> 2010 MS3 - How-To's
Like Tree2Likes
  • 2 Post By bigriver
 Old 02-18-2012, 08:11 PM   #1
bigriver's Avatar
Posts: 1,123   (View Stats)
Default How to repair stripped rmm nut with helical thread repair kit
I stripped the nut on the subframe for the vertical bolt that is inserted in the rear motor mount. Don't know how this happened because I am very careful about not cross threading nuts and using the specified torque. But oh well, shit happens, lol.
It all started when I started getting slightly more vibration and deeper exhaust drone. The changes were very subtle, but noticeable. At first I tried using blue loctite, split lock washer and a nord lock washer, but nothing worked. @jbarone advised me to take a look at the nut whenever I tried something different to keep the bolt from loosening. The last fix I tried using the nord lock washer did not hold, and when I checked the nut, there was a piece of thread sticking out from the bottom of the nut. I pulled it out and knew it was fucked! Here is the piece that I pulled out:
Anyway, on the bright side, I did learn how to repair a stripped nut using a helical repair kit. I know there are other ways to fix this issue but I thought I would use this method. This is the first time I've ever done this so feel free to comment and add any useful tips.
So I purchased a Powercoil helical repair kit (m12 x 1.25) from Grainger. Here are pics of the kit:
The first step was to use the included 31/64 drill bit to clean out the nut. Be sure you have a 1/2" drill. I now have a nice new Dewalt 1/2" drill because of this, lol. Fortunately, the drill bit fits through the lower subframe hole. Be sure to wear safety glasses because pieces of metal will fly out. I also put some oil on the bit.
Next, use the tap and thread the nut for the new coil. You need to supply your own tap wrench. I also put some oil on the tap.
Next, insert the coil insert tool through the hole in the subframe, then attach the collar that holds up the new coil and tighten the grub screw on the collar.
Place the new coil on the insert tool. Note that I did not trim the coil and kept it at the 18mm length out of the box. This makes it easier to thread the bolt. On my first attempt, I did trim the coil but the bottom of the coil would not go all the way in the hole. So I pulled it out and said fuck it, I'll just leave it a little long. It doesn't stick out very far. The experts will groan at me for this but it worked in the end so I'm fine with it.
Finally, insert the new coil into the nut and thread it in. There is a "tang" at the top of the coil that is supposed to be broken off. I tried a few times and couldn't break it. Doesnt matter. I forgot to take a pic of the new coil in the nut.
I then reinstalled the rmm and torqued everything down. Yes!! Now I can drive the car again and make more WOT logs!
Hopefully this is useful to y'all. The kit cost me about $75 and it comes with 10 coils. Big thanks to Jamie for listening to my various "fixes" for the loose rmm bolt. He was the one that pointed out that the nut was probably the issue. I was always able to torque down the bolt until the last time when the thread finally came out.
Summary: bigriver stripped nut. fixed with powercoil m12x1.25 helical thread repair kit. back in business.
Tools:
safety glasses
small screwdriver (for grub screw on insert tool collar)
1/2" drill
large tap wrench (for 12+mm tap)
Powercoil m12x1.25 thread repair kit (includes 31/64 drill bit, tap, insert tool and 10 coils).
rfinkle2 and kritz like this.
The Following 18 Users Say Thank You to bigriver For This Useful Post:
ak_spray (04-05-2012), allo80 (03-18-2014), atvfreek (02-19-2012), Caveman4684 (11-19-2012), Don06speed6 (02-19-2012), Easter Bunny (04-05-2012), franz (04-03-2012), himurax13 (04-09-2012), kairojya (02-27-2012), outshined (04-08-2012), Raider (02-19-2012), rfinkle2 (02-19-2012), robry (02-19-2012), SJP0tato (04-08-2012), SKiZ0TT (02-27-2012), SLOWHATCH (02-19-2012), The Nut (03-14-2014), Tibu (10-25-2012)
 Old 02-19-2012, 06:14 AM   #2
JBR
JBR's Avatar
Posts: 6,604   (View Stats)
Groans: 28
Damn fine job sir.
This "how to" can be applied to so many situations; thanks for posting.
Jamie
JBR is offline   Reply With Quote
The Following 6 Users Say Thank You to JBR For This Useful Post:
atvfreek (02-19-2012), bigriver (02-19-2012), kritz (04-08-2012), rfinkle2 (02-19-2012), robry (02-19-2012), SLOWHATCH (02-19-2012)
 Old 02-19-2012, 06:53 AM   #3
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
I'll send msf bucks $500,000 your way when I get on a puter.
Great thread!
The Following 2 Users Say Thank You to Raider For This Useful Post:
bigriver (02-19-2012), rfinkle2 (02-19-2012)
 Old 02-19-2012, 12:36 PM   #4
bigriver's Avatar
Thanks guys!
