> 2010 MS3 - Wheels & Tires
 Old 11-06-2011, 05:50 PM   #1
Posts: 7,290   (View Stats)
Default 17" x 9" what offset
I tried on a set of Enkie RFP1's 45mm offset with 245/40/17 Dunlop Direzzas on them and the rear was just fine but the front was rubbing the strut, has anyone run this set up and with what offset 40 would prolly work and 38 would be hella frush(not what I'm looking for). Want an auto cross set up and to widen the track a bit as well as having a little moar side wall for the great roads around here in the NYC metro area.
Nator is what it does.
rfinkle2 (11-07-2011)
 Old 11-06-2011, 05:51 PM   #2
apena85's Avatar
Posts: 470   (View Stats)
apena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the worldapena85 is the leader of the world
My tires are 245/40/17 not what you posted... I believe a 42 offset will be good. Someone with more wheel fitment experience might know better.
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
apena85 is offline   Reply With Quote
The Following User Says Thank You to apena85 For This Useful Post:
kritz (11-06-2011)
 Old 11-06-2011, 05:55 PM   #3
rabble rabble
802MS3's Avatar
Posts: 5,311   (View Stats)
Groans: 221
i haz 17x9 +45 with 5mm spacer up front with bilsteins.
'08 CWP MS3 w/ T3 3071r
The Following User Says Thank You to 802MS3 For This Useful Post:
kritz (11-06-2011)
 Old 11-06-2011, 05:58 PM   #4
apena85's Avatar
He has a Genpu... I have a genwon with the set up he stated.
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
 Old 11-06-2011, 05:59 PM   #5
Is that on a won or pu?
 Old 11-06-2011, 06:31 PM   #6
beachshoer's Avatar
Posts: 2,039   (View Stats)
beachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the world
Im running 17x9 when I race with 10mm spacers up front with 255s. Genpu with stock struts and hr springs.
2010 BM MS3
BNR S3
HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs
H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines
Works emotions cr-kai 18x7.5 ventus v12s for the street
TRM C3s 17x9 Hankook RS3s for track days
STRATIFIED TUNED
Other Mazdas in my stable
2010 VR MS3 Wifes Ride
ETS TMIC JBR RSB JBR SSP JBR knob AT internals
1999 Miata
gtx2867 1.9L VVT built like a brick shithouse
2001 Miata LS
RB FSB Hawk HP+ pads Dunlop ZII
beachshoer is offline   Reply With Quote
The Following 2 Users Say Thank You to beachshoer For This Useful Post:
kritz (11-28-2011)
 Old 11-06-2011, 06:34 PM   #7
17 x 9 with what offset 45? RFP1's?
 Old 11-06-2011, 06:40 PM   #8
beachshoer's Avatar
Sry forgot the offset. 45 offset. TRMotorsport C3s. They were on sale on tirerack. Just something to mount my sticky tires on.
2010 BM MS3
BNR S3
STRATIFIED TUNED
1999 Miata
2001 Miata LS
The Following User Says Thank You to beachshoer For This Useful Post:
kritz (11-06-2011)
 Old 11-06-2011, 07:04 PM   #9
Thanks , I would rather not use spacers so 40mm offset would do it.
 Old 11-07-2011, 11:39 AM   #10
rabble rabble
802MS3's Avatar
Groans: 221
sorry, i have a genwon. didn't realize you had a 2010.
The Following 2 Users Say Thank You to 802MS3 For This Useful Post:
kritz (11-07-2011)
 Old 11-07-2011, 02:48 PM   #11
myt_tuf1's Avatar
Posts: 256   (View Stats)
myt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the world
Enkie RPF1 17x9 +45 w/Hankook Ventus V12 Evo K110 235/45-17... Note that I have Koni Yellows. On these shocks, the front are indented enough so the wheel doesn't touch... I'm not sure with the stock shocks though...
Front Fitment in Relation to Koni Sport Shock
More pics and info here: Matte Black Enkei rpf1 17x9 +45
Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC
myt_tuf1 is offline   Reply With Quote
The Following User Says Thank You to myt_tuf1 For This Useful Post:
kritz (11-07-2011)
 Old 11-07-2011, 03:40 PM   #12
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
yeah, i think you're gonna have to run 5mm or 10mm spacers
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
kritz (11-07-2011)
 Old 11-07-2011, 09:40 PM   #13
Looking at the Enkie website it seems that I will have to go with a 17 x 8.5 with a 40 offset the 17 x 9 would be a 35 or a 45. So either herra frush or spacer FTL. The Dunlop Dirreza star specs in the 245/45/17 are 25.7 in diameter compaired to the 25.1 of the stock 225/40/18 I guess I will have a longer 2nd gear for a/x.
 Old 11-08-2011, 03:47 AM   #14
apena85's Avatar
Just keep in mine that the smaller size of the wheel wil change the look of the rim. You won't have s lip like me and the spokes wil kind of pop out a bit. Look at Vasken's old tires, he had 38 offset and 8.5/17 eith 235/45/17
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
The Following 2 Users Say Thank You to apena85 For This Useful Post:
kritz (11-08-2011)
 Old 11-08-2011, 05:27 AM   #15
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Ugh I hate this whole wheel/tire/offset ratio. Makes my fucking head hurt.
