> 2010 MS3 - Wheels & Tires
Notices
Like Tree3Likes
  • 1 Post By drummermike58
  • 1 Post By GODspeed7
  • 1 Post By burn813
 Old 07-29-2012, 02:14 AM   #1
Jin
Jin's Avatar
Posts: 64   (View Stats)
Jin has a spectacular aura aboutJin has a spectacular aura about
Groaned at 7 Times in 4 Posts
Default Thinking about going to 19'', need advice....
I'm thinking about going to 19''.
Just wondering if anyone is running 19'' here? What's the proper coilover kits and tires? What's the best number for offset, camber? Any recommandation?
Thanks for the help!
Jin is offline
 Old 07-29-2012, 02:22 AM   #2
jnt
jnt's Avatar
Posts: 40   (View Stats)
jnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond repute
I'm on 19" rims and I think it looks great, the 19s I have are even slightly lighter than stock rims. these are 19 x 8.5 +45 with a 235 x 35 tire. Cheers.
jnt is offline
The Following 9 Users Say Thank You to jnt For This Useful Post:
Alpha (07-29-2012), CWP_MS3 (09-10-2012), EdgeAutosport.com (07-30-2012), GunGuru727 (12-29-2012), J'sSpeed3 (07-29-2012), MZRSPEED (07-29-2012), PartiAudiMazdarati (08-28-2012), SLOWHATCH (08-05-2012), tddvrrn (08-06-2012)
 Old 07-29-2012, 05:20 AM   #3
rfinkle2's Avatar
Posts: 12,562   (View Stats)
Groans: 235
trf5000 has 19" nurburgrings on his car.
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
rfinkle2 is online now
trf5000 (07-30-2012)
 Old 07-29-2012, 07:19 AM   #4
MZRSPEED's Avatar
Posts: 165   (View Stats)
MZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the world
Are those Advan?
'12 SPEED3 LSM--- / AUTOTECH HPFP / RACE PIPE / JBR SHIFTER BUSHINGS / SURE SHORTCUT /
14.195@101.47 (stock tune) Orlando Speedworld 3/27/13
MZRSPEED is offline
 Old 07-29-2012, 07:21 AM   #5
NATOR Photog
Domino81's Avatar
Posts: 3,839   (View Stats)
Groaned at 61 Times in 26 Posts
They don't look bad...
...even though I've been thinking of running 17" RPF1's lately...
Anthony D. Christiano
2008 CosmicBlue Mazdaspeed3 - 294whp/335wtq on stock K04, new BNR Stage 3 numbers coming soon...
BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, 3-bar map and connector, PTP injector seals and studs, Kritz 3-port boost solenoid, Sure Return, CP-E FMIC, TWM STS, AutoTech Fuel Pump Internals, James Barone 88-Duro RMM, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 ET48, Cobb Rear Sway Bar, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back. BF Goodrich g-Force Sport 235/40/18's, MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz
Domino81 is offline
 Old 07-29-2012, 08:01 AM   #6
Jin
Jin's Avatar
Thanks man! So you're running on stock coilover? Will there be any rubbing issues for this kind of setup? Thanks again for your advice!
Jin is offline
 Old 07-30-2012, 04:03 AM   #7
jnt
jnt's Avatar
Originally Posted by MZRSPEED View Post
Are those Advan?
Yes, they are the Advan RS-D
Thats fine, Im on lowered springs (Eibach pro kit) and I dont have any rubbing at all. Cheers.
jnt is offline
 Old 07-30-2012, 04:06 AM   #8
Able
helmetface's Avatar
Posts: 4,425   (View Stats)
Groans: 125
Why would anyone want to run 19's on this car>>.....
247 that a way --->
helmetface is online now
The Following 10 Users Say Thank You to helmetface For This Useful Post:
breakfstincluded (12-30-2012), Colin1337 (07-30-2012), Dash08 (09-04-2012), Easter Bunny (12-29-2012), JohnMS3 (12-29-2012), kritz (12-30-2012), Macncheese (08-28-2012), Neverlift (12-29-2012), PartiAudiMazdarati (08-28-2012), uncorked11 (12-30-2012)
 Old 07-30-2012, 04:26 AM   #9
jnt
jnt's Avatar
247 that a way --->
Why not! 19's on a Gen 2 looks great and you dont lose any of the performance if you are prepared to get decent wheels that are light weight. On a Gen 1 I wouldnt go 19's but on a Gen 2 it fills the wheel arch perfectly. So I say why not have the look and the performance. Cheers.
jnt is offline
The Following 2 Users Say Thank You to jnt For This Useful Post:
memin (08-27-2012), SLOWHATCH (08-05-2012)
 Old 07-30-2012, 05:22 AM   #10
trf5000's Avatar
Posts: 1,959   (View Stats)
19s work just fine on the PU it seems. I haven't had any issues. I wish I would have run a bigger tire though.
