> 2010 MS3 - Wheels & Tires
 Old 10-24-2011, 10:10 PM   #1
sabrelli's Avatar
Posts: 39   (View Stats)
sabrelli has a spectacular aura aboutsabrelli has a spectacular aura about
Groaned at 3 Times in 1 Post
Default 18x8 +42mm, 235/40/18 Fitment (added PICS)
Hi All,
Ive searched this whole section on Wheel and Tires and couldn’t find any definite answer.
I ordered rims 18x8 +42mm and looking to get 235/40/18 and not sure if I will have trouble with rubbing.
Reading what other setups ppl have on here, it seems I will be quite safe.
I read some guy with Konig Deceptions 18x8 40mm with 225/40/18 had no issues before and after lowering but haven’t found anyone with same specs as mine
Any feedback or advice will be much appreciated!
UPDATE : PICS BELOW.
sabrelli is offline   Reply With Quote
 Old 10-24-2011, 10:11 PM   #2
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
youll be fine. no rubbing
im running 235s on a genwon, lowered on coils, and i only rub a bit when i have a fully loaded car and i smash the gas. Genpoos have more clearance than genwons
Last edited by super_pablo_; 10-24-2011 at 10:11 PM. Reason: MSF Database - Automerged Doublepost
super_pablo_ is offline   Reply With Quote
The Following User Says Thank You to super_pablo_ For This Useful Post:
sabrelli (10-24-2011)
 Old 11-01-2011, 01:53 PM   #3
nextgenerationx1's Avatar
Posts: 536   (View Stats)
nextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the world
Groaned at 27 Times in 13 Posts
i'm not lowered but i threw on some all seasons on my stockers 235/40/18 swince the dunlops r on 18x8 konigs, but no rubbing issue with the 235 on stock 7.5 wide wheels
06 Mazdaspeed 6
Precision 5858cea, PG turbo mani, 3" catless vband DP, 3" JBR intake, Cobb AP, Cobb EBCS
3 bar, TR8 intercooler, CPE 3" single exhaust/magnaflow muffler, NJSPEED P&P intake mani
KMD internals, CPE safe seals, GFB turbo fuse, Turbosmart 50/50
JBR tranny mount, AWR dogbone, Turbine Tech front/rear diff mount, Whiteline Rsb,
AWR rear adjustable endlinks, BC coils (suckie), OZ Ultraleggeras,
waiting to install Devils own meth kit,
ATVFREEK tuned!
PS: Forever BT slow
nextgenerationx1 is offline   Reply With Quote
The Following User Says Thank You to nextgenerationx1 For This Useful Post:
sabrelli (11-02-2011)
 Old 11-01-2011, 02:34 PM   #4
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
yep, you should be fine
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
 Old 11-01-2011, 02:51 PM   #5
MSP611's Avatar
Posts: 2,291   (View Stats)
I would still roll ur Fenders. I would go with a 245/35 and do the roll/pull on ur fenders and Ull be great
Sent from my GT-I9100 using Tapatalk
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
 Old 11-02-2011, 07:49 AM   #6
sabrelli's Avatar
Its all good..
Fitment is fine esp since im not lowered yet. Should be ok with full load too.
When i do lower, i will prolly roll guards..rather not take the risk and wreck the tires.
 Old 11-02-2011, 07:50 AM   #7
Swagerwagon03's Avatar
Posts: 309   (View Stats)
Swagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the worldSwagerwagon03 is the leader of the world
in for pics
08 MS3 GT
Swagerwagon03 is offline   Reply With Quote
 Old 12-01-2011, 08:07 AM   #8
shadoweighs1ton's Avatar
Posts: 28   (View Stats)
shadoweighs1ton is a splendid one to beholdshadoweighs1ton is a splendid one to beholdshadoweighs1ton is a splendid one to beholdshadoweighs1ton is a splendid one to beholdshadoweighs1ton is a splendid one to beholdshadoweighs1ton is a splendid one to beholdshadoweighs1ton is a splendid one to behold
pics please
L3GIT 2013 Civic SI Sedan GSP coilovers and SSR Comps 17x9 +27 245/40/17 Z2's
shadoweighs1ton is offline   Reply With Quote
 Old 12-01-2011, 08:17 AM   #9
Originally Posted by sabrelli View Post
Its all good..
yea i have mediocre all seasons on my stock wheels 235/40/18, just lowered on eihbachs and no issues whatsoever. i have the dun lops on my konigs. looking to replace the dun lops with a good pair of summer 235/40/18s also. but lowered on 235 is no issue for me
06 Mazdaspeed 6
ATVFREEK tuned!
