, Avon black anodized air grips w/throttle boss, sidemounted license plate
Prodigalson is offline   Reply With Quote
The Following User Says Thank You to Prodigalson For This Useful Post:
MD1032 (02-17-2017)
 Old 02-17-2017, 04:30 AM   #9
MD1032's Avatar
Groans: 139
Actually, I know exactly what you are referring to. I have had the exact same thing on my car multiple times in the past. Each time, reinstalling the RMM has resolved the problem (I have it out of my car often enough...lol). That could easily be it for OP.
2007 Mazdaspeed3 GT
 Old 02-17-2017, 06:42 AM   #10
Yatta's Avatar
Posts: 1,862   (View Stats)
Yatta has disabled reputation
It is really easy to put a mount in and have some pre-load on it and doing so will bring more noise into the cabin. I almost think it is a good idea to loosen and retorque all of the mounts when one is replaced... and I have also tuned out some noise with my PMM by doing this to my RMM.
The Following 2 Users Say Thank You to Yatta For This Useful Post:
MD1032 (02-17-2017), Prodigalson (02-17-2017)
 Old 02-17-2017, 08:41 AM   #11
That makes sense. It's an especially timely suggestion since I'm installing a Damond PMM this weekend...
 Old 05-03-2017, 05:59 AM   #12
So I haven't really been driving my car lately, got a bike, it has mainly been sitting. I had my mechanic buddy in the car and he thinks its the CV joint out of alignment. I know when I was putting the TMM in, the motor was slightly cocked to one side. When I put a level on the top mount, it was off by a hair. I didn't think it would have this affect, but here we are. It makes a 2-3 second rumble/vibration from 3500-3250/3000. I'm thinking this weekend I loosen up all mounts and completely re-align the motor and see what happens... Hopefully the CV boot isn't ripped, I will have to inspect that as well.
Chirping noise when blipping throttle after installing Autotech hpfp internals joshuajcrouch MazdaSpeed 3 - Engine, Transmission & Driveline 11 02-03-2017 02:51 PM
Noise after installing TSW Nurburgring rims Douggievee MazdaSpeed 3/6 - Wheels & Tires 22 04-30-2015 08:07 AM
Neutral trans noise at idle 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 21 08-20-2013 06:42 PM
HU noise after installing stiffer mounts apena85 Mazdaspeed3/6 General Discussion 0 12-06-2012 05:33 AM
Strange noise from diff/trans MYspeedEMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 01-17-2011 11:16 PM
Page generated in 0.32706 seconds with 26 queries
