> 2010 MS3 - How-To's
Like Tree19Likes
 Old 01-13-2012, 10:17 PM   #1
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Neutral  +6 score
Post HOW-TO: MAZDASPEED3 REPLACE CLUTCH
HOW-TO MAZDASPEED3 REPLACE CLUTCH
This was done on a genpu, the gen1 requires the exactly the same procedures. This is meant to be a helpful walk through for doing a clutch swap on a MS3. This job should be performed ONLY BY PROFFECIONAL EXPERIENCED TECHNICIANS. I’m not liable for any mistakes you make, following this guide, which is probably not 100% accurate. This is probably a 12hr job according to Mazda, but it can be accomplished in <5hrs if you know what you’re doing.
Tools Required:
Socket Wrenches
Socket Sizes Used Most:
10mm
12mm
14mm
17mm
19mm
21mm
24mm
Ratcheting Wrenches(not necessary, but helpful):
10mm
12mm
14mm
17mm
Torque Wrenches
A Decent Screwdriver Set
Pry-Bars
Very Tall Jack Stands or a Lift
Transmission or Motorcycle Jack
Good Set of Pliers
Various Pieces of Wood
Hammers
Other Miscellaneous Hardware:
Brake-Clean
Grease
Thread-Lock
New Flywheel Bolts
New Trans Fluid
Rags, Towels, etc.
Coat Hangers, Rope, Wire, etc.
Drain Pan
Die-Grinder
Air Tools, Impact Guns
Piece of cardboard, and marker(to keep track of bolts)
Recommended to Replace:
Flywheel Bolts
Driveshaft Seals
Driveshaft C-Clip(only 1)
First, start by jacking the car in the air, or using a lift if you have one.
Begin by removing the undertray, front wheels, intake, battery, battery box, ECU, basically everything above the transmission.
Remove the brackets for the wiring harness and shift cables on the top of the trans, there is 3 brackets show here, all are being held on by 2 bolts IIRC:
Unbolt the coolant hard pipe running above the trans, as to access the trans bolts later, it’s held on by one 10mm nut on the front of the engine above the starter, and one 10mm bolt above the bellhousing towards the back of the engine:
Unclip the electrical connectors from the trans, located on a bracket on the front of the engine:
Remove the slave cylinder, from the bellhousing, two 12mm bolts, no need to remove the slave from the fluid line:
Next, drain all the trans fluid. Crack the fill plug first, just to make sure it will come out later. The fill plug is located on the front of the trans and, drain plug is located on the side of the trans, shown here
Fill:
Drain:
Now begin tearing into the brakes and suspension. Remove the front calipers, held on by two 17mm bolts, and remove the rotors. Hang the calipers by the springs with some rope/wire.
Now remove the tie-rod safety pin then the 14mm nut:
Put the nut on the stud, and whack the nut till the tie rod is free from the knuckle:
Remove the upper sway-bar end-link nut, remove the end-link from the strut and put the nut on it, so you don’t lose it(14mm and some metric hex key size… I just zip these off with an impact, since they’re usually rusted to shit and don’t want to come off. If all else fails, cut the end-link off and buy new ones):
Remove the lower ball-joint bolt nut(14mm):
Remove the strut bolt(17mm):
It’s now time to free the strut from the knuckle. First take out a big hammer and pound on the knuckle shown here:
Do this until the knuckle moves down about 1cm. This will allow you now to pry the knuckle open and slide it off the strut. It needs to go down about 1cm, because the strut has a protruding piece of metal as to align it in the knuckle. Now you take some random piece of metal roughly ¼” thick and place it where the strut bolt goes. I’ve used this tiny wrench for my air grinder, as well as big washers, or pieces of metal I have laying around. Thread in the strut bolt the opposite way so it can press up against the piece of metal, effectively prying the knuckle open:
Take a pry bar and pry down on the knuckle to free it from the strut:
Thanks Daniel “silvapain” for this trick
Now it’s time to separate the lower ball joint from the knuckle. I’m sure with Mazda’s special tool, or a ball joint separator, it would be easier, but it can be done pretty simply with other methods. With the bolt out, the ball joint should come right out of the knuckle, but it being a very tight fit and some corrosion can lead to it being a bit difficult.
Support the hub with a jack-stand.
Then take a hammer and start pounding on the lower control arm, around where the ball joint is. Work at it till the ball joint is almost free. Use a pry bar, or lift up on the knuckle, to remove the knuckle.