I think the problem is that the threads on the nut are weak. Since I was able to pull out most of the old thread intact, it looks like it was shearing/vibration force that stripped it out. After I torqued down the bolt, I even marked the bolt head and the subframe to see if the bolt was backing out. The marks matched up perfectly so the bolt was not moving. When I tried retorqueing it, the bolt was loose. Really not much I could have done to prevent it I guess. This was really strange.
 Old 02-19-2012, 12:50 PM   #5
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Thanks for taking the time to do the write-up. Great pics btw.
 Old 04-05-2012, 02:24 PM   #6
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
Great writeup big river. I sent you a pm about some assistance. I am low on funds after purchasing Jamies Trilogy mount kit . Is it possible to put in a longer bolt and a lock nut above the threads?
bigriver (04-08-2012)
 Old 04-05-2012, 02:59 PM   #7
bigriver's Avatar
I've read some posts where guys have done that but finding the bolt and nut is the issue. The nut has to be small enough to fit in that space above the welded nut. You also need the proper grade of bolt as well and will likely have to cut the bolt to fit since most standard sizes are too long. So if you have to drill out the welded nut anyway, might as well do it the right way with the helicoil and not worry about it down the road. I can help you fix it this weekend or you can borrow my kit if you need it sooner. I replied to your PM so give me a call or text me and let me know what you want to do.
The Following User Says Thank You to bigriver For This Useful Post:
gearhead750 (04-05-2012)
 Old 04-08-2012, 02:40 AM   #8
bigriver's Avatar
Ok. Did the rmm stripped nut repair on @himurax13 ms3 yesterday. The threads were also stripped clean.
So some other notes are to use a lift or something that will get the car up high enough to fit the drill and long drill bit. We used my race ramps. See pics
 Old 04-08-2012, 07:04 AM   #9
Posts: 7,290   (View Stats)
A right angle drill would help too, to break the tang use a screwdriver and smack it with a hammer or a nice punch would be the correct tool. Nice write up, when doing repairs it is hard to document usually more concerned with the fix. So Kudos to you Sir!
Nator is what it does.
 Old 04-08-2012, 09:38 AM   #10
bigriver's Avatar
Thanks! Yes a right angle drill would have been perfect. I have one but I think its a 3/8". If its a 1/2" I'm a retard because I bought a new drill lol. I didnt even think of using a screwdriver. Awesome!
kritz (04-09-2012)
 Old 04-09-2012, 12:01 PM   #11
himurax13's Avatar
Groans: 255
Stripped clean? It looked like a smoothbored hole.
Bigriver, what about the other pic with the helical installed?
Its nice to know Mazda uses bolts that are stronger than the threads. Without Bigriver, I would have been totally screwed.
Of course, after Big River leaves the mailman decided to drop off the James Barone 88 Durometer Motor mounts.
So I spent 4 hours installing the RMM and PMM. Everything seems to line up and is torqued down properly.
The car is now a totally different animal. It feels like a rumbling racecar and I don't need to worry about the RMM bolt falling out.
 Old 04-09-2012, 12:10 PM   #12
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
so... he's the one who did it for you.. nice!
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline   Reply With Quote
 Old 04-09-2012, 12:28 PM   #13
bigriver's Avatar
@himurax13 Glad you got the rmm and pmm installed! That is awesome.
Here's the pic of the repaired nut with the helicoil inside.
gearhead750 (04-09-2012)
 Old 04-09-2012, 01:46 PM   #14
himurax13's Avatar
Groans: 255
Bigriver is a nice guy, but I think Corona is a bit far for our weekly meets.
Now if I could get a hand on this pesky Transmission motor mount install. I finally got a decent jack and a torque wrench.
 Old 04-09-2012, 03:07 PM   #15
bigriver's Avatar
If you can wait, I can help you on April 28 or 29. I'm busy at work the next two weekends. But really, the tmm is not hard at all. The only thing I would add to the jbr guide is to break the oem bushing bolt loose while the car is on the ground in case you have to put some muscle into it. It may get sketchy if the car is raised and you try to wrestle with that bolt. And like I mentioned, be careful with the bolts on the tranny housing.
 Old 04-10-2012, 10:25 AM   #16
himurax13's Avatar
Groans: 255
Hmm, another detail that is nice to know. Is that the bolt that needs to be torqued down to 120 lbs?
 Old 04-10-2012, 10:44 AM   #17
bigriver's Avatar
Yes, this is the single bolt in the bushing on the oem mount. Just need to break it loose. Then remove completely after car is raised and tranny is supported by a jack.
