> 2010 MS3 - Wheels & Tires
Like Tree6Likes
  • 1 Post By MazdaBoy2.3
  • 1 Post By Downmented
  • 1 Post By kritz
  • 1 Post By thanu31
  • 2 Post By PapaSmurf
 Old 07-18-2013, 07:07 AM   #1
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
Default 17x9 +45 RPF1's on a Genpu
Specific to Gen 2 speed3's. I DO NOT CARE WHAT YOUR GEN1 is running.
Who has them and what suspension set up are you running. spacers? issues?
I currently have Sonic Tuning coilovers and a set of 17x9 +45 RPF1's waiting to be installed on my car.
I want to know what suspension you're running because it seems that for some reason the inner wheels rub on the strut with sonic tuning coilovers. Ive yet to see pictures though.
thread reference: Need help!! Rpf1 inner rim is rubbing on strut!
Maybe its a brownie issue, but @Voltron Locos; also stated he had the same issue with HKS coilovers on a similar wheel size/offset. He also stated bigger spacers didnt work. (10mm)
I know people are running them and want to know what suspension they are using, I might just have to return the sonic tuning coilovers or sell them and get different ones.
set ups known to work:
H&R Coilovers (spacer may be required)
Koni Yellows
Ksport Coilovers (spacer may be required)
860whp/677wtq
2.7 V6 Ecoboost
The Following 2 Users Say Thank You to PapaSmurf For This Useful Post:
Manny (07-21-2013), rfinkle2 (07-20-2013)
 Old 07-18-2013, 07:12 AM   #2
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
@myt_tuf1; runs that size, but not on coils (I think Koni and spring combo). He reports being close to rubbing the strut.
Largest RPF1 I Can Get?
myt_tuf1 (07-20-2013)
 Old 07-18-2013, 07:14 AM   #3
PapaSmurf's Avatar
Groans: 112
ya i just found that thread and saw he was on koni's.
I really want to know if anyone is actually on any after market coil overs and not having problems as stated.
860whp/677wtq
2.7 V6 Ecoboost
 Old 07-18-2013, 07:14 AM   #4
rfinkle2's Avatar
Groans: 298
I'll help you look because I'm interested too.
 Old 07-18-2013, 07:15 AM   #5
PapaSmurf's Avatar
Groans: 112
pretty much any wheel that is 17x9 +40's or so.
860whp/677wtq
2.7 V6 Ecoboost
The Following User Says Thank You to PapaSmurf For This Useful Post:
rfinkle2 (07-18-2013)
 Old 07-18-2013, 07:16 AM   #6
pwdunmore's Avatar
Posts: 368   (View Stats)
pwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the world
I have the same setup on stock suspension and it's close, probably have 3mm of clearance without spacers.
The spring and shock combo seems to produce more clearance because of coilovers being a little thicker.
pwdunmore is offline   Reply With Quote
The Following 2 Users Say Thank You to pwdunmore For This Useful Post:
PapaSmurf (07-18-2013), rfinkle2 (07-18-2013)
 Old 07-18-2013, 07:19 AM   #7
mghtymouse380's Avatar
Posts: 1,182   (View Stats)
mghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the world
Groans: 58
I have 17x9 with a +45 with z1 star specs. I have 8 mil spacers from oriellys and current coilovers are ksport kontrol pro's. I did need bigger than 3 mil spacers or it would rub the struts.
2013 CWP (DD)
COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP
TUNE IN PROGRESS (RFINKLE2)
1999 Mazda Miata (PROJECT) (blown motor)
BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8
mghtymouse380 is offline   Reply With Quote
The Following 4 Users Say Thank You to mghtymouse380 For This Useful Post:
Downmented (07-18-2013), Manny (07-21-2013), PapaSmurf (07-18-2013), rfinkle2 (07-20-2013)
 Old 07-18-2013, 07:19 AM   #8
Volcom8190's Avatar
Posts: 448   (View Stats)
Volcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the world
Have 17x9s with 255 dunlops, have extended studs and 5mm spacers, stupid close to stock struts, but cleared with no spacers (put 5mms in for piece of mind).
Going to be putting KWs on soon (in the box in garage). Going to break out the calipers and measure the thickest part of each this weekend and see what I need. Not looking forward to having my tires stick out even farther.
2010 - BMW 335i M-Sport - Lemans Blue Metallic
2005 - Kawasaki ZX-6R 636 - Magma Red
Volcom8190 is offline   Reply With Quote
The Following User Says Thank You to Volcom8190 For This Useful Post:
mghtymouse380 (07-18-2013)
 Old 07-18-2013, 07:21 AM   #9
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
MazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the world
Groans: 51
Groaned at 29 Times in 22 Posts
@PapaSmurf;
See post #5469 on the link below guys. Just came across this last night.
http://www.mazdaspeedforums.org/foru.../index137.html
I used to go zoom zoom with my speed....
Now i drive a slow stockish Focus ST...
MazdaBoy2.3 is offline   Reply With Quote
The Following 3 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
PapaSmurf (07-18-2013), rfinkle2 (07-18-2013), YABBAMZR (07-21-2013)
 Old 07-18-2013, 07:25 AM   #10
rfinkle2's Avatar
Groans: 298
That car looks hot!
