![]() | ![]() | #1 | ![]() |
![]() Join Date: Jan 2010 Location: Lake Villa, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,503
Groaned at 21 Times in 15 Posts
(Thread Starter) | ![]() ![]() ![]() I had the RPM Ventpod laying around from when I had the genone and since I have ripped out the vent for the pu at least half a dozen times I figured it was time to see if this would work. So obviously you will need one of these.... VentPod Single Gauge Pod for Mazda 3 / Mazdaspeed 3 #EHP-MZ3-VP - Revolution Performance Motorsports! ![]() pull your vent out from the dash and this is where the work begins. I used a 3" clamp but whatever you will use it will have to apply even pressure to all the little tabs that keep the two pieces together. A flathead isn't going to work as you need all the tabs pressed in otherwise it will more than likely break it. Tabs ![]() After it's apart ![]() Now you will have to trim some of the ventpod from the RPM store. With the ridges, it will not fit in the outer ring from your vent without a little modification. I used a dremel and the drum sander attachment. I removed two of the ridges leaving four, sanded the lip so it was pretty much flush with the rest of the pod. I also added another cut so it would be more pliable. Hack job and after sanding ![]() Once that is complete it should just slide right into the outer ring like so... ![]() Everything put back together ![]() I think I am going to paint the pod a flat black to match the stock vent cover as it might be too much aluminum but otherwise it gives it a nice clean look. As I said, there are other options for a ventpod but this was successful so I thought I would share. EDIT: So gave it a touch a paint and looks way better. Both gauges in place too! ![]()
__________________ Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah 4/15/12 dynojet results: 305whp / 355 tq ![]() Last edited by JTMS3; 11-03-2011 at 03:55 PM. |
The Following 26 Users Say Thank You to JTMS3 For This Useful Post: | 3mazdaspeed (10-29-2011), BigBoostMS3 (01-31-2014), bioevolve (03-10-2014), BoostedHatch (09-05-2016), Broxer (02-03-2012), Cujo (02-06-2012), f-castrillo (05-23-2012), gar_lei (06-23-2012), Geo13 (10-31-2011), irishking03 (01-30-2014), jack_hammer (07-18-2014), JSmith (05-04-2015), K.Mah (09-20-2012), mrmonk7663 (02-12-2012), myslow1 (11-20-2011), obijack (03-09-2014), omgvance (02-04-2014), ruthless013 (10-29-2011), Scoobs (05-23-2012), silentwolf8 (02-12-2012), SLOWHATCH (11-01-2011), SWAY (10-28-2011), TiGraySpeed6 (12-15-2011), Titanknight (11-09-2011), Wambo (05-28-2014), WetzMS3 (01-30-2014) |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Feb 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 323
Groaned at 6 Times in 6 Posts
| ![]() ![]() ![]() Im glad I looked here. I have been wondering if it will work in the PU. I really liked the vent pod when I havd it installed in the won. Thanks for this.
__________________ 2009 Metro Grey Numbers Fully Bolted. Nator Pa Dyno Day: 311HP 328TQ Pump 93 Nator Pa Dyno Day: 310HP 329TQ Pump 93 End of Drive 9/24/2013 2012 Liquid Silver Cobb AP |
The Following User Says Thank You to irishking03 For This Useful Post: | JTMS3 (01-30-2014) |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Jan 2012 Location: Allentown, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
| ![]() ![]() ![]() Nice job, the final result looks fantastic. Looks like it came from the factory combined with the Mazdaspeed gauge like that.