 Old 02-28-2014, 01:08 AM   #18
The Nut's Avatar
Posts: 1,571   (View Stats)
The Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the world
Groaned at 38 Times in 20 Posts
I have to revive this thread because as @himurax13; helped me verify tonight, my RMM bolt hole is stripped. I know @bigriver; is no longer active on here, but if there is anyone in the L.A. Metro area that can help me do this if I buy this kit. I don't have a proper jack, jack stands, ramps, or even a drill. And I most certainly don't have a lift. Please let me know if there's anyone out there who can help me. Only thing holding the bolt in there right now is some red Loctite and prayers. Only other thing holding the engine in place are OEM PMM & TMM. They won't last long like this. Please and thank you.
2012 BLACK MICA w/TECH
Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches
Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18
Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob
Stereo: Full Custom Mobile Audio/Video Entertainment System
91 & Corn diagnostics by:
The Nut is offline   Reply With Quote
The Following User Says Thank You to The Nut For This Useful Post:
himurax13 (06-29-2014)
 Old 02-28-2014, 03:39 AM   #19
Raider's Avatar
Groans: 856
You need too not post here, but in NATOR SoCal, son.
The Nut (02-28-2014)
 Old 06-28-2014, 03:26 PM   #20
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Addikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the world
Groans: 157
Groaned at 29 Times in 16 Posts
I used this same repair kit on my pmm threads yesterday, it was a pita, but worked out great
09 MGM MS3
BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s
Addikted To Boost is offline   Reply With Quote
 Old 11-10-2014, 10:50 AM   #21
Matrix311's Avatar
Posts: 2,133   (View Stats)
Matrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the world
Thanks for this thread with photos! I just ordered this same kit but from Zoro Tools for $55 shipped. My rmm main stud is also stripped out. I got under my car yesterday to retrieve a nut that I dropped and I saw the rmm stud sticking half way out of the hole so I figured I better torque it down. Went to tighten it up and it stopped at about mid resistance and then just kept spinning with no more meat to grab. I tried tapping it again with the same pitch and no go! Did a quick google search and this thread popped up and i'll be doing my first helicoil patch this week. Thanks for the great photos, I feel confident this will be an easy fix. I already got the dewalt drill and a tap wrench so i'm good to go. Will post results when this is complete.
Eric Schlaht - Arizona Phoenix Photographer
http://www.esimaging.net - http://www.facebook.com/esimaging
2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14**
**9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp
**11/19/13** Forged engine built and started up the car for the first time, success!
**3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno
**6/24/15** Sold the Mazdaspeed 3
**7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package
Matrix311 is offline   Reply With Quote
 Old 11-10-2014, 11:52 AM   #22
The Nut's Avatar
This link below might also prove helpful. It was my journey of repairing all 4 bolt holes that got stripped. Hopefully it helps, and good luck with your repair.
http://www.mazdaspeedforums.org/foru...t-hole-165402/
himurax13 (11-10-2014)
 Old 11-11-2014, 08:52 AM   #23
Matrix311's Avatar
So it looks like you two were successful in replacing the vertical rmm stud that screws into the subframe but were not able to hammer out the 3 holes that go into the transmission. Any extra advice you can give me for when I do just the rmm stud since thats all I have to do?
 Old 11-11-2014, 01:05 PM   #24
The Nut's Avatar
Actually, if you look in the previous post I attached a link to my personal thread on how all 4 bolt hole repairs were done. (Holes on tranny were technically done by Eric the Bolt Guy, but is well documented with the necessary repair kits that need to be ordered whether your doing the one verticle bolt hole your trying to repair, or the 3 on the tranny.
For yours, it couldn't be more straight for ward.
-Get car up on lift (can be done on ramps or Jack stands, but I don't suggest it for easy clearance of drill and long but needing clearance for proper angle.
-use included bit in kit to drill out old thread hole in sub frame.
-re-tap with included tap tool. Follow instructions for proper installation of helicoil.
-put RMM back in place and reinsert bolt. Helicoils generally make the bolt hole good for 25ft lbs of Tq wrench pressure over OEM, so you'll know the work has actually improved the vehicle.
Hope this helps, let me know if you have and more questions.
Post #15 in that thread shows the kit you need.
 Old 11-12-2014, 09:32 PM   #25
Matrix311's Avatar
All done! Kit came in via ups this afternoon and I completed the job in about 15 minutes. Was able to torque down the rmm stud bolt and all is back to normal.
Used same kit as in op. Bought from zoro tools for $55.
Finished with new threads in place.
Thanks so much to op guy. I hear he's not on msf anymore but if you ever read this thread again you saved me big time. Msf ftw again.
The Following User Says Thank You to Matrix311 For This Useful Post:
The Nut (11-12-2014)
 Old 11-12-2014, 10:46 PM   #26
The Nut's Avatar
Easy peasy
PCV repair question tuners Mazdaspeed3/6 General Discussion 6 11-03-2011 05:01 PM
Transmission Repair RWDAddict MazdaSpeed 6 - Engine, Transmission & Driveline 12 08-29-2011 11:42 AM
Issues after repair Speed6Guy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-13-2011 02:19 PM
Page generated in 0.53781 seconds with 29 queries