MazdaBoy2.3 (07-18-2013)
 Old 07-18-2013, 07:25 AM   #11
PapaSmurf's Avatar
Groans: 112
@thanu31; whats your suspension set up?....nevermind I kept reaading that thread and saw that they were H&R coils.
As stated in the OP someone said they used 10MM spacers with the HKS and they still didnt fit? Must be some big ass struts if you ask me.
The question is, Do I want to try 10MM spacers on the sonic tuning coil overs or do I just want to sell those and get the Ksports. Difference in coil overs is very minimal if you ask me.
860whp/677wtq
2.7 V6 Ecoboost
 Old 07-18-2013, 07:28 AM   #12
Volcom8190's Avatar
after seeing all the k-sport fail lately, not just on here but other sites, id pick up the KW V1s, especially with the amount of money you have in the car.
I lost a car to shitty coilovers, with shitty chinese welds..hence the V3 purchase.
Nliiitend1 (07-18-2013)
 Old 07-18-2013, 07:28 AM   #13
Groans: 51
That car looks hot!
Idk what it is but the white lettering on the tires just looks epic IMO. Not to mention the drop and wheels.
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
 Old 07-18-2013, 07:32 AM   #14
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Originally Posted by MazdaBoy2.3 View Post
@PapaSmurf;
Quick thread jack that does not require a response, simply trying to help. But when linking a post to a specific post, if you click the post number, it will put that specific post to the top of the page, and when you copy that URL, it will automatically link people to that exact post. Just FYI
Carry on
MazdaBoy2.3 likes this.
700HP CLUB
11.479@124mph
#DIX
The Following 5 Users Say Thank You to Downmented For This Useful Post:
leon78 (07-18-2013), MazdaBoy2.3 (07-18-2013), PapaSmurf (07-18-2013), rfinkle2 (07-18-2013), YABBAMZR (07-21-2013)
 Old 07-18-2013, 07:32 AM   #15
pwdunmore's Avatar
Thanu is running H&R Coilovers with some spacers... I'm sure he will chime in.
Maybe 5mm spacers all around, but I don't think that's right...
 Old 07-18-2013, 08:18 AM   #16
pwdunmore's Avatar
Looked in my inbox when I messaged him about his fitment, he said he is running 10mm in the front and none in the rear.
The Following 3 Users Say Thank You to pwdunmore For This Useful Post:
MazdaBoy2.3 (07-18-2013), PapaSmurf (07-18-2013), rfinkle2 (07-20-2013)
 Old 07-18-2013, 08:25 AM   #17
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
@kritz; is on the Corksport coilovers and some fairly wide Volks. I think he would have some valuable input to this thread.
2004 MSM TiGrey
The Following 2 Users Say Thank You to Crarrs For This Useful Post:
kritz (07-18-2013), rfinkle2 (07-18-2013)
 Old 07-18-2013, 09:47 AM   #18
Groans: 51
I'm pretty sure his are 17x8.5 with a +40 offset...
kritz (07-18-2013)
 Old 07-18-2013, 12:28 PM   #19
Posts: 7,290   (View Stats)
Matt, You get a gold star. 17/8.5"/40mm offset. Running 245's Starspec II No clearance issues at the struts but the rear needed a roll and pull as well as some plastic inner (rear) wheel well trimming.
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
MazdaBoy2.3 (07-19-2013), rfinkle2 (07-20-2013)
 Old 07-18-2013, 07:16 PM   #20
Mazdaspeed3KHP's Avatar
Posts: 272   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
How low is your rear? I test fitted my 17x9 rpf1 with 245s and it wasn't ribbing at all. I have a 2 inch drop as well. Maybe my dampening is too stiff.
Mazdaspeed3KHP is offline   Reply With Quote
 Old 07-18-2013, 07:35 PM   #21
Not that low, 1-1/2 max. What tires? The star specs seem to have a wider profile than most. I know a 245 is a 245 but shape will differ between brands.
Sent from fastest ko4 Pu!
 Old 07-18-2013, 07:55 PM   #22
I have good year eagle f1 asymmetric 2s. The series would also make a big difference , mine is a 40
 Old 07-18-2013, 08:46 PM   #23
245/45-17 on minez
 Old 07-18-2013, 10:01 PM   #24
thanu31's Avatar
Posts: 40   (View Stats)
thanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond reputethanu31 has a reputation beyond repute
sorry for the late reply.
I am running H&r Coils with no problems at all. I use spacers in the front because of an odd issue with the rims touching my calipers :s
Other then that, they are fine, nothing touching the struts, even with 245/40 starspecs, and starspecs are a bit bulky compared to others
Hope that helps
thanu31 is offline   Reply With Quote
The Following User Says Thank You to thanu31 For This Useful Post:
 Old 07-18-2013, 10:07 PM   #25
abelardo's Avatar
Posts: 135   (View Stats)
abelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond reputeabelardo has a reputation beyond repute
I'm running a 18x8.5 on stock dunlops and stock suspension w/o any problems.
edit: reading fail i thought you meant rubbing on the fenders not the struts. my bad.
