> 2010 MS3 - How-To's
Like Tree2Likes
  • 1 Post By Miltron
  • 1 Post By El Beaner
 Old 02-17-2014, 09:52 AM   #1
Miltron's Avatar
Posts: 488   (View Stats)
Miltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the worldMiltron is the leader of the world
Default How-to Disable GenPu Auto Door Locks
After seeing the below video, I thought it would be good to get this info out there for people that drive on tracks, or just if you don't want this on...
Auto lock/unlock function
- When the vehicle speed exceeds 20 km/h (12 mph), all doors and the liftgate lock automatically.
- When the ignition is switched off, all doors and the liftgate unlock automatically.
These functions can also be disabled so that they do not operate.
Function Number and it's Function
1. The auto door-lock function is disabled.
2. All the doors and the liftgate lock automatically when the vehicle speed is about 20 km/h (12 mph) or more.
3. All the doors and the liftgate lock automatically when the vehicle speed is about 20 km/h (12 mph) or more. All the doors and the liftgate unlock when the ignition is switched from ON to ACC or Off.
Programming details
1. Stop the vehicle and close all the doors.
2. Switch the ignition ON.
3. Press and hold the lock side of the driver's door-lock switch within 10 seconds of switching the ignition ON, and make sure a beep sound is heard about eight seconds afterwards.
4. Referring to the auto lock/unlock function setting list, determine the function number for the desired setting and press the unlock side of the driver's door-lock switch only in the amount of the selected function number (Ex. If you select function 2, press the unlock side of the switch only 2 times).
5. Three seconds after the function setting has been changed, a beep sound will beep in the amount of the selected function number.
NOTE
- The doors cannot be locked or unlocked while the setting function is being performed.
- The procedure can be cancelled by pressing the lock side of the driver's door-lock switch.
Mauro_Penguin likes this.
Miltron is offline   Reply With Quote
The Following 11 Users Say Thank You to Miltron For This Useful Post:
3starmagnum (02-20-2014), bioevolve (02-17-2014), Captainobvious (04-09-2014), chaser27 (02-18-2014), Cujo (02-17-2014), Dralphy (02-20-2014), hz23 (02-20-2014), jharris243 (02-17-2014), macdiesel (02-20-2014), Mauro_Penguin (02-17-2014), Tifosi42 (02-03-2015)
 Old 02-18-2014, 09:57 PM   #2
Miltron's Avatar
Anyone try this in their car? Useful?
Tapatyped
 Old 02-20-2014, 10:18 AM   #3
El Beaner's Avatar
Posts: 4,251   (View Stats)
El Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the worldEl Beaner is the leader of the world
Groaned at 16 Times in 16 Posts
I thought that was only a dealer change option? It's in the back of the manual under personalization options(for my genpu at least) Section 10-13 of the manual
SOLD 2012 LSM Tech - 11/17/17
Power Mods: AP V3 ~ Autotech HPFP ~ JBR FMIC w/ TR6 ~ UR Catted DP TBE ~ JBR PP Stg 2 ~ GFB Stealth FX ~ SP63 Aux Fan Control ~ JBR RSB
Styling Mods: Kevdog Tow Plate ~ RX-8 Wheels ~ LED interior lights ~ LED Fog Lights ~ LED Bumper Reflector ~ Corksport Battery Box ~ Corksport Mud Flaps ~ Maisonvi Knob ~ Blackvue Dr550gw-2ch ~ Passport 9500ix
El Beaner is offline   Reply With Quote
The Following User Says Thank You to El Beaner For This Useful Post:
 Old 02-20-2014, 10:19 AM   #4
Miltron's Avatar
Nope apparently not - I disabled mine using the instructions
Tapatyped
 Old 02-20-2014, 06:22 PM   #5
hz23's Avatar
Posts: 10   (View Stats)
hz23 has a spectacular aura abouthz23 has a spectacular aura abouthz23 has a spectacular aura about
Originally Posted by Miltron View Post
Nope apparently not - I disabled mine using the instructions Tapatyped
Strangely enough.... I enabled mine. Thank you for the tip!
SOLD - No longer active.
hz23 is offline   Reply With Quote
The Following User Says Thank You to hz23 For This Useful Post:
Miltron (02-20-2014)
 Old 02-20-2014, 06:58 PM   #6
Miltron's Avatar
No problem!
 Old 02-20-2014, 07:22 PM   #7
3starmagnum's Avatar
Posts: 348   (View Stats)
3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world
Just went out and did this. Disabled. Thanks!!
