> 2010 MS3 - Wheels & Tires
 Old 07-26-2011, 07:58 PM   #1
DwightS's Avatar
Posts: 125   (View Stats)
DwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the worldDwightS is the leader of the world
Groaned at 6 Times in 3 Posts
Default tire size for low offset grids
I am going with the 9.5" Grids ET38. It just looks so bad ass I cannot resist. Anybody recommend 225's or 235's?
DwightS is offline   Reply With Quote
 Old 07-26-2011, 08:41 PM   #2
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
would it be really stretched on a 235 or 225?
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
 Old 07-27-2011, 06:43 AM   #3
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
Groaned at 62 Times in 28 Posts
both tires will be stretched
225 on a 9.5" wheel will look like shit, and i wouldn't suggest doing it
Rich-PMS is offline   Reply With Quote
The Following User Says Thank You to Rich-PMS For This Useful Post:
rfinkle2 (07-27-2011)
 Old 07-27-2011, 07:06 AM   #4
ccspeedsix's Avatar
Posts: 152   (View Stats)
ccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond reputeccspeedsix has a reputation beyond repute
Youd have to run like 255s to make it looks somewhat normal on 9.5" wides. Use to run a set on my deuce 40. But what he said ^^^^^ if your going 9.5 the min i would recommend would be 245/255 which means no herra frush for you because tires are gunna poke out no matter what.
Im pretty sure you wouldnt be able to fit those in the ms3. At least, not if your slammed. If your only like 1-1.5 in from stock id say throw some 245s on that bitch and go to a shop that can set you up with a good drop and alignment. As long as your not going for VIP or hella flush, a shop can get those tires working for ya.
Function over form! at least when your trying to use crazy wheel setups
ccspeedsix is offline   Reply With Quote
The Following User Says Thank You to ccspeedsix For This Useful Post:
DONOTBUGME (07-27-2011)
 Old 07-27-2011, 08:49 AM   #5
DONOTBUGME's Avatar
Groans: 266
God I hate the stretched tire look, I just dont get why you would get such a wide wheel then put such little rubber on it.
The Following User Says Thank You to DONOTBUGME For This Useful Post:
JS + MS3 (07-27-2011)
 Old 07-27-2011, 08:53 AM   #6
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I don't know of any gen2's running a 9.5" wheel.
 Old 07-27-2011, 09:58 AM   #7
DONOTBUGME's Avatar
Groans: 266
I know of some gen1s doing it with lots of fender work, Gen2s seem to have more room in back too. But what the point, hes putting 225-235s, my suggestion would be to find a brick wall and drive strait into it.
The Following 2 Users Say Thank You to DONOTBUGME For This Useful Post:
Blackspeed (07-27-2011), kritz (07-27-2011)
 Old 07-27-2011, 10:00 AM   #8
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
did you just pull these sizes out of your ass? If you look at tire rack, they list appropriate rim sizes for each tire size.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
 Old 07-27-2011, 10:29 AM   #9
rfinkle2's Avatar
Groans: 298
Look, we are supposed to be a bit nicer to some of the members, so would you recommend he finds a brick wall and drives a bit sideways into it?
The Following 9 Users Say Thank You to rfinkle2 For This Useful Post:
AZSPEED3 (08-27-2011), bertrand_CX_7 (07-28-2011), Broxer (07-29-2011), DONOTBUGME (07-27-2011), jroc (07-28-2011), JS + MS3 (07-27-2011), kritz (07-27-2011), SLOWHATCH (08-27-2011), specvspeedfreak (08-28-2011)
 Old 07-27-2011, 10:40 AM   #10
MazdaASM's Avatar
Posts: 491   (View Stats)
MazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the world
Groaned at 9 Times in 7 Posts
OP crying in a corner somewhere?
9.5 is too wide.. i have 255 on my 9" rpf1's on my s2000, they fit perfectly
MazdaASM is offline   Reply With Quote
 Old 07-27-2011, 10:45 AM   #11
Did Finkle just make a joke at the expense of another member? You are learning the ways of the Darkside, young padwan.
OP, the only proper way to run those rims is with pulled fenders and 255's or a nice 3" lift and mud tires.
 Old 07-27-2011, 10:55 AM   #12
Rich-PMS's Avatar
Groans: 68
why would you get a wide wheel (more weight) just to run the next size bigger tire than stock....
i was going to put a 305 on a 9.5" wheel on my dakota.
 Old 07-27-2011, 06:58 PM   #13
DwightS's Avatar
Ok. For all of you faggots that like to complain about what you don't like I found a couple shots of someone running 225/40. If you think this looks shitty your out of your mind but to each their own. I am getting these.