2010 MS3 VRM - Corn Fed PU
CS CBE, CS RP, CS DP, JBR 80/88 Duro Fully Mounted, TS BPV, CPE HPFP, CS SRI/TIP, CPE-FMIC, AP, NGK Iridiums, GS EBCS in 3 Port Int, JMF IM, Hypnotic Tuned, TWM Full Replacement, E4 Weighted Knob, Eibach Prokit, 18x8.5 Konig Milligrams Matte Black with Machined Undercut, 245/40 18 Fuzion ZRi
Best Run: 13.1 @ 109 1.9 60ft Atco
Slow build in progress
trf5000 is offline
 Old 07-30-2012, 05:44 AM   #11
Jin
Jin's Avatar
247 that a way --->
Why not? I think the 18'' is perfect on Gen1 but....a bit small on Gen2....
Just the spring?
Kinda worry about lowered body cause I'm living in Chapel Hill now....lots of "up and down"s....everyday my roomie kinda suffers to drive her z06 back home....
Last edited by Jin; 07-30-2012 at 05:44 AM. Reason: MSF Database - Automerged Doublepost
Jin is offline
 Old 07-30-2012, 05:45 AM   #12
4G63's Avatar
Posts: 1,390   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 120
Groaned at 154 Times in 77 Posts
I'm really not sure how a bigger 19" rim helps in performance in any way but I must crazy...no track cars worldwide run bigger than an 18 it's too much weight and height to run a properly set up track car. 18s are fine on a Gen 2 if it's lowered even 17" if you really want to make it as light and nimble as possible
As for 19" Advans...send ur paycheck my way you rich bastard lol.
2003 TB Evo VIII
Big turbo, injectors, intercooler and stuff. 448whp 373trq 25psi 93oct. Speed Density Converted
Old: 2009 White MS3 GT. Fully bolted and tuned. Sold
4G63 is offline
 Old 07-30-2012, 12:21 PM   #13
Wide tire man
dbrier's Avatar
Posts: 706   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
They don't help performance. It's an appearance mod.
Even if two wheels weigh the same, the smaller diameter wheel will perform better. The weight is closer to the center and requires less energy to change speed.
My motto is: If you want the mod, go for it. Don't worry about the very minor performance difference unless you're extremely competitive in your racing series.
2012 CWP Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP, Denso ITV22 plugs, JBR rear sway bar, Corksport rear camber arms, CP-e rear motor mount, Mazda5 rear brake upgrade.
Too many wheels & tires to list.
dbrier is offline
The Following User Says Thank You to dbrier For This Useful Post:
jdmnerd (07-31-2012)
 Old 08-05-2012, 05:55 PM   #14
drummermike58's Avatar
Posts: 358   (View Stats)
drummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the world
19x8.5 et35 245 40 r19 tires on d2 coilovers
:: Gusto :: likes this.
--2010 BM MS3--
Treadstone tr8 fmic core, custom piping, self made 3.5" MAF, gtx3076 .82 a/r ts/vband hotside, RaceRoots EWG exh mani/3" vband DP, TIAL MVR EWG, UR Catback, Sure shortcut, Sure R3 rmm, Eagle Rods, Custom 10.5:1 .020 over pistons, balanced rotating assy., ARP head and main studs, Autotech internals, Accessport, 3bar map sensor, vtcs delete, EGR delete, Balance shaft delete, Hallman MBC, HKS SSQV 4 BOV, NGK iridium spark plugs, D2 coilovers, Nextmod lip kit, painted Enkei Aegis 19x8.5 et +35, 245/40/19 potenza tires, chinese HIDs, JB shift knob, 35% tinted, still tuning...
drummermike58 is online now
The Following User Says Thank You to drummermike58 For This Useful Post:
 Old 08-06-2012, 08:59 PM   #15
KevinWP's Avatar
Posts: 9   (View Stats)
KevinWP can only hope to improve
Groaned at 16 Times in 5 Posts
JNT, how low is that kit? Is the body of the car lower to the ground? I love the look of your car with those rims, but I don't want to be worried about speedbumps and steep parking garages.
Oh, and would the car look dumb if you hadn't used that lowering kit?
KevinWP is offline
The Following User Says Thank You to KevinWP For This Useful Post:
Tlnt60 (09-03-2012)
 Old 08-08-2012, 06:36 AM   #16
jnt
jnt's Avatar
Thanks, its only a moderate drop, from memory I think about a inch or so all round, there are a few threads in the "Suspension & brakes section that mentions the drop you are likely to get with the Eibach springs, with the slightly bigger rims it may give the illusion that the car is lower than it actually is.