Now that the hub/knuckle assembly is removed from the surrounding suspension components, it’s time to remove the axles.
We’ll start with the right axle, there is a joint shaft bracket that needs to be unbolted from the block, held in by 3 bolts.
Here’s a better pic of the joint shaft bracket, and it’s location:
Now the axle can be removed from the transmission. It helps to have a friend hold the axle level, while you can pry the axle out. The prying actions is as goes: use a pry bar, and with a jerking motion pry against the raised edge of the axle, in short bursts, to literally pop the axle out of the trans.
Once the axle/hub assembly is removed, from the trans, set it aside.
Do the same on the left side of the vehicle, and pop the axle out.
Some people say it’s not necessary to remove the subframe to pull the trans. It honestly does not need to be removed, I’ve done a clutch job before with the subframe in place. However, you will save yourself many hours of frustration, by removing it. Why? A portion of the subframe site right underneath the differential, and you’ll spend more time trying to wiggle the trans out of a very tight space. Plus the subframe takes 15min to remove.
Begin with the cross bar behind the subframe, IIRC this is where the bolts are located. The 14mm bolts shown in green, the 14mm nuts shown in yellow, and the one 10mm bolt that supports the fuel line shield portion of the cross bar in red:
Unhook the rubber exhaust hangers that connect the exhaust to the subframe, location in green:
Remove the heat shield on the powersteering rack(red arrow), three 10mm bolts. Then unbolt the powersteering rack from the subframe, three 19mm bolts(shown in green):
Here’s a pic of how to get the center bolt, from the rear of the car:
Here’s a pic from the shop manual:
Now with the rack unbolted, use bungee cords or zip ties, to secure the rack to the exhaust so it doesn’t fall with the subframe.
Unbolt the RMM from the trans:
Now it’s time to unbolt the subframe from the car. CAUTION! The subframe is heavy, support it on jacks/jackstands and have a friend on each side ready to pull it out, once unbolted from the vehicle.
There are 4 main bolts(front 19mm, rear 17mm), indicated in this pic:
Use extensions through the holes in the LCAs to get at the front two bolts:
Remove the 12mm bolts of the support brackets, shown in green, then remove the 17mm subframe bolt, shown in red. Do the same on the other side.
Now that the subframe is detached from the vehicle, lower it slowly, making sure everything is disconnected, and move it from underneath the vehicle. You’ll have to move the FSB/endlinks and tie-rods around so they don’t get caught up on each other.
Time to remove the trans mount. First support the engine as well as trans with whatever methods you have, leave room to remove the lover bellhousing bolts later, or skip a few steps, and pull out the lower bolts now:
This car had a CP-E trans mount at the time of this install. If you have a different aftermarket mount, refer to the supplier instructions, on how to remove it. Here’s how to remove the OEM mount.
Begin with the battery support, held in by two 10mm bolts(pink), and four 17mm bolts(blue).
Next remove the 17mm bolt(red), and pull out the top portion of the mount.
Unbolt the three 17mm bolts/nuts(green), and remove the lower portion of the mount.
For better pics, refer to Jamie’s site: http://jamesbaroneracing.com/support...structions.pdf
Now it’s time to remove the eleven 14mm bolts securing the bellhousing to the block:
Some are hard to get at, so use extensions, and swivel sockets:
Keep the bolts organized as you remove them, so you know where they go upon re-installing:
Yay! Now with all the bellhousing bolts removed, it’s time to get this extremely heavy trans out of the way. Being by lowering the jacks supporting the motor and the trans, in conjunction, to clear the trans from the frame. Use a pry bar to pry the trans away from the block, do this evenly around the bellhousing:
Keep working the trans away from the engine, by pulling it from the wheel well on left side of the car. Once the input shaft is slid out from the clutch assembly, and the trans is free from everything, lower the trans from the car:
Slide the trans from underneath the car, to access the clutch assembly:
Now it’s time to remove the six 10mm pressure plate bolts. If you intend on re-using the stock PP, follow these steps. If not, impact it off. First insert the clutch alignment tool into the center of the clutch assembly, and remove the bolts in a crisscross sequence, to properly release tension of the PP. Bolts shown in red:
Pull away the clutch PP, to access the flywheel. Use a 12mm socket to remove the 6 flywheel bolts(these bolts are not intended to be re-used due to the factory applied thread lock):
Here’s the rear main seal, inspect it for leaks, replace if necessary:
Remove and replace the throw-out bearing, first by unclipping the clutch fork from the ball stud of the trans assembly, by pulling or pushing on this spring:
INSTALLATION PROCEDURES AND TQ SPECS:
Install the new bearing, clean/grease where it connects to the fork, clean/grease the ball stud for the fork, and clean/grease the input shaft:
Install the flywheel along with new bolts. Use either the Mazda SST, or a pry bar, to lock the FW in place:
Install the clutch disc, according to the writing on the actual disc not the shop manual(it’s backwards), and pressure plate using the alignment tool, torque the pressure plate down in the sequence shown here:
Remove the alignment tool.
