> 2010 MS3 - Wheels & Tires
 Old 04-21-2013, 06:10 PM   #1
redline's Avatar
Posts: 23   (View Stats)
redline is just really niceredline is just really niceredline is just really niceredline is just really niceredline is just really nice
Default 17x8.25 with 35mm offset
So I bought new wheels for my srt4 neon a couple months ago and traded it in on a 2010 speed 3. Will a 17z8.25 with 35mm offset work and can I use a 235/40/17 as a tire. If so that would be great because I can get the tires from free from my brother.....if not i'll just have to sale them.
redline is offline   Reply With Quote
 Old 04-21-2013, 06:13 PM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Yeah i am running similar setup and offset. You may need a roll in the rear.
Etipp98 is offline   Reply With Quote
 Old 04-21-2013, 06:16 PM   #3
redline's Avatar
I'm going to search some more but do you know what the hub bore is off the top of your head?
never mind, 67.1 is the hub bore......my wheels are 71, will I still need to get hubcentric spacers or is that good enough. i'm such a tire noob.
 Old 04-21-2013, 06:18 PM   #4
Etipp98's Avatar
stock hub bore is 67.1
 Old 04-22-2013, 08:34 AM   #5
GreyGhost's Avatar
Posts: 315   (View Stats)
GreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the world
Pics?
2013 Mazdaspeed 3:
Performance: Autotech Internals // COBB AP // COBB TIP // Cobb Intake & Air Box // COBB FMIC // UR Catted DP V1 // UR CBE // UR Testpipe // Go Fast Bits BPV // Stratified ECBS 2-Port Mode // NGK One Step Colder Plugs // JBR Coolant Bypass Kit // Rotella T6 5w-40 // CP-e Stage RMM // Cp-e PMM // CS Shifrer Plate // Sure Shift Anchors // Redline Plus Hood Struts
VD: 304hp / 333tq Stage 2 91 Octane Freek Tune
GreyGhost is offline   Reply With Quote
17x8 5x114.3 42mm offset mrmonk7663 2010 MS3 - Wheels & Tires 7 12-09-2011 05:25 AM
Varrstoen Wheels - ES 2.2.1 (18 x 8.0 (+35mm) PapaSmurf 2010 MS3 - Wheels & Tires 30 06-09-2011 11:17 AM
Speed with MX-5 wheels and 35mm spacers IshiKage MazdaSpeed 3/6 - Wheels & Tires 20 01-12-2011 03:25 PM
17x8", 43 offset? Fobio MazdaSpeed 3/6 - Wheels & Tires 3 11-09-2008 06:08 PM
Page generated in 0.25656 seconds with 22 queries