With my build I got the springs before I got the wheels so I honestly could not answer your last question.
All the best with what ever you decide to do. Cheers from down under!
jnt is offline
 Old 08-27-2012, 04:56 PM   #17
TRBLSUM's Avatar
Posts: 25   (View Stats)
TRBLSUM has disabled reputation
JNT did you roll your fenders and can you have passengers without rear fenders rubbing? Cheers.
2012 MS3 CWP//Ace Alloy Wheels Mica Grey (19x8.5 +45) Conti DW Ext. 235-35-19//Eiback Pro Kit//Curt 11383 (1.25" Hitch)//Cobb AP//CP-E HPFP//SF F3-ASI-TIP-Return Pipe-RMM-CounterShift//Racing Beat CBE//JBR Stg 2 OCC//RMM.
TRBLSUM is offline
 Old 08-28-2012, 05:26 AM   #18
jnt
jnt's Avatar
Hi, I didn't roll the fenders, and there is no rubbing with passengers, that's with the 19" and Yokohama S Drive 235 x 35 x19 tyres. When I went with this setup I was told to be mindful that some tyres run wider than others even if they are all 235s
All the best. Cheers.
jnt is offline
 Old 08-28-2012, 10:25 AM   #19
TRBLSUM's Avatar
Excellent, thank you, any camber issues and do you think a 240 40 19 would fit or 235-40-19? Reason being the wider (240) better for grip-hp and the 40 for meet to protext the wheel. Sorry for the so many questions but i have not much 19" info here even under the Gen 1 section. thanks again, cheers.
TRBLSUM is offline
 Old 08-28-2012, 11:51 AM   #20
mrchristopher's Avatar
Posts: 6   (View Stats)
mrchristopher is an unknown quantity at this point
I am also running 19" ADVANS w/ +45 and the Eibach pro kit. I can confirm that it rides well and doesn't rub the fenders
mrchristopher is offline
 Old 09-04-2012, 04:50 PM   #21
MazdaBoy2.3's Avatar
Posts: 2,289   (View Stats)
MazdaBoy2.3 has disabled reputation
I tried my old track rims from my Gen1 MZ3 on my Gen2 Speed...and what a difference.
I was saving about 8 lbs a wheel and I could definitely feel it.
Track rims are 17*7.5 Konig Feathers with 225/45/17 Hankook EVO's
2010 Black Mica
Corksport: RP, SRI/TIP, Cold Airbox, RMM Inserts, Mudflaps
JBR: SSP & Bushings
SURE: Boost Tubes
COBB: Accessport
Other: AT Internals, 35% Tint, DDM 6k HID, NGK Plugs
My car is being rfinkle(d) with! VD: 263hp/319tq
MazdaBoy2.3 is offline
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
kritz (12-30-2012)
 Old 12-29-2012, 06:36 PM   #22
Euro2Jdm's Avatar
Posts: 49   (View Stats)
Euro2Jdm is infamous around these partsEuro2Jdm is infamous around these partsEuro2Jdm is infamous around these partsEuro2Jdm is infamous around these partsEuro2Jdm is infamous around these partsEuro2Jdm is infamous around these parts
Groaned at 185 Times in 36 Posts
No such thing as a 240-40 but there is a 245. I would go 235 to be on the safe side. Also a wider tire will not give you more horsepower just a bigger contact patch and from only going from 235 to a 245 wont make much difference anyway.
Euro2Jdm is offline
The Following User Says NO Thank You to Euro2Jdm For This Un-useful Post:
Easter Bunny (12-30-2012)
 Old 12-29-2012, 09:06 PM   #23
GODspeed7's Avatar
Posts: 2,618   (View Stats)
Groaned at 46 Times in 31 Posts
Thanks for bumping a 4 month old thread to clear that up!
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete.
GODspeed7 is offline
The Following 3 Users Say Thank You to GODspeed7 For This Useful Post:
caesura (12-29-2012), smoogs12 (12-30-2012), uncorked11 (12-30-2012)
 Old 12-30-2012, 06:43 AM   #24
Euro2Jdm's Avatar
It was a question that was never answered idiot. I don't care how long ago it was posted and never looked at the date. This is a car forum where people can ask questions and get answers not stupid remarks like you give. You wouldn't answe his question but you quote me to make a stupid remark? Wow what a waste of a forum member.