Now install the transmission. Jack it up underneath the car, once the input shaft is lined up, slide the trans towards the block making sure the input shaft goes into the clutch assembly without binding.
With the input shaft in, push and lift the trans towards the block, align the holes on the trans to the alignment tabs on the block(blue arrows):
With the trans lined up and on the block, begin threading in the bolts, get them all hand tight, then tighten in a crisscross pattern down to spec:
From here, install is reverse of removal. Here are some important TQ specs:
That’s it folks!
Thanks to @Ckmazdaspeed3 for this bitch of a how to, and having to do this 3 times. Thanks to @silvapain for taking away time from his family to help with the install. It took me twice as long to write this guide as it toke us to do this job.
Why did it take us 3 times? Well, we installed the clutch properly the first time, got everything back together and the car would not go into gear properly, as if the clutch was not disengaging properly with the pedal depressed. I thought the clutch disc was installed backwards, because I was tired and forgot to check the orientation it was installed. We pulled everything back apart, and installed the clutch disc according to the shop manual. Same problem, but not as bad, the car would engage 1st gear, and other gears at very low RPM(below 2000k). Pulled everything back apart, found the clutch was engaging due to the disc being backwards, and the tighter clearances between the disc and FW. The springs on the clutch disc were acting as the friction material, rubbing against the FW, around the mounting bolts(shown below). We took the new assembly and the OEM assembly, bolted/torqued the PP to the FW on my counter, to find that the new PP was not set properly, by the PP fingers not being at the same height. It was a self-adjusting-PP, where it needs to be set to the new components, in a press. We installed the OEM components, and the car drove perfectly fine. The reason the clutch slipped in the first place… the rear main seal was leaking near where the oil pan gasket and the seal meet.
Fun pics!!!
Current Fail:
MATT DAMOND is offline   Reply With Quote
The Following 117 Users Say Thank You to MATT DAMOND For This Useful Post:
802MS3 (12-23-2017), 86AmishMs3 (01-14-2012), ak_spray (07-13-2012), alien_sporez (01-14-2012), Alpha (02-10-2012), altaprecision (01-04-2015), Arnie1229 (03-03-2015), atvfreek (03-13-2013), Bap (06-04-2014), bertrand_CX_7 (01-14-2012), Bexar (06-26-2017), BigBoostMS3 (02-17-2014), bigwavedave33 (07-19-2014), bmfms3 (02-25-2012), brandon3212 (04-14-2015), breakfstincluded (02-01-2012), Broxer (04-03-2012), CaptainCode (04-22-2015), Cataphract_40 (01-14-2012), Ckmazdaspeed3 (01-13-2012), Dano (02-09-2013), Dash08 (09-12-2012), dereeek (01-14-2012), DingoDave (02-03-2013), Domino81 (01-14-2012), EdgeAutosport.com (11-02-2012), Element23 (02-04-2016), Elusivellama (01-22-2014), FistPump20fo7 (05-07-2013), forcedinduktion (02-01-2012), Funkster777 (06-10-2013), GLORIFIEDBOZO (04-01-2012), goHAMM (09-30-2014), GregScuba (07-10-2015), hartlch (09-29-2012), J-Liss (03-09-2012), JacksonMS30 (02-10-2012), Jason43 (04-01-2014), JDR767 (12-29-2016), jeopardy98 (04-19-2013), JewBagel254 (04-05-2015), JLee1469 (01-14-2012), jman46 (02-23-2012), JMEngineer (02-04-2016), Jra2011speed3 (12-19-2012), JSmith (04-06-2015), JTMS3 (10-15-2012), kmac (01-14-2012), kritz (02-01-2012), Livingframe (07-02-2015), LumberJack (08-21-2017), Majin~Nieve (11-30-2013), Manny (01-14-2012), Mattyhawk1 (08-24-2015), McGee (04-01-2012), Mchart (09-12-2012), meelo88 (04-02-2013), MicaBlackMS6 (01-14-2012), Micha (05-26-2012), mituc (10-14-2013), modusoperandi (04-18-2017), MS3-a(sore)ASS-rex (01-14-2012), ms3blackmica (03-13-2013), MS3CB (08-09-2013), MS6 P.C. (04-20-2018), Nliiitend1 (01-14-2012), Novej (01-15-2012), nybe0010 (05-08-2013), Oliverms3 (02-10-2012), Onelovesoccer (03-09-2012), p057 (01-14-2012), predapio (01-14-2012), Pseud0logik (03-13-2013), Raider (01-14-2012), rghispanic88 (01-14-2012), RhoadBlock (01-14-2012), robry (03-12-2012), Roddiy (05-06-2013), roguemazda (06-04-2016), ruthless013 (03-09-2012), Sacrilicious (01-14-2012), ScarMS3 (01-14-2012), Sid3wayS (01-14-2012), siegsuwa (12-04-2013), silvapain (01-14-2012), SJP0tato (01-14-2012), skeeter149 (01-14-2012), skeurton (10-10-2012), Skyman88 (08-04-2013), slickety (03-24-2016), someguy (12-30-2013), speed23 (01-14-2012), stevenlapensee (02-10-2014), Strangel (01-22-2015), superq7 (01-13-2012), taf0422 (01-14-2012), tastysi2004 (03-08-2013), tddvrrn (01-14-2012), ThOrZwAr (06-09-2016), TiGraySpeed6 (01-14-2012), Tokay444 (07-13-2014), Tomas (01-14-2012), TriO (01-14-2012), TWOptSL0W (07-12-2013), uncorked11 (01-13-2012), Vader (03-09-2012), voodoo2crue (02-13-2016), vtdone (11-17-2014), VulgarKyle (02-19-2013), WAHBAM (10-01-2012), wankular (02-02-2012), xI Leveler Ix (09-09-2012), Z32_MS3 (05-01-2014), zatara (01-14-2012), ZetaDrift (05-08-2014), Ziggo (01-14-2012), zpele (03-09-2012)
 Old 01-13-2012, 10:38 PM   #2
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
You forgot the alternative for putting the tranny back... Get a big black guy to bench press it into place.
Matt, you look really creepy (like a child molester) in those last photos.
Great write up. I hope you can make it to the motor install!
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
MATT DAMOND (01-14-2012)
 Old 01-14-2012, 03:36 AM   #3
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
This is an epic thread! Holy shit! The detail is amazing. Think it's the same for gen1?
 Old 01-14-2012, 04:19 AM   #4
zatara's Avatar
Posts: 1,499   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
Pick of his head coming through the battery hole in the car, only thing I can think of is the Shining.
Duper detailed write-up. Thank you for taking the time to do it. I can't say I'll ever have to do this, but I like to think that eventually I may need to. And this'll really come in handy.
2010 Mazdaspeed 3 Black Mica
CorkSport SRI/ TIP-- CorkSport TMIC-- Cobb DP-- CorkSport CBE-- Cobb AP Stratified Lex Tune-- Autotech Internals-- Denso ITV22's-- JBR EGR Blockoff-- JBR OCC-- JBR 88 Chrome-Molly RMM-- JBR 80 PMM-- JBR 88 TMM-- Corksport Skidplate-- JBR RSB
Red JBR shift knob-- VG Sharkfin--CS LED interior lights-- Hardwired Valentine 1 Radar detector-- 5K HID lows-- 3K HID Fogs-- 30% tint front, 20% tint rear
zatara is offline   Reply With Quote
The Following 2 Users Say Thank You to zatara For This Useful Post:
Arnie1229 (03-03-2015), MATT DAMOND (01-14-2012)
 Old 01-14-2012, 04:26 AM   #5
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
i would never attempt this myself but now i appreciate the intense work that goes into this job.
fantastic write up as always and thanks for the contributions over the years!!!!
The Following 2 Users Say Thank You to p057 For This Useful Post:
Alpha (10-19-2012), MATT DAMOND (01-14-2012)
 Old 01-14-2012, 05:18 AM   #6
alien_sporez's Avatar
Posts: 1,199   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
Fuck me, epic write-up. I always considered a clutch replacement as too difficult to DIY, but your write-up shows it's not hard... just long and tedious. I think I could tackle this now if I took my time and had some NATOR assistance.
