> 2010 MS3 - Wheels & Tires
 Old 10-05-2012, 02:13 PM   #1
Droopzy's Avatar
Posts: 23   (View Stats)
Droopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant future
Default 17x9 RPF1's +18.. Fit or no fit
Came across a pretty good deal on a set of RPF1's today and was wondering if the offset being +18 would purpose an issue?
Yes, I did search but no luck even though common sense tells no because every I see on here runs +30 to +40ish offset..
Droopzy is offline   Reply With Quote
The Following User Says NO Thank You to Droopzy For This Un-useful Post:
MS3G35 (10-08-2012)
 Old 10-05-2012, 02:22 PM   #2
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Lol no fit.
+18 is a ridiculous offset.
The amount of poke would be retarded.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 10-05-2012, 02:25 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Really OP?
If you're that unsure plug it into a fucking calculator....
The Following User Says Thank You to helmetface For This Useful Post:
MS3G35 (10-08-2012)
 Old 10-05-2012, 02:33 PM   #4
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
most people here run +40 to +50, or even larger if possible. I have 18x8.5 +38 with 245s and my tires are flush in the back and poke just a tiny bit in the front. +18 is a lot
Blue Pu.
 Old 10-05-2012, 07:04 PM   #5
ahfunaki's Avatar
Posts: 764   (View Stats)
Wheel Offset Calculator
 Old 10-05-2012, 07:20 PM   #6
Code Monkey's Avatar
Posts: 7,660   (View Stats)
I thought they only come in +48 and +63, how did you come up with +18, unless using spacers?
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 10-05-2012, 08:49 PM   #7
Droopzy's Avatar
Originally Posted by smoogs12 View Post
Lol no fit.
Tapa
Thats what I figured but I just had to make sure lol
thanks for the info
Originally Posted by helmetface View Post
Really OP?
Jesus tap dancing christ... Some of us arent as fortunate to know how to work a calculator.
But for reals.. fuck off. But thanks for the input ill take it into consideration <3
After I posted this I was finding this to be true. the 17x9.5 comes in +18 though. Unless there older? I dn
Last edited by Droopzy; 10-05-2012 at 08:49 PM. Reason: MSF Database - Automerged Doublepost
MS3G35 (10-08-2012)
 Old 10-06-2012, 10:18 PM   #8
bmfms3's Avatar
Posts: 244   (View Stats)
bmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond reputebmfms3 has a reputation beyond repute
Groans: 31
Yeah I run 18x9.5 with an offset of 30 and it looks tough and pokes out quite a bit. But i ddon't care cuz I'm running 245 all around its not just looks
Originally Posted by rghispanic88 View Post
I WOULD BLOW SOME AIR INTO HER ASS JUST SO I CAN SMELL ONE OF HER FARTS.
OLD 2010 Diamond White Pearl yes the GM color Mazdaspeed 3
Current Mods: Forge BOV l window tint all around l resonator delete l DDM HID 6k lows l Larger exhaust tips l JBR SSP STG 2 l JBR PMM 80 l JBR TMM 88 l Autotech internals l CP-E TMIC l Rally Armor ''RED'' Mudflaps l CP-E catted DP l Heavy Foot l CS SRI w/TIP l CS racepipe l TRZ RMM "Delrin" l CP-E towplate l Cobb AP l CS Boost Tubes l CS LED INT Kit l CS fog leds l
NEW 2012 LSM MS3 TECH PKJ - 30% E85 Mix -Devils Own Meth Kit D07100% 345HP/375TRQ
Cobb AP -91oct Tune by cld12pk2go & E85 tune by LEXl CP-E catted DP w/ 3in Elec Cutout l CP-E TMIC l CS Boost Tubes l Forge BOV l PnP Intake Mani by Cornnutz l DNP Exhaust Mani l JBR ''Whale Penis'' non recir l SURE Halos l Autotech FP Internals l JBR SSP STG 2 l JBR PMM 80 l JBR TMM 88 l TRZ RMM 88 l SURE TIGS l SURE BSD l JBR Oil Baffle l ITV22 l Rally Armor ''RED'' Mudflaps l Larger TI exhaust tips l CS Rear Bumper LEDs l Varrstoen 2.2.1 18x9.5+30 245-35 Hankook V12 l CP-E towplate l
bmfms3 is offline   Reply With Quote
 Old 10-06-2012, 10:40 PM   #9
IE.SD.Manny's Avatar
Posts: 84   (View Stats)
IE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond reputeIE.SD.Manny has a reputation beyond repute
it will stick out of your fender a good inch at least.
Stupid looking
08 MS3- Autotech HPFP Internals, Braile 21lb Battery, Cobb SRI, Evo IX MR BBS Wheels, HKS HipermaxIII Sport Coilovers, JBR SSP, JBR Knob, JBR 88aRMM, JBR Rear Sway, TB Suspension Adjustable Trunk Bar, TB Suspension Traction Bar, Test Pipe, Ultra Gauge Monitor
IE.SD.Manny is offline   Reply With Quote
Black RPF1 17x9 on CWP 802MS3 Wheels & Tires - WHITE 44 01-05-2014 08:11 AM
Silver RPF1's 17x9 brooks1277 Wheels & Tires - SILVER 20 04-16-2013 11:00 AM
Black 17x9 RPF1's et 45 245/45/17 MGM bnoon MazdaSpeed 3/6 - Wheels & Tires 8 06-05-2012 09:55 AM
Anyone have pictures of their 17x9 rpf1's? Fermion 2010 MS3 - Wheels & Tires 27 05-03-2011 12:46 AM
Page generated in 0.34460 seconds with 27 queries