Euro2Jdm is offline
The Following 4 Users Say NO Thank You to Euro2Jdm For This Un-useful Post:
Block8head (12-30-2012), Easter Bunny (12-30-2012), Pointless (12-30-2012), uncorked11 (12-30-2012)
 Old 12-30-2012, 07:30 AM   #25
GODspeed7's Avatar
No seriously bro I was in the market for some new tires and wanted to go with 250/40/18 but since the extra width doesn't matter I will just go with the 240/40/18's!!!
It's called busting your balls! If you can't take it then this forum obviously isn't for you. Yeah it's a performance oriented forum but a good portion of it is bullshitting amongst common people. I wasnt even mean to you it was just a sarcastic remark. you obviously need to read a little more and know what you are getting into around here before your feelings get hurt.
The guy didn't know that tires only came in 10mm increments ending in 5. If you buy a mazdaspeed and don't know that he has bigger things to worry about other than tires.
Block8head (12-30-2012), Easter Bunny (12-30-2012), thanox2 (12-30-2012)
 Old 12-30-2012, 02:08 PM   #26
Euro2Jdm's Avatar
I have been on car forums for over 10 years and I know how they work. I also know that there would be a lot less stupid post if someone was to simply answer the question instead of making dumb remarks. Like why would you even post something if it wasn't of any help? That's the point there is a lot more clutter on these forums because of kids like yourself. No beef just saying, have fun posting useless post to get that post count up.
Euro2Jdm is offline
 Old 12-30-2012, 02:54 PM   #27
smoogs12's Avatar
Posts: 3,284   (View Stats)
Groans: 153
Not this one.
Because its funny or contains pics of tits.
Clutter=character. Any thread of great importance is usually very on topic. The reason we bullshit is because most of us like to jab at each other like that. It's also just how we operate as a forum in general (especially towards brownies).
1,280+1
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
smoogs12 is online now
The Following 5 Users Say Thank You to smoogs12 For This Useful Post:
Block8head (12-30-2012), kritz (12-30-2012), ms6mil (12-30-2012), Pointless (12-30-2012), uncorked11 (12-30-2012)
 Old 12-30-2012, 02:57 PM   #28
TRBLSUM's Avatar
and here is the end result. Thanks to all for the feedback, I'm very happpy with the outcome.
TRBLSUM is offline
The Following 4 Users Say Thank You to TRBLSUM For This Useful Post:
ms6mil (12-30-2012), rfinkle2 (12-30-2012), smoogs12 (12-30-2012), uncorked11 (12-30-2012)
 Old 12-30-2012, 06:20 PM   #29
GODspeed7's Avatar
This isn't some dumbass car forum that you have been on in the past 10 years. This is a family. It isn't all business. It's a lot of bullshitting with a plethora of knowledge and info thrown in. I'm not your kid and last but not least you obviously have not taken the time to research how THIS forum works. I think it would be best if you took your uptight ass to mazdas247 where all of your "knowledge" is better "appreciated". Bottom line is you bumped an old thread to make a comment about tires that is common fucking knowledge. I hope you sleep better at night knowing you saved MSF! Fucking tool.
aggierandy likes this.
 Old 12-30-2012, 06:28 PM   #30
Posts: 5,683   (View Stats)
Groans: 58
Groaned at 25 Times in 21 Posts
Tokay444; oh shit I mean Raider; close this POS thread.
CorkSport Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu!
kritz is online now
The Following 7 Users Say Thank You to kritz For This Useful Post:
Block8head (12-30-2012), KusteLokal (12-30-2012), lilred (12-30-2012), Pointless (12-30-2012), SarcasticOne (12-30-2012), smoogs12 (12-30-2012), uncorked11 (12-30-2012)
 Old 12-30-2012, 06:29 PM   #31
Stage GINGER
burn813's Avatar
Posts: 2,441   (View Stats)
Trololololol ^
kritz likes this.
2008 MS3 gt
383whp 380tq on 22psi vdyno results
HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 PERM TUNED
burn813 is offline
The Following User Says Thank You to burn813 For This Useful Post:
kritz (12-30-2012)
 Old 12-30-2012, 08:01 PM   #32
Scammer Hunter
Raider's Avatar
Posts: 14,980   (View Stats)
Groans: 449
Groaned at 105 Times in 88 Posts
No
MSF Moore OK Tornado Recovery Donation Thread
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
Raider is online now
kritz (12-30-2012)
Thinking of doing the res. delete. Need some advice. bohica17 2010 MS3 - Engine, Transmission & Driveline 79 02-13-2013 04:38 AM
To anyone thinking about... Hectik1 MazdaSpeed 3/6 - Turbo Induction 3 02-26-2009 06:47 PM
Page generated in 0.58935 seconds with 40 queries