2011 Jaguar XFR Full Resonator Delete Mina Cat-Back Exhaust Staggered Giovanna Portofinos
2010 Mazdaspeed 3 - GONE
alien_sporez is offline   Reply With Quote
The Following User Says Thank You to alien_sporez For This Useful Post:
 Old 01-14-2012, 05:20 AM   #7
Raider's Avatar
Groans: 856
I'm thinking the same thing. A trip to Harbor Freight for some more tools first, though.
Bap (06-04-2014)
 Old 01-14-2012, 05:23 AM   #8
RedBliss's Avatar
Posts: 245   (View Stats)
RedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the world
Groaned at 15 Times in 3 Posts
Awesome write up! This will come in handy down the road. Thank you!!
RedBliss is offline   Reply With Quote
The Following User Says Thank You to RedBliss For This Useful Post:
 Old 01-14-2012, 05:52 AM   #9
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
I'm sorry if I didn't catch it but what kind of clutch did you try to install and it didn't work?
Couldn't believe the markings from the disc springs!
I take it that whole clutch is fukt now?
2012 WRX HB w/mudflaps yo!
The Following User Says Thank You to spnkr21 For This Useful Post:
 Old 01-14-2012, 06:11 AM   #10
bertrand_CX_7's Avatar
Posts: 1,453   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Groans: 52
Groaned at 145 Times in 38 Posts
THANK YOU VERY MUCH!
This will be helpfull to Lot of bronnies like me. Always something I wanted to do for my self.
Please keep up with the Great work. This will make our forum a unique Mazda ressource out there.
TYVM!
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
The Following User Says Thank You to bertrand_CX_7 For This Useful Post:
 Old 01-14-2012, 06:13 AM   #11
86AmishMs3's Avatar
Posts: 3,633   (View Stats)
Groans: 338
Awesome, eagle motorsports organic?
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Current: N54 135i FBO
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
Ckmazdaspeed3 (01-14-2012)
 Old 01-14-2012, 07:32 AM   #12
Groans: 134
Eagle motor sports. Everything is refurbished stock parts iirc, except it is their own friction plate material... This is my dd, so I need something that will feel similar to stock. Luckily, after two fails, we were able to clean the stocker well enough to reuse... A small oil leak was causing it to slip.
The damage was superficial and the parts were sent back to EM and the pressure plate was reset. My motor blew a couple of weeks ago and is being built right now so we will see if this works when I put the new motor in (arp studs, k1 rods, wiseco pistons and port and polished head).
Anybody that is intimidated by this (not talking about u spnkr) if you have time and patience, and some help and beer, give it a try. I had never even worked on a car before just over a year ago. And when we took out my motor I was able to do almost everything (taking the tranny out is the hardest part) after doing this with Matt and silvapain a few months ago.
 Old 01-14-2012, 07:43 AM   #13
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,715   (View Stats)
Groaned at 33 Times in 19 Posts
Great write up.
I don't know about dropping the engine cradle though. I didn't do that and things worked out fine.
Edit: Now that I read this in more detail dropping the sub frame seems like a good idea. I do remember I suffered intensely trying to wiggle the gear box out of there. I like the idea of using zip ties to keep the steering rack in place. Fucking win.
Just a couple of notes from my experience:
1. The passenger side axle does not need to be pried out. It slides out easily.
2. The driver's side axle has a snap ring which keeps it pretty tight in place. I used a chisel and with the flat side against the CV joint and the shaft against the gear box tapped it out. You can also hit it with a bar and hammer through the passenger side of the gear box once that shaft is of. I tried that and wasn't successful so I used the chisel.
MAKE LOVE TO THE CANVAS
 Old 01-14-2012, 08:02 AM   #14
greenespeed's Avatar
Posts: 1,320   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
Amazing write up guys. Info will be handy next weekend as Nator TN/KY will be doing this on a MS3 and a MS6. How much more difficult will a 6 be versus the 3? thanks.
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is offline   Reply With Quote
 Old 01-14-2012, 08:06 AM   #15
Groans: 134
@Tomas Silvapains advice worked great for me a couple weeks ago when I pulled my motor (this was the only major hang up). Just grab the axle on either side of the cv and make a few sharp jerks... Comes out in under 5 seconds for the driver side axle. I know u don't need to know how, just saying the easy way I did it.