2011 Mazdaspeed3
Power Mods: JBR 3" intake//CP-e top mount IC//AT internals//CS testpipe//NGK step colder plugs
Other mods: JBR 88 rmm//Swift springs//RA mud flaps//JBR ssp
STRATIFIED TUNED by Lex
3starmagnum is offline   Reply With Quote
The Following User Says Thank You to 3starmagnum For This Useful Post:
 Old 02-20-2014, 07:23 PM   #8
macdiesel's Avatar
Posts: 824   (View Stats)
macdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the world
Wow, wonder if any other personalized options have codes to enable.
Sent from my iPhone using sausage fingers
2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts//
Coming up: Corksport injector seals
macdiesel is offline   Reply With Quote
The Following User Says Thank You to macdiesel For This Useful Post:
 Old 02-20-2014, 07:23 PM   #9
Miltron's Avatar
I really want to find out how to turn on the automatic 3 blink turn signal
Tapatyped
The Following User Says Thank You to Miltron For This Useful Post:
 Old 02-20-2014, 07:26 PM   #10
Tapatyped
+1
Would be great
2011 Mazdaspeed3
 Old 02-20-2014, 07:50 PM   #11
El Beaner's Avatar
Tapatyped
Dealer can do that. I had them do it and love that feature
 Old 02-20-2014, 07:51 PM   #12
Miltron's Avatar
Yeah I took mine in and they were going to charge like $55, I was like Nooope...
Tapatyped
 Old 02-20-2014, 07:53 PM   #13
macdiesel's Avatar
$55 ain't bad for the triple turn signal. I love that feature on my wife's car
 Old 02-20-2014, 07:55 PM   #14
Miltron's Avatar
Well I work with computers and I know all they gotta do is plug it up and enable it - it's a rip off to charge for that
Tapatyped
 Old 02-20-2014, 09:19 PM   #15
El Beaner's Avatar
Tapatyped
Yep its too bad Cobb hasn't figured out a way to do it with the AP
Since I bought my car used I sent Mazda and email saying I should be entitled to the free personalization they give new owners and they picked up the tab.
Miltron likes this.
 Old 02-23-2014, 07:31 AM   #16
AJsMS3's Avatar
Posts: 702   (View Stats)
AJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the worldAJsMS3 is the leader of the world
They waited way to long to get him out of that car. Unresponsive, car still running, helmet off, yeah he didn't crash so there didn't seem to be a lot of urgency to get him out.
AJsMS3 is offline   Reply With Quote
 Old 02-23-2014, 07:34 AM   #17
Miltron's Avatar
Yeah it was like 8 mins before they broke the window - I thought that was a long time
Tapatyped
 Old 02-23-2014, 12:02 PM   #18
rbflurry's Avatar
Posts: 193   (View Stats)
rbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Dafuk are you two talking about?
rbflurry is offline   Reply With Quote
 Old 02-23-2014, 12:03 PM   #19
Miltron's Avatar
Da video
Tapatyped
 Old 02-23-2014, 01:12 PM   #20
AJsMS3's Avatar
Did you even watch the video?
Sent from my SCH-I545 using Tapatalk
2013 MS3 Vecolcity Red w/ Tech
K&N SRI
Forge V2 BPV
CS TIP
CS RMM
Cobb AP V2
CS Race Pipe
CPE TMIC
AutoTech Internals
Freek Tuned
The Following User Says Thank You to AJsMS3 For This Useful Post:
Miltron (02-23-2014)
 Old 02-23-2014, 02:25 PM   #21
macdiesel's Avatar
I finally watched they video. Every track event I went to required windows down even in the rain.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f429/how-disable-genpu-auto-door-locks-164690/
2012 Changing Settings - MID off and Door auto-lock : mazda3 This thread Refback 03-01-2014 10:32 PM
Requires the locksmith for noisy auto door locks of my mazda mx 5 ipMdycguir Miata - General Questions 3 02-11-2013 07:42 PM
Disable Key warning when door opening babypetit 2010 MS3 - Car Audio & Electronics 15 09-20-2012 08:44 PM
Does AP or any other tuner disable boost limiter on GenPu? alien_sporez 2010 MS3 - ECU Computer Tuning 12 10-11-2011 09:40 PM
Genpu disable seatbelt alarm / chime alexb2 MazdaSpeed 3 - How-To's 0 06-29-2011 01:27 PM
Weird door locks? BLK_MS3 2010 MS3 - Troubleshoot/Diagnostics 22 12-17-2010 03:18 PM
Page generated in 0.42511 seconds with 26 queries