 Old 07-27-2011, 10:22 PM   #14
YZF-R6's Avatar
Posts: 189   (View Stats)
YZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the world
I guess it looks pretty good.... I just DO NOT understand the point of getting a 9.5" rim only to put a stock width or smaller tire on it. Maybe im just not cool or something.....
2010 MS3 Liquid Silver: TRZ Poly RMM, Cobb AP, PERM (Load-Based FTW), CP-E HPFP, SURE Aeros, HTP TIP, Corksport TMIC, SURE Boost Tubes, Magnaflow CBE, Corksport T/P, JBR LE Shift Knob & Weight, Redline MTL, Swift Spec-R, TSW Nurburgring 18x8.5, Nitto NT555 235/40/18.
If You Don't Like The Pu, Don't Play In The Pu.
YZF-R6 is offline   Reply With Quote
 Old 07-27-2011, 10:38 PM   #15
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groans: 98
Groaned at 72 Times in 51 Posts
seriously... is it your first time thinking of getting an aftermarket rims??
9.5 with 225 or 235????
ridiculous
man up and get the tires in proper size
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 07-27-2011, 10:46 PM   #16
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
fwd cars dont handle low offsets period
 Old 07-27-2011, 10:59 PM   #17
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
Why not go 9.5" front and 10" rear? While your add it run a 215 tire too..
Its what the cool kids are doing
Spoofmastafly is offline   Reply With Quote
The Following User Says Thank You to Spoofmastafly For This Useful Post:
Blackspeed (07-28-2011)
 Old 07-28-2011, 03:54 AM   #18
rfinkle2's Avatar
Groans: 298
@DwightS, that looks fine to me (the white car you posted), but are you sure those are 225's on a 9.5 inch wheel?
I have 235's on an 8.5 and they are a bit stretched.
BTW, if they aren't being mounted and balanced by the company you are buying from, try to find someone with a Hunter touchless machine to do the work.
You can be sure your brand new wheels will not get damaged in the mounting process with one of those machines.
 Old 07-28-2011, 04:00 AM   #19
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
ive talked to that guy before dwight.. he's running 245's on his car.. all he did was roll fenders and mess with his CO settings.. aint no 225's..
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline   Reply With Quote
The Following User Says Thank You to Dre For This Useful Post:
rfinkle2 (07-28-2011)
 Old 07-28-2011, 08:28 PM   #20
DwightS's Avatar
I verified they are 235's. Thanks for everybodys info.
The Following User Says Thank You to DwightS For This Useful Post:
rfinkle2 (07-29-2011)
 Old 07-28-2011, 08:34 PM   #21
jwilkins88's Avatar
Posts: 3,675   (View Stats)
jwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the world
Groans: 126
Groaned at 59 Times in 47 Posts
Don't be a pussy... Go with 185s
jwilkins88 is offline   Reply With Quote
 Old 07-29-2011, 08:51 AM   #22
ccspeedsix's Avatar
jwilks is a brownie !! ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^^^^^^
Broxer (07-29-2011)
 Old 08-27-2011, 03:50 PM   #23
jdhiatt's Avatar
Posts: 56   (View Stats)
jdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the worldjdhiatt is the leader of the world
How did they turn out Dwight?
jdhiatt is offline   Reply With Quote
 Old 08-27-2011, 08:59 PM   #24
DwightS's Avatar
Still waiting.. They are on backorder till early September. Also got rear ended 2 nights ago. So as soon as I get the wheels and once I get the car fixed I will post pictures.
 Old 08-28-2011, 04:46 AM   #25
jdhiatt's Avatar
Damn man! Sorry to hear you got rear ended. Hopefully you are good?!?! I'll be watching out for those pictures for sure.
MS3 wheel offset/size questions... Smokehouse MazdaSpeed 3/6 - Wheels & Tires 12 04-30-2016 02:36 PM
stock wheels: Size,Bolt Pattern,Offset,Bore Jasnall MazdaSpeed 3/6 - Wheels & Tires 20 06-10-2014 12:53 PM
Need quick advise on tire size and rim size setup sensui MazdaSpeed 3/6 - Wheels & Tires 1 03-18-2011 11:10 AM
Need some input on offset and tire size KeysMS3 MazdaSpeed 3/6 - Wheels & Tires 3 07-02-2010 01:32 PM
which size offset for rota slips Darksun280 MazdaSpeed 3/6 - Wheels & Tires 31 10-08-2008 07:47 AM
Page generated in 0.42826 seconds with 34 queries