Someone will be able to clarify better I'm sure, but it is A LOT harder on a six.
I think it is the same for gendone, but I'm positive that the hardest parts (suspension and tranny itself) are the same.
Last edited by Ckmazdaspeed3; 01-14-2012 at 08:08 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
MATT DAMOND (01-14-2012), Tomas (01-14-2012)
 Old 01-14-2012, 09:00 AM   #16
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
excellent write-up!
Thanks for the blood, cursing & effort that you've shared!
I'm taking away the opinion to treat this as several smaller easier jobs, rather than one big badass mutha of a job. Before you know it, the trans is on the floor.
I'm also glad to see the info on what NOT to do regarding the clutch parts assembly on the car. THAN YOU for sacrificing the time to do the job three times & get it straight, and share with us what didn't work and why! That info is worth it's weight in gold, just as much as the rest of the write-up.
340hp / 371tq
 Old 01-14-2012, 02:13 PM   #17
Excellent write-up Matt.
 Old 01-14-2012, 02:43 PM   #18
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
great write up! it's peeps like you that make this forum the best. real info, bitches!
The Following User Says Thank You to tddvrrn For This Useful Post:
 Old 01-14-2012, 03:09 PM   #19
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Wow, great write up. In your experience is this as hard as an intake install?
That intake was a bitch.
What a lovable bunch we are!!
The Following 2 Users Say Thank You to predapio For This Useful Post:
MATT DAMOND (01-14-2012), MS3-a(sore)ASS-rex (01-14-2012)
 Old 01-14-2012, 03:53 PM   #20
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
hehe he's riding a tranny. good write up though.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
The Following User Says Thank You to dereeek For This Useful Post:
 Old 01-14-2012, 04:12 PM   #21
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Kick ass Matt! Excellent write-up. God you're one sexy ginger
NATOR PA
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
 Old 01-14-2012, 05:28 PM   #22
Cataphract_40's Avatar
Posts: 1,729   (View Stats)
Groans: 30
Originally Posted by MATT DAMOND View Post
So sexy. I want a MATT DAMOND transmission mount
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following 8 Users Say Thank You to Cataphract_40 For This Useful Post:
alien_sporez (01-16-2012), Ckmazdaspeed3 (01-14-2012), forcedinduktion (02-01-2012), MATT DAMOND (01-14-2012), Micha (05-26-2012), Raider (01-16-2012), rghispanic88 (01-14-2012), WAHBAM (10-01-2012)
 Old 01-14-2012, 05:55 PM   #23
Domino81's Avatar
Posts: 5,081   (View Stats)
Holy fuck, I had no idea a clutch swap was so involved.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 01-14-2012, 06:12 PM   #24
rigor's Avatar
Posts: 2,397   (View Stats)
rigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the world
Groans: 40
holy Jesus h Christ you don't have to pull the k frame lol
BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw
472 hp 461tq virtual dyno and ran out of fuel!
nishan said theirs a easy 550 in the setup if i had the fuel but meh...
54,000 miles big turbo! stock block
at 104000 2 bent rods
current miles 113000 and runs perfect! no hiccups!
tuned by nishan
rigor is offline   Reply With Quote
 Old 01-14-2012, 06:24 PM   #25
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
awesome write up. funny too.
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
 Old 01-14-2012, 06:32 PM   #26
hank25's Avatar
Posts: 71   (View Stats)
hank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant future
Wow great work! Nice write up!
Cobb SRI Cobb BPV SURE TIP SURE RMM KMD Internals SU Test Pipe JBR Stage 2 FREEKTOONZ
hank25 is offline   Reply With Quote
 Old 01-14-2012, 06:37 PM   #27
rigor's Avatar
Groans: 40
bottom pinch bolt, axle nut, pry down on A arm, and pull out on the knuckle, pull the axle out, out of the knuckle then pop it out of the trans , and the hole damn thing can hang their and leave the k frame in much easier...
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
 Old 01-16-2012, 06:53 AM   #28
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
@Raider pulled mine out yesterday and everything was the same for a Genwon. @MATT DAMOND big thanks for the write up it's awesome and @silvapain for the trick with the struts. Thanks again guys this worked out great.
Raider likes this.
