> 2010 MS3 - Dyno Sheets/Discussions
 Old 09-25-2017, 01:42 PM   #1
andale927's Avatar
Posts: 156   (View Stats)
andale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud of
Default BNR S4 E25 Dyno
Made 365whp/341wtq, mods in sig
Also here's a video:
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
The Following User Says Thank You to andale927 For This Useful Post:
Code Monkey (09-25-2017)
stock dyno & Cobb v-dyno numbers garf 2010 MS3 - Dyno Sheets/Discussions 45 04-08-2016 11:51 AM
AEM lets you hook up your car to a dyno at home with Dyno-Shaft Haltech Automotive News 2 11-23-2011 05:39 PM
Dyno runs: Renault Megane RS, Mazdaspeed 3 and Focus RS [Pics, dyno sheet and Video] ganque MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 01-20-2011 02:03 AM
Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? desperado callado MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-18-2009 11:27 AM
Page generated in 0.23517 seconds with 21 queries
