> 2010 MS3 - How-To's
Notices
Like Tree2Likes
  • 1 Post By Barnes
  • 1 Post By surebOOst
 Old 04-05-2011, 08:24 PM   #1
Special--k's Avatar
Posts: 610   (View Stats)
Special--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the world
Default Change the battery in smart-key
Stupid car keeps telling me that my smart key battery is getting low. I cannot figure out how to get this dam thing open!! anyone does this yet?
Special--k is offline   Reply With Quote
 Old 04-06-2011, 02:31 PM   #2
zatara's Avatar
Posts: 1,353   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
Owner's Manual, Page 3-5 to 3-7
zatara is offline   Reply With Quote
 Old 04-06-2011, 02:47 PM   #3
Special--k's Avatar
i dont have one... lost it in the move i guess... wonder if its posted in VIP?
 Old 04-10-2011, 08:58 PM   #4
Barnes's Avatar
Posts: 14   (View Stats)
Barnes will become famous soon enough
The manual sucks and doesn't even show our key type. What you have to do is pull the slide to release the top portion of the key. Now look inside the well of the transponder and you will see a label with writing on it. In small letters you will see where it says 'Open' on both sides. Take a very small flat head screw driver and gently pry apart the two sides of the transponder. Once you get the cover off, there is a black disk that covers the battery. You can just pull it off with your fingernail. The battery in mine was CR2025- a flat circular type battery you would find in a clock, etc.. Hope that helps...
galens47 likes this.
Barnes is offline   Reply With Quote
 Old 04-10-2011, 09:47 PM   #5
2010Speed3's Avatar
Posts: 622   (View Stats)
2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world
It's kinda sketchy how you're supposed to do it. I just did it recently cause I was sick of it telling me to change the battery.
Steps:
1. Remove key attachment or whatever you want to call it
2. Use thin flat head screw driver to go between the grooves to start the opening
3. Go along the side with screw driver on both sides carefully. It took me a couple of times switching from side to side until I could finally pull both halves apart.
4. Remove black battery cover and replace battery!
Enjoy having to not hear the car bitching at you each time you turn it off...
On a side note, is anybody's smart key scratched up quite a bit? I've got another few keys on my key chain though.
2010 Black Mica MazdaSpeed3
Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC
2010Speed3 is offline   Reply With Quote
The Following 8 Users Say Thank You to 2010Speed3 For This Useful Post:
AZRushki (06-30-2012), BAT-man (12-04-2012), CaptObvious75 (07-01-2012), galens47 (07-18-2012), Geo13 (07-13-2012), gitarpik (07-13-2012), GNO (11-13-2012), tomek_46 (09-11-2012)
 Old 04-10-2011, 10:04 PM   #6
Special--k's Avatar
wicked thanks!
 Old 04-10-2011, 11:49 PM   #7
2010Speed3's Avatar
Not a problem. I should be studying, but DIY's are so much fun to make...
 Old 04-28-2011, 04:31 PM   #8
Smily27's Avatar
Posts: 315   (View Stats)
Smily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond reputeSmily27 has a reputation beyond repute
Mine has been telling me this as well. But should the battery be dieing so quick? It seems like a short life. I feel like with our keys, it should use less power, but again I have no clue
Sent from my Droid using Tapatalk
2010 Velocity Red Mazdaspeed 3
PERFORMANCE: CS SRI w/TIP, TS DUAL PORT, COBB AP (Stage 1), KMD INTERNALS, UR CBE
SUSPENSION: H&R SPRINGS
WHEELS: 18" SPEEDY LITE FINS (on stock tires)
2005 MAZDA 3s- Traded in for ^
1993 HONDA ACCORD LX- R.I.P
Smily27 is offline   Reply With Quote
 Old 04-29-2011, 02:56 AM   #9
2010Speed3's Avatar
I thought the same thing at first, but I kinda thought about it a bit more. I'm thinking that a lot of it has to do with the fact that the key has to constantly be sending a signal to the car to know if its in range. That's just my case.
 Old 07-09-2011, 05:33 AM   #10
dr_banano's Avatar
Posts: 510   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
Steps:
yeah it is easy to scrath try to carry it alone without keys
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- Nitto NT05 tires on stocker wheel - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers-
ptp studs/seals - JBR TB/IM Thermal ins - EGR block - pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
The Following 2 Users Say Thank You to dr_banano For This Useful Post:
2010Speed3 (07-11-2011), Geo13 (07-13-2012)
 Old 07-25-2011, 09:08 PM   #11
rx7mazda's Avatar
Posts: 52   (View Stats)
rx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud ofrx7mazda has much to be proud of
i just got the low battery also. all i did though to get the battery out was pull the key out about half way then twist it and the thing pops open thus accessing the battery
· 2010 Mazdaspeed3
· 1988 RX-7
· 2003.5 Protege5 - Sold!
rx7mazda is offline   Reply With Quote
 Old 07-25-2011, 09:42 PM   #12
Ehdith's Avatar
Posts: 563   (View Stats)
Ehdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the worldEhdith is the leader of the world
Yeah I was lazy and when I bought my batteries from Radio Shack they replaced it for me.