The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Ckmazdaspeed3 (01-16-2012), silvapain (02-03-2012)
 Old 02-01-2012, 08:45 PM   #29
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Great write up and epic pics
 Old 02-01-2012, 10:02 PM   #30
Novej's Avatar
Posts: 353   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
Wow just Wow Can't wait to do this project
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
 Old 02-02-2012, 10:32 PM   #31
Ur moms boyfriend
Sorry Matt I couldn't help myself....
The Following User Says Thank You to forcedinduktion For This Useful Post:
alien_sporez (02-09-2012)
 Old 02-10-2012, 05:35 AM   #32
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Matt you're wearing $25 mechanic gloves and $5 sandals
I has confused.
 Old 02-10-2012, 05:50 AM   #33
I has confused.
Has his priorities in order
340hp / 371tq
Alpha (02-10-2012)
 Old 02-10-2012, 06:01 AM   #34
rigor's Avatar
Groans: 40
if you pull the k frame you have to have your alignment done jfyi
tuned by nishan
 Old 02-10-2012, 07:34 AM   #35
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
Shit gets DONE in that garage man! Badass!
I literally laughed out loud when I saw that Matt D SRI pic lol
 Old 03-09-2012, 06:54 AM   #36
ruthless013's Avatar
Posts: 603   (View Stats)
ruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the world
Groans: 52
thanks a shit-ton for this stellar write up. r&r of this tranny looks significantly more of a pain in the ass compared to a honda b-series, which i've done several times. i don't think i'll be dropping the ms3 tranny onto my chest like i did the honda.
trannys dropping on my chest. thats right i said it.
Majin~Nieve likes this.
2010 Black Mica Mazdaspeed3
2009 Black Cherry CX-9 AWD
1997 Classic Red Miata
ruthless013 is offline   Reply With Quote
 Old 04-01-2012, 08:31 AM   #37
Here is an alternative method for reinstalling the transmission on the engine:
Instead of using a jack to lift the transmission back into place, use a cherry picker and a strap.
I believe thanks go out to @GLORIFIEDBOZO for this idea.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
GLORIFIEDBOZO (04-01-2012), McGee (04-01-2012), Micha (05-26-2012), Nliiitend1 (04-01-2012)
 Old 04-01-2012, 09:18 AM   #38
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
So did Clint's clutch go smoothly/as planned yesterday? Sorry I couldn't make it down...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
silvapain (04-01-2012)
 Old 04-01-2012, 01:24 PM   #39
For the most part. We had trouble with his front suspension; some pieces just didn't want to come apart. Otherwise it went without fail.
That reminds me: another thing to note on the clutch install is to use Moly Grease or similar high-temp grease on the collar for the throwout bearing. DO NOT USE WHITE LITHIUM GREASE as it cannot withstand the temperatures, and will eventually turn into a gummy substance that will bind the TOB.
We believe this was the issue with @phate's clutch getting harder to press and he went through the gears at WOT.
GLORIFIEDBOZO (04-03-2012), Nliiitend1 (04-01-2012)
 Old 04-03-2012, 12:18 PM   #40
Exactly how high of a tempature rating are you thinking? I was curious about this as I did Matt's clutch this weekend. I will have to look at what I used when I get home.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f429/how-mazdaspeed3-replace-clutch-102245/
What Did You Do To Your Car Today? - Page 389 This thread Refback 10-11-2015 04:13 PM
HOW-TO: MAZDASPEED3 REPLACE CLUTCH - Mazdaspeed Forums This thread Refback 11-28-2014 04:00 AM
HOW-TO: MAZDASPEED3 REPLACE CLUTCH - Mazdaspeed Forums This thread Refback 11-28-2014 03:58 AM
Rok - build and boost my MZ3 2006 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-08-2014 04:48 PM
Bryan's Message Board This thread Refback 07-23-2013 10:59 AM
Clutch write up. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-24-2013 06:23 AM
4th Gear Temporary Power Reduction - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-18-2012 04:40 PM
how to replace pcv value for gen 1 ms3? boostedms3 MazdaSpeed 3 - How-To's 17 10-14-2012 12:25 PM
clutch vibration at top of clutch PLEASE HELP livetoskate06 MazdaSpeed 3 - Engine, Transmission & Driveline 84 03-06-2010 05:53 PM
Replace Air Filter Campo MazdaSpeed 3/6 - Turbo Induction 12 02-09-2010 10:39 AM
How do i replace my fogs? speedster 3 Mazdaspeed3/6 General Discussion 16 11-02-2008 05:34 PM
Page generated in 0.69929 seconds with 50 queries