2012 Mazdaspeed3 Velocity Red Mica
Corksport SRI & TIP, Cobb AP W/Stage 1 OTS Map, AutoTech HPFP, 18 X 8.5 Enkei RPF1 (Black)
JBR 88a Dogbone RMM, JBR RSB, JBR SSP & Weight,
Waiting to be installed:Corksport Down Pipe, Corksport Test Pipe, and a Forge V2 BOV
abelardo is offline   Reply With Quote
 Old 07-19-2013, 10:46 PM   #26
245/45-17 on minez
There's the difference!
The Following User Says Thank You to Mazdaspeed3KHP For This Useful Post:
kritz (07-20-2013)
 Old 07-19-2013, 11:33 PM   #27
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
I'm on 245 zIIs and I was hitting strut in the front on stock suspension, I have 5mm spacers in the front....and there shouldn't be a need for them in the back (I have tons of room there, unless those cool overs are 20mm thicker than stock). I would think anything more than 8mm or so and you would have to pull the fender liner and roll the fronts the rest of the way. I am lowered on swifts with stock struts. I am super busy but maybe I can get a pic of the current clearance tomorrow with a point of reference so we can better see the actual available clearances.
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
 Old 07-20-2013, 04:21 AM   #28
PapaSmurf's Avatar
Groans: 112
Don't worry about it, I don't care about the stock suspension lol
As far as it goes now, the thread linked in the OP has a confirmed fit with sonic coil overs which is what I have. 10 MM spacers will work. He has pictures in the thread to show it.
Sent from your girlfriends tapabedroom
rfinkle2 and Mazdaspeed3KHP like this.
860whp/677wtq
2.7 V6 Ecoboost
The Following 3 Users Say Thank You to PapaSmurf For This Useful Post:
kritz (07-20-2013), Mazdaspeed3KHP (07-21-2013), rfinkle2 (07-20-2013)
 Old 07-20-2013, 05:27 AM   #29
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,798   (View Stats)
Why don't you just sell the pu and get a genwin? All your problems will go away, all the wheels you'll ever want will fit, and the ladies will like you better. It's a win win win.
MAKE LOVE TO THE CANVAS
 Old 07-20-2013, 07:16 AM   #30
PapaSmurf's Avatar
Groans: 112
There needs to be some type of motivation for the fail Pu owners lol
When I sell the speed3 I will be staying away from the failz wheel drive though.
I plan on getting a C6 Vette, A FD or a Supra.
I am however getting rid of my miata for a 1st Gen CTS-V for my daily when I get back.
860whp/677wtq
2.7 V6 Ecoboost
Manny (07-21-2013)
 Old 07-20-2013, 08:05 AM   #31
2k4_8's Avatar
Groans: 64
Sorry, didn't see that in the post, it was kinda late last night. Gl, should be a sweet setup!!!!
The Following User Says Thank You to 2k4_8 For This Useful Post:
PapaSmurf (07-20-2013)
 Old 07-20-2013, 10:39 PM   #32
myt_tuf1's Avatar
Posts: 256   (View Stats)
myt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the world
I just changed my brake pads and realized that with a fresh set of pads the caliper is pushed out, closer to the wheel, and actually touches the wheel. I had to put washers on the wheel studs to make the wheel clear the caliper; I'll keep the washers on until the pads wear down a little bit.
All in all, a couple 5 mm spacers would not be a bad investment (at least for the front wheels) to keep the wheels from touching the struts (that's not a problem with the Koni's) and the keep them from touching the calipers (when new pads are installed).
BTW, I installed the Akebono pads, if that's of any interest.
Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC
myt_tuf1 is offline   Reply With Quote
The Following 3 Users Say Thank You to myt_tuf1 For This Useful Post:
Mazdaspeed3KHP (07-21-2013), PapaSmurf (07-21-2013), rfinkle2 (07-24-2013)
 Old 07-21-2013, 09:33 PM   #33
Waiting for my new studs and spacers to come in so I can mount mine!
 Old 07-21-2013, 09:51 PM   #34
Manny's Avatar
Posts: 1,185   (View Stats)
Manny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the world
Groans: 320
Groaned at 78 Times in 45 Posts
What size tire do you wanna run on the wheel? If 5mm barely clears get some 10mm spacers because they will clear for sure and you wont have to roll/pull the fenders. Get some extended wheel studs because anything over 8mm you'll barely have enough threads for the lugs. The studs linked below are cheaper than the ms3 specific ones and they work just fine.
http://www.summitracing.com/parts/ARP-100-7708/
Manny is offline   Reply With Quote
Black RPF1 17x9 on CWP 802MS3 Wheels & Tires - WHITE 44 01-05-2014 08:11 AM
Silver 17X9 RPF1's kunfu Wheels & Tires - RED 13 07-31-2013 09:03 AM
17x9 RPF1's +18.. Fit or no fit Droopzy 2010 MS3 - Wheels & Tires 8 10-06-2012 10:40 PM
Page generated in 0.54968 seconds with 35 queries