2010 Black Mica MS3
*** JBR Heavy Knob - Special Edition//JBR 80 Duro RMM//JBR Rear Sway Bar***
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
TEAM MOM -- RIP
Ehdith is offline   Reply With Quote
 Old 06-26-2012, 10:31 PM   #13
Flynn's Avatar
Posts: 64   (View Stats)
Flynn will become famous soon enoughFlynn will become famous soon enough
Just to make sure there is no re-programming needed? Right?
www.flynndist.com The best in Automotive Detailing Supplies. Check out the website or PM me for questions/comments.
Flynn is offline   Reply With Quote
 Old 06-26-2012, 10:34 PM   #14
Firemedic/Arms Dealer
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
Groaned at 7 Times in 6 Posts
No
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is online now   Reply With Quote
 Old 06-29-2012, 02:59 PM   #15
tlh4tung's Avatar
Posts: 23   (View Stats)
tlh4tung is just really nicetlh4tung is just really nicetlh4tung is just really nicetlh4tung is just really nice
I just replaced mine few days ago, take the key to dealer and they replace it for me for $3.95 out the door.
tlh4tung is offline   Reply With Quote
The Following User Says Thank You to tlh4tung For This Useful Post:
Geo13 (07-13-2012)
 Old 06-30-2012, 11:26 AM   #16
surebOOst's Avatar
Posts: 1,343   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groans: 33
Groaned at 54 Times in 35 Posts
Did you have to buy the batteries? Or was that 3.95 batteries parts and labor included?
2006 Evolution IX RS
ER Built 2.3l // ETS Vband Hta3586r // Exedy Triple HD // AEM v1 EMS
English Racing Tuned Pump Gas 550awhp // E85 740awhp
surebOOst is offline   Reply With Quote
 Old 06-30-2012, 11:45 AM   #17
Tucson's First GenPu
AZRushki's Avatar
Posts: 234   (View Stats)
AZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the world
They didn't scan your key like they did mine, then void the warranty on it because it was in contact with a car which had a modified PCU.... did they? BRB stranded.
Ya, I got some stuffs in thurr
AZRushki is offline   Reply With Quote
 Old 06-30-2012, 12:01 PM   #18
surebOOst's Avatar
Groans: 33
I cracked my shit open like a champ and replaced it. I was just wondering if that guy was dumb enough to buy batteries, wast gas driving to dealership, and pay install fees.
speeed likes this.
 Old 07-01-2012, 07:24 PM   #19
Mazda Super Tech
motherfnmonsta's Avatar
Posts: 948   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
Do what I never heard that and don't see how that could even be true inky way to even gain access to those keys is through the pats function through the scan tool and even then only certain techs have that access. But I'm really interested in hearing about this. I'm a Mazda tech and never heard of this.
And don't waist your money at dealership for batterys we charge like $3 for one I'm sure u can get a pack for.that price.
Sent from my Android using Forum Runner
injen cai,cobb tip,jbr tig,jbr egr delete,jbr heavy shift knob,internals,ur dp,ur tp,maganaflow cbe
jrb rsb,cs lowering springs.
motherfnmonsta is offline   Reply With Quote
 Old 07-02-2012, 02:40 PM   #20
tlh4tung's Avatar
$3.95 battery & labor out the door, not sure how much you can save for labor to replace it your own. I have secondary key to use so just bring it in whenever I have chance pass by the dealer with no rush.
 Old 07-03-2012, 05:04 AM   #21
CaptObvious75's Avatar
Posts: 375   (View Stats)
$3.95 isn't all that much considering what people spend on mods
 Old 07-13-2012, 02:32 AM   #22
Flynn's Avatar
To bad the nearest Dealership to me is a 3 hour drive and over a mountain pass. I decided to just do it myself lol.
 Old 07-13-2012, 06:06 AM   #23
Fun fact: our keyless fobs are made by Mitsubishi lol
Sent from my Atrix
 Old 07-13-2012, 06:35 AM   #24
Geo13's Avatar
Posts: 972   (View Stats)
Geo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the world
Groans: 110
Groaned at 8 Times in 7 Posts
Mine started this with both key fobs a year and a half after purchasing?!? Just had them both done by the dealer for $8 (batteries & 'labor').