__________________ '08.5 CWP MS3 GT ![]() |
The Following User Says Thank You to aaron88 For This Useful Post: | JTMS3 (01-31-2014) |
![]() | ![]() | #4 | ![]() |
| ![]() ![]() ![]() I'm just trying to figure out how to get the actual factory vent out pos won't budge tappin dat trigga
![]() | ![]() | #5 | ![]() |
Easy peasy. Sent from my EVO using Tapatalk
__________________ Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah 4/15/12 dynojet results: 305whp / 355 tq ![]() | |
![]() | ![]() | #6 | ![]() |
| ![]() ![]() ![]() Cool tappin dat trigga
![]() | ![]() | #7 | ![]() |
![]() Join Date: Jun 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 19 Times in 9 Posts
| ![]() ![]() ![]() very clean. on my list of things to do ASAP! |
![]() | ![]() | #8 | ![]() |
| ![]() ![]() ![]() I am about 70% done my pod. Can't wait to show my own pictures. I have to get a better sander or sand paper and sand the top part so its flush. What did you use to sand it down what grip. I only had 100 laying around and I said fuck it cause it wasnt good enough. Pictures and write up and perfect. This is an easy how to. @JTMS3;
![]() | ![]() | #9 | ![]() |
![]() | ![]() | #10 | ![]() |
tappin dat trigga
__________________ 2009 Metro Grey Numbers Fully Bolted. Nator Pa Dyno Day: 311HP 328TQ Pump 93 Nator Pa Dyno Day: 310HP 329TQ Pump 93 End of Drive 9/24/2013 2012 Liquid Silver Cobb AP | |
The Following User Says Thank You to irishking03 For This Useful Post: | JTMS3 (03-10-2014) |
![]() | ![]() | #11 | ![]() |
![]() Join Date: May 2014 Location: Sandy, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| ![]() ![]() ![]() Thanks for the thread, always wondered how this is done. Quick and simple. Awesome, always wondered how this is done. Quick and easy, thanks!
__________________ 2006 Mazdaspeed6 Velocity Red - 526AWHP::: - SOLD 2012 Mazdaspeed3 Pearl White::: - Fully Bolted/Tuned/Mounted. Soon to be built and big turbo... coming soon. Last edited by MZR801; 05-23-2014 at 07:10 AM. Reason: MSF Database - Automerged Doublepost |
![]() | ![]() | #12 | ![]() |
| ![]() ![]() ![]() Finally done mine now I have to fill the hole. Po-Po tappin
![]() | ![]() | #13 | ![]() |
![]() Join Date: Aug 2012 Location: Dalton, Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
Groans: 32
Groaned at 37 Times in 28 Posts
| ![]() ![]() ![]() I got something you can put in that hole jk looks good
__________________ ![]() |
The Following User Says Thank You to Oalmon For This Useful Post: | JTMS3 (05-23-2014) |
![]() | ![]() | #14 | ![]() |
| ![]() ![]() ![]() Can't be more than 52mm wide lol Po-Po tappin
The Following User Says Thank You to irishking03 For This Useful Post: | Oalmon (05-23-2014) |
![]() | ![]() | #15 | ![]() |
![]() Join Date: Aug 2011 Location: Fuckin Topeka, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
Sent from my GS3 running Pac-Man ROM via FapDaCock
__________________ "I apologize for nothing!" - Hedonismbot ![]() | |
The Following User Says Thank You to aromig For This Useful Post: | irishking03 (05-23-2014) |
![]() | ![]() | #16 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| ![]() ![]() ![]() Cant the genone have anything to them selfs lol good job it does look really good
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
The Following User Says Thank You to blackms3_71 For This Useful Post: | irishking03 (05-23-2014) |
![]() | ![]() | #17 | ![]() |
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
| ![]() ![]() ![]() Where did you get the dual pod you have there?
__________________ '10 MS3- CS SRI/TIP Damond EGR Delete CS Fuel Pump Internals CP-E Stage 2 RMM AP V3 (Stage 1+ 93) '86 FC RX7- in the rebuild process I shoot cars. |
![]() | ![]() | #18 | ![]() |
| ![]() ![]() ![]() Looks like a @Block8head; pod to me.
The Following User Says Thank You to aaron88 For This Useful Post: | Block8head (07-17-2014) |
![]() | ![]() | #19 | ![]() |
![]() Join Date: Jul 2008 Location: Brockton,Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,661
Groans: 206
| ![]() ![]() ![]() That's Block8head dual pod.. ![]()
__________________ [SIGPIC][/SIGPIC] O4 350z "Money pit" 06 MS6 "Gone" BOSTON STRONG |
![]() | ![]() | #20 | ![]() |
The Following User Says Thank You to irishking03 For This Useful Post: | Block8head (07-18-2014) |
![]() | ![]() | #21 | ![]() |
| ![]() ![]() ![]() Hey @Block8head; I got your pm but couldnt reply because i dont have 15 posts yet ![]() but thanks for the reply and i'll have a look at your stuff today.
The Following User Says Thank You to project86 For This Useful Post: | Block8head (07-18-2014) |
Display Modes | |
Morgan and friends converting Aero Supersport into all-electric prototype | Haltech | Automotive News | 0 | 08-17-2011 01:10 PM |
Converting NA StandBack to MS6 | RichieRichness | Custom Performance Engineering (cp-e.com) | 0 | 06-02-2010 02:13 PM |