PS: Forever BT slow
rfinkle2 (12-01-2011)
 Old 12-01-2011, 09:16 AM   #10
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,162   (View Stats)
Groans: 793
You need 245/35 18's.
No rolling required.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 12-01-2011, 12:58 PM   #11
MSP611's Avatar
yea^^^^ wat he said
In progress:
 Old 12-04-2011, 05:26 PM   #12
genrec's Avatar
Posts: 83   (View Stats)
genrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of light
Im trying to figure this out..but would this size be the exact same rolling size (diameter) as the stock 225/40/18 that come stock on the car? is the 235/40/18 actually wider but also the diameter is larger, and it will throw the speedo off a bit.
genrec is offline   Reply With Quote
 Old 12-04-2011, 05:33 PM   #13
Tokay444's Avatar
Groans: 793
245/35/18 is as close to the stock diametre as you're gonna get.
235 is wider than stock, narrower the 245, and doesn't have a sidewall comibination that as closely matches stock as the 245/35.
Demodded.
The Seals
rfinkle2 (12-09-2011)
 Old 12-06-2011, 08:53 PM   #14
genrec's Avatar
I went on like tire 1010 site or something and plugged in some sizes to the calculator....the 235/35/18 is actually a bit smaller than stock....i actually like what i saw with the 235/40/18...
what would be your guess in mpg loss with this size..it is not much bigger than stock 225/40/18 at all....
any mpg loss maybe 1 mpg if that?? curious
 Old 12-07-2011, 03:55 AM   #15
Tokay444's Avatar
Groans: 793
You should gain mpg as the tire is rotating less per mile.
But you'll never notice.
Demodded.
The Seals
 Old 12-07-2011, 07:26 PM   #16
genrec's Avatar
No..the 235/40/18 is a bit taller than the stock..so i wont be rotating less..but more??? Still, the MPG loss should not be that noticeable??
 Old 12-08-2011, 03:53 AM   #17
Tokay444's Avatar
Groans: 793
I'm not sure what you just said, but a taller tire will rotate less per mile, and yield better economy.
Demodded.
The Seals
 Old 12-08-2011, 07:15 PM   #18
genrec's Avatar
Noway, I just came from a few years of driving lifted trucks (Toyot tacomas, had 3 of them). Everytime I would lift and plus size the tires I would loose mpg a by a few...the smaller one would go in tire size, the better the mpg! me thinks anyway
 Old 12-08-2011, 11:05 PM   #19
Quickbluems3's Avatar
Posts: 63   (View Stats)
Quickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of light
Lol. The taller/wider tire is going to be bigger and heavier. More contact to the ground adding more rolling resistance as well as rotational mass means the engine has to work harder. Also your speedo and odometer may be off as well with a taller tire-hence lower MPG as you also saw in your plus sizing in the truck. It'll be minimum in the Mazda going from a 225-235
Quickbluems3 is offline   Reply With Quote
 Old 12-09-2011, 03:58 AM   #20
Tokay444's Avatar
Groans: 793
The loss in mpg comes from accelerating the heavier wheel/tire combo.
But a larger rolling diametre means less revolutions per mile.
So at a given cruising speed, you're saving gas with a taller tire.
Demodded.
The Seals
Nliiitend1 (12-09-2011), rfinkle2 (12-09-2011)
 Old 12-09-2011, 05:16 AM   #21
Where are the pics of this setup?
 Old 12-09-2011, 05:43 PM   #22
sabrelli's Avatar
Pics of setup in First post.
cp-e XCEL Cold Air Intake | cp-e Rear Engine Mount | Jbarone Short Shift Plate | Team Voodoo Shift Knob | Visual Garage Sharkfin | Red Painted Calipers | Resonator Delete | 15% Tints | 18 x 8 Black Rims on Dunlop 235/40/18
17x8 5x114.3 42mm offset mrmonk7663 2010 MS3 - Wheels & Tires 7 12-09-2011 05:25 AM
Wheel fitment? Postulio4joo 2010 MS3 - Wheels & Tires 1 01-18-2011 01:00 AM
18x7.5, 42mm...anyone have this on their ms3? builthatch MazdaSpeed 3/6 - Wheels & Tires 0 12-24-2008 10:30 PM
Olympus E-420 10MP Digital SLR Camera Kit w/ 14-42mm Lens $549.99 Free Shipping Haltech Hot Deals Section 0 04-03-2008 02:30 PM
Page generated in 0.39906 seconds with 29 queries