SPONSORED BY MY WIFE- 2010 Mazdaspeed3 Black Mica (DeadPool): COBB AP Stage 2+(Custom skeurHYPNOTICton Tune), SURE AEROS, SIDEWINDER, RETURN, CHARGE TUBES, TORQ R3 RMM (STREET), IM & TB TIG, SHORTCUT, COUNTERWEIGHT, TVS Caps,S.U Edition TURBOSMART 50/50 BOV, JBR70D TMM & PMM, RSB, OCC, EGR Block Off, Mudflaps, Tanabe Strut Tower Bar, Moddiction Anvil, TWM Full Replacement Shifter, Fortune Auto 500 Coilovers, Rolled & Slighty Pulled, SPC Adjustable Camber Arms, Autotech Internals, Denso ITV24, ETS TMIC, UR Catted Down Pipe & Resonated Test Pipe, Corksport CBE, GrimmSpeed 3 Port EBCS, Proto Tuning AP Holder, ProSport EVO Boost & AFR Gauge, Ultragauge Classic, Block8Head Dual Vent Pod, DDM Lows: 35w/6K & Fogs: 35w/3k HIDs, Headlight Armour Yellow Fog OverlaysiNATORva
COMING SOON (as my fucking wife says I can spend the cash or I stop getting tickets): BNR STG 3(keepin it small to make up for my BIG BALLs that are in a jar on the wife's desk)
2 Reckless By Speed + 2 Speeding = Mazdaspeed3 (and a pissed off wife)
Geo13 is offline   Reply With Quote
 Old 07-18-2012, 05:20 PM   #25
galens47's Avatar
Posts: 455   (View Stats)
galens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the world
Groaned at 14 Times in 5 Posts
Glad I found this thread! Been wondering about it for a while. My "spare" is in use now and I'm getting the Key is Dying notice. Homedepot here I come.
Cheers,
G
2010 ms3 Black Mica Tech Package
SURE RMM \\ CS SRI & TIP \\ Stratified tune \\ JBR RSB \\ Autotech internals \\ Konig Deception Blue \\ Fosgate 1000w with enclosed 12" \\ Tint \\ Hankook V12 \\ JBR Short Shift Plate \\ JBR 88 Duro TMM & PMM \\ CS Catless DP \\ Koni FSD \\ CS Strut Tower bar
“It is the mark of an educated mind to be able to entertain a thought without accepting it.” --Aristotle
galens47 is offline   Reply With Quote
 Old 08-13-2012, 12:05 PM   #26
Lighting Whore
soaptray's Avatar
Posts: 108   (View Stats)
soaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond repute
Took me 2 seconds - thanks for the tips!
[ 2010 MAZDASPEED3 - Crystal White Pearl ]
CoreCustoms.ca 6000k HID Bi-Xenon, Painted Out, Morimoto LED Halos, HID Fogs, LED Interior, LED DRL | Autotech HPFP Internals | MagnaFlow CBE | CP-e DeltaCore FMIC | Cobb SRI, TIH, AP, Knob | TurboXS Hybrid BOV | UR Catted Downpipe, Test Pipe | VG Sharkfin | Denso ITV22 Plugs | SURE Anchors, Counterweight, Shortcut | Rally Armor Flaps | AutoEXE Strut Bar | Speedline Hood Damper | Prosport Evo Boost Gauge, Evo Wideband AFR Gauge | JBR 80a RMM, 80a TMM Mount, Stage 2 OCC | Hella Supertones | Misc 30% Tint | Varrstoen 18 x 8.5 ES2 +35
soaptray is offline   Reply With Quote
 Old 11-13-2012, 03:32 PM   #27
GNO
GNO's Avatar
Posts: 27   (View Stats)
GNO is a jewel in the roughGNO is a jewel in the roughGNO is a jewel in the roughGNO is a jewel in the rough
Groaned at 10 Times in 1 Post
Funny how many times you see people post about using the search button. I used "Key Fob Battery" as my search string on the forum and this thread didn't come up. In order to find the thread, I used the same string on Google and added "Mazdaspeed3".
Thanks Special--k for starting this thread! Thanks 2010Speed3 for the pics and details!
GNO is offline   Reply With Quote
The Following User Says Thank You to GNO For This Useful Post:
2010Speed3 (11-26-2012)
 Old 11-13-2012, 03:37 PM   #28
GODspeed7's Avatar
Posts: 2,614   (View Stats)
Groaned at 46 Times in 31 Posts
Yeah let's cry because you tried ONE way to search and didn't have everything spoon fed to you. It's the Internet try a different site that's why their are millions of them. Are you really that lazy? Imagine back in the old day actually having to read a book to find the answers. Shocking right?
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete.
 Old 12-04-2012, 08:43 AM   #29
BAT-man's Avatar
Posts: 124   (View Stats)
BAT-man has disabled reputation
Groaned at 13 Times in 3 Posts
And now someone do one for 2010/12+ remotes (the ones that have the key jump out).
BAT-man is offline   Reply With Quote
The Following User Says Thank You to BAT-man For This Useful Post:
Cujo (12-19-2012)
Never blow up your battery with Michelin Smart Jumper Cables Haltech Automotive News 1 03-21-2010 10:16 PM
smart fortwo electric drive: smart starts series production of second generation electric drive Haltech Automotive News 0 12-14-2009 09:50 PM
Smart fortwo electric drive: smart starts series production of second generation electric drive Haltech Automotive News 0 12-14-2009 09:50 PM
Man buys truck with change, LOTS of change Haltech Automotive News 1 08-14-2008 08:15 AM
Page generated in 0.49336 seconds with 40 queries