Good luck kritz. At least you got some answers. I can't figure out dick for my genwon lol
NATOR PA
kritz (11-08-2011)
 Old 11-08-2011, 06:12 AM   #16
deadbeatrec's Avatar
Posts: 47   (View Stats)
deadbeatrec is infamous around these parts
Groaned at 51 Times in 12 Posts
im with u man. what a shitty set up we have.
deadbeatrec is offline   Reply With Quote
 Old 11-08-2011, 06:25 AM   #17
apena85's Avatar
Steve I say just go ahead and get the spacer. the 45 offset looks way better then the 38.
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
 Old 11-08-2011, 06:38 AM   #18
what spacers are people using?
 Old 11-08-2011, 06:40 AM   #19
Ex_WRX_driver's Avatar
Posts: 719   (View Stats)
Ex_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the world
Im looking at 17x9 with a 42mm offset. Wanna run 235/45/17. No plans to lower the car. Think this will be ok?
I really hat trying to figure this shit out, always gives me a headache. lol
2011 Liquid Silver
Corksport SRI/TIP/AIRBOX
Ultimate Racing catback
JBR stage 2 shift kit
SURE RMM
Ex_WRX_driver is offline   Reply With Quote
The Following User Says Thank You to Ex_WRX_driver For This Useful Post:
MS3-a(sore)ASS-rex (11-08-2011)
 Old 11-08-2011, 06:50 AM   #20
apena85's Avatar
Genwon or Genpu?
On my genwon I don't use spacer and so far I have not have rubbing issues.
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
Last edited by apena85; 11-08-2011 at 06:50 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-08-2011, 06:53 AM   #21
trf5000's Avatar
Posts: 2,290   (View Stats)
17s with anything higher than a 42 offset will most likely rub on the stock strut assembly up front.
@kritz, i would go with the 17x8.5 40 offset. That should do you good and allow you to run a tire for autox.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 2 Users Say Thank You to trf5000 For This Useful Post:
kritz (11-08-2011)
 Old 11-08-2011, 06:55 AM   #22
Genpu for me.
2011 Liquid Silver
SURE RMM
 Old 11-08-2011, 06:59 AM   #23
Thanks Tyler, I believe I will go with 40 on the offset and get the 245/45's 17's.
@trf5000
BTW are you going to join us for a fishing trip? Check the NY,NJ Nator thread.
 Old 11-08-2011, 07:35 AM   #24
Groans: 224
@apena85 would a 30 offset be ok to run? Wheel size would be 17x8.5 30mm offset. You seem way more knowledgable than me with this shit so I could use the help.
Sorry for the threadjack Steve lol
Edit: or would a 17x8 35mm offset be better? Either set would be run with 235/40/17 Nitto NT-05's. Ugh hate this shit!
NATOR PA
 Old 11-08-2011, 07:46 AM   #25
No sweat bro!, 30mm of offset would be hella frush!
 Old 11-08-2011, 08:02 AM   #26
apena85's Avatar
I am new to the whole wheel fitment myself. I am just going off personal experience. But, be aware that with the tire size listed your going to be at -4.7% off on you speedometer, With my current set up I am -3.5% meaning that when my actual speed is 60 my speedometer reads 62.
That would be okay with me but it seems that during some hoonage the traction and DSC activate way often which annoys me. This is why for my next set up (w/ever that is ) will be 245 45/17 which are closer to stock at .28%.
Check this page out for the right tire size you should get at the width you'll like Tire size calculator
I don't know how good is this, but this might be able to help some of us.. .
Wheel Offset Calculator
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
Last edited by apena85; 11-08-2011 at 08:02 AM. Reason: MSF Database - Automerged Doublepost
kritz (11-08-2011), MS3-a(sore)ASS-rex (11-08-2011)
 Old 11-08-2011, 08:18 AM   #27
Groans: 224
What's it take to run that size then?
NATOR PA
 Old 11-08-2011, 08:37 AM   #28
Moar rubber!
 Old 11-08-2011, 08:48 AM   #29
apena85's Avatar
you would have to make the tire taller.
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
 Old 11-08-2011, 08:50 AM   #30
@apena95 Did you finish your homework youngman? Howz the bride feeling?
 Old 11-08-2011, 08:53 AM   #31
apena85's Avatar
I am studying for a midterm right now, physics. But its rather easy as its dealing with the electrical parts only. Oh the wife is fine btw... she is holding my child hostage, I keep telling her to let go of her LMAO...
2008.5 MS3 totaled
2006 ms6 sold
2017 cx9
 Old 11-08-2011, 09:00 AM   #32
The perfect parasite.
LaHood: Getting Toyota to recall took "enormous effort," calls automaker "a little safety deaf" Haltech Automotive News 0 02-02-2010 05:10 PM
Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] Haltech Automotive News 0 08-04-2009 08:40 AM
Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" Haltech Automotive News 0 04-14-2009 12:40 PM
Page generated in 0.48855 seconds with 29 queries
